500-040-231-C01
500-040-231-C01
    ZD CONNECTOR, 2.0 MM HARD METRIC
500-040-231-C01 数据手册
10 1 1 ORIGINAL 2.50 1.50 TYP. 5.68 REF. 2.50 TYP. ±0.35 ±0.25 ±0.15 -Z- .X .XX .XXX 22.50 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM. TOLERANCE UNLESS OTHERWISE SPECIFIED NOTES: ROW A MATERIAL: HOUSING: SHIELD: 11.65 15.35 3.00 TYP. ROW B ROW BG (GROUND) LCP+30% GLASS REINFORCED, UL94V-0 PHOSPHOR BRONZE NICKEL PLATING PHOSPHOR BRONZE GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING 30~100µ" ON SOLDER TAIL OVER NICKEL 50~150µ" UNDER PLATING ROW C CONTACT: ROW D ROW DG (GROUND) -Y0.75 REF. 2.50 PCB HOLE DIM: DRILLED HOLE = 0.700±0.025mm 24.95 MAX. 5.30 ±0.05 -X- +0.02 2.95-0.08 6.40 FINISHED HOLE = 0.600±0.050mm Cu THICKNESS = 0.0375±0.0125mm 13.40 SnPb THICKNESS = 0.007±0.003mm 9 X 2.5 = 22.5 2.50 TYP. 22.50 2.50 TYP. TYP. ROW A ROW B ROW BG (GROUND) ROW C ROW D ROW DG (GROUND) 1.50 -Y- -X0.05 X Y ALL PLATED THRU HOLES SCALE 2:1 ACAD REFERENCE NO.: ZD CONNECTOR, MALE, VERTICAL, 2 PAIR DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 500-040-231-C01 DATE: JUNE.27 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 500-040-231-C01 ISSUE PART NUMBER: 500-040-231-C01 1
500-040-231-C01 价格&库存
很抱歉,暂时无法提供与“500-040-231-C01”相匹配的价格&库存,您可以联系我们找货
