473-150-571-002
    CONN DIFF ARRAY RCP 150P R/A SMD
473-150-571-002 数据手册
TOLERANCE UNLESS OTHERWISE SPECIFIED .X .XX .XXX ±0.25 ±0.15 ±0.10 MATERIAL: HOUSING: CONTACT: OPERATION TEMPERATURE: -55°C TO 85°C 64.320 ELECTRICAL: CURRENT RATING: VOLTAGE RATING: INSULATION RESISTANCE: CONTACT RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: 0.5A 50V AC 500MΩ MIN. 50MΩ MAX. 150V AC / 60 SEC. B A PITCH 0.800 TYP. CL 0.10 A PIN 149 1.99 6.440 0.81 PIN 150 A 9.02 PIN 1 L.C.P SERIES, UL-94V-0 COPPER ALLOY 10µ" GOLD PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER NICKEL UNDER PLATING 67.500 0.22 PIN 2 1 ORIGINAL NOTES: 11.350 73.000 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. -A- B MARKED MARKED * C : CRITICAL DIMENSION DIMENSIONS NEED TO BE MEASURED IN CPK LONG PIN 59.200 2.85 8.350 PIN 1 2.225 67.250 C Ø1 .32 0 4.000 65.800 SEC. A-A SCALE 5:1 PIN 149 67.250 65.800 0.420 PIN 1 PIN 150 PIN 2 59.200 BOARD TO BOARD, 150 CONTATS, RIGHT ANGLE, ALL LONG PINS, FEMALE ACAD REFERENCE NO.: DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE 1.700 1.780 4.025 PIN 149 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 4.350 Ø 0. 6 Ø1 .40 30 0 Ø1 .91 0 0.630 PIN 150 1.750 CL 67.250 1.500 PIN 2 473-150-571-002 DATE: JUNE.28 /2018 DATE: N.T.S SHEET 1 OF 2 DRAWING NUMBER: 473-150-571-002 ISSUE PART NUMBER: 473-150-571-002 1 TOLERANCE NOTES: UNLESS OTHERWISE SPECIFIED MATERIAL: HOUSING: CONTACT: L.C.P SERIES, UL-94V-0 COPPER ALLOY 10µ" GOLD PLATING ON CONTACT AREA MATTE TIN PLATING ON SOLDER TAIL OVER NICKEL UNDER PLATING OPERATION TEMPERATURE: -55°C TO 85°C ELECTRICAL: CURRENT RATING: VOLTAGE RATING: INSULATION RESISTANCE: CONTACT RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: 0.5A 50V AC 500MΩ MIN. 50MΩ MAX. 150V AC / 60 SEC. MARKED MARKED *C .X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 1 ORIGINAL ±0.15 ±0.10 ±0.05 : CRITICAL DIMENSION DIMENSIONS NEED TO BE MEASURED IN CPK PIN 150 PIN 2 LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL PIN 1 PIN 149 4.900 "L" "L" :LONG PIN BOARD TO BOARD, 150 CONTATS, RIGHT ANGLE, ALL LONG PINS, FEMALE COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO.: DRAWN: W.T CHECKED: SCALE: 473-150-571-002 DATE: JUNE.28 /2018 DATE: N.T.S SHEET 2 OF 2 DRAWING NUMBER: 473-150-571-002 ISSUE PART NUMBER: 473-150-571-002 1
473-150-571-002 价格&库存
很抱歉,暂时无法提供与“473-150-571-002”相匹配的价格&库存,您可以联系我们找货
