500-080-225-D01
500-080-225-D01
    ZD CONNECTOR, 2.0MM HARD METRICM
500-080-225-D01 数据手册
.X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. UNLESS OTHERWISE SPECIFIED, ALL RADIUS ARE 0.2 MM. TOLERANCE UNLESS OTHERWISE SPECIFIED ±0.25 ±0.15 ±0.10 ORIGINAL 1 24.90 2.50 1.65 34.55 A B 10.00 A 5.30 6.35 2.00 6.90 3.00 0.1 0.1 A B 0.40 1.50 1.50 DETAIL A 0.12 1.15 17.68 17.32 2.20 5.68 1 10.45 TOP SURFACE OF DAUGHTER CARD 2.70 3.00 10 15.00 -A- A 19.65 23.35 1.50 0.12 - - 4.50 SCALE 4:1 17.20 NOTES: 0.20 0.12 MATERIAL: HOUSING: SHIELD: A B -X- 1 ROW A ROW B ROW BG (GROUND) ROW C ROW D ROW DG (GROUND) ROW E ROW F ROW FG (GROUND) ROW G ROW H ROW HG (GROUND) 5 6 10 CONTACT: 0.05 X Y 1.500 TYP. 1.50¡Ó0.20 ALL PLATED THRU HOLES LCP GLASS REINFORCED, UL94V-0 COPPER ALLOY NICKEL PLATING COPPER ALLOY GOLD FLASH PLATING ON CONTACT AREA MATTE TIN PLATING 30~100µ" ON SOLDER TAIL OVER NICKEL 50~150µ" UNDER PLATING PCB HOLE DIM: DRILLED HOLE = 0.700±0.025mm -Y- FINISHED HOLE = 0.600±0.050mm Cu THICKNESS = 0.0375±0.0125mm SnPb THICKNESS = 0.007±0.003mm 2.500 TYP. 9 X 2.5 = 22.5 PCB LAYOUT SCALE 2:1 0.1 ACAD REFERENCE NO.: ZD CONNECTOR, MALE, RIGHT ANGLE, 4 PAIR DRAWN: W.T CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: 500-080-225-D01 DATE: JUNE.27 /2018 DATE: N.T.S SHEET 1 OF 1 DRAWING NUMBER: 500-080-225-D01 ISSUE PART NUMBER: 500-080-225-D01 1
500-080-225-D01 价格&库存
很抱歉,暂时无法提供与“500-080-225-D01”相匹配的价格&库存,您可以联系我们找货
