B14HD-L-258-B-4
B14HD-L-258-B-4
    JOHNSON
    间断 占空比螺线管 开放框架(拉) 型 0.400"(10.16mm) 行程 6VDC 底座安装
B14HD-L-258-B-4 数据手册
Ledex® Magnetic Latching Box Frame Size B14HD-L VDC Battery Powered gh ed Long Life 4 - 10 Inch (254 mm) leads 6 - Terminals Pole Configuration 1 - Flat Face 2 - Conical Specifications Typical Force @ 20°C – Conical (net with spring) Operation Pull Dielectric Strength 1000 VRMS for one second Unlatch Voltage See schematic and coil data below Magnetic Holding Force* Conical: 8.7 lb (38 N) Flat Face: 12.6 lb (56 N) Coil Insulation + Class “ B”: 130°C max. – HighTermination Long Magnetic Miniature Quietmm) PVC lead wires or Coil 10"Performance (254 Speed Life Latching Size terminal Plunger Pole Face Flat face or conical Plunger Weight 0.86 oz. (24.4 g) Total Weight 3.47 oz. (98.4 g) + – Quiet Magnetic Miniature *Latching In no power, latched position, with return spring Performance Size 12.0 (53.4) 10.0 (44.5) 6.0 (26.7) 4.0 (17.8) 2.0 (8.9) 0 Unlatch Quiet Miniature Maximum Duty Cycle Voltage 50% Performance Size Recommended Max ON Time (sec) 1 1 25% 10% 1 1 Watts (@ 20°C) 11 11 22 55 Ampere Turns (@ 20°C) 940 938 Resistance Ref # VDC VDC VDC VDC (@20°C) Turns (Nom) (Nom) (Nom) (Nom) B14HD-L-X58-B-X 1.45 B14HD-L-X57-B-X 7.0 B14HD-L-X56-B-X 14.2 B14HD-L-X54-B-X 27.5 B14HD-L-X53-B-X 110.2 321 4.4 4.3 6.1 9.7 750 8.9 8.7 12.4 19.6 1068 12.7 12.5 17.6 27.9 1470 17.7 17.4 24.6 38.9 2920 35.4 34.8 49.2 77.8 0.2 (5.08) 0.3 (7.62) Stroke - in (mm) 0.4 (10.16) 0.5 (12.7) 16.0 (71.2) 1326 2097 Coil Data Part Number 0.1 (2.54) Typical Force @ 20°C – Flat Face (net with spring) Force - lbs (N) – Magnetic Latching ■ 10% Duty Cycle 55W ■ 25% Duty Cycle 22W ■ 50% Duty Cycle 11W 8.0 (35.6) Performance + All products are RoHS Compliant Coil Selection (from performance chart below) Force - lbs (N) LINEAR Open Frame Part Number: B14HD - L - X XX - B- X 12.0 (53.4) ■ 10% Duty Cycle 55W ■ 25% Duty Cycle 22W ■ 50% Duty Cycle 11W 8.0 (35.6) 4.0 (17.8) NOTES: 0 1. All data is typical. 2. Force testing is done with the solenoid in the horizontal position. 3. All data reflects operation with no heat sink. 0 0.05 (1.27) 0.1 (2.54) 0.15 (3.81) Stroke - in (mm) 0.2 (5.08) 0.25 (6.35) How to Order Select the part number from the table provided. (For example, to order a 25% duty cycle unit with a conical pole configuration rated at 6.1 VDC with 10" lead wires, specify B14HD-L-258-B-4. Please see www.ledex.com for our list of stock products available through our North American distributors. (Red) Coil Polarity Latch: A A+ B- Unlatch: A- B+ B (Black) All specifications subject to change without notice. Ledex® Solenoids Force values for reference only. www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624 Max. 0.5 (12.7) Ledex® Magnetic Latching Box Frame Size B14HD-L Inches (mm) Dimensions All solenoids are illustrated in energized state 2.12 ± 0.02 (53.8 ± 0.5) Lead Wire Models 6-32 Thd Typ (4) (2 Holes This Side; 2 Holes Opposite Side) 1.214 ± 0.016 (30.84 ± 0.41) Ø0.157 (4.00) Ø0.394 ± 0.003 (10.00 ± 0.08) 0.315 ± 0.008 (8.0 ± 0.20) 0.787 ± 0.008 (20.00 ± 0.20) 0.138 ± 0.005 (3.51 ± 0.13) 0.319 ± 0.010 (8.10 ± 0.25) 0.787 ± 0.008 (20.00 ± 0.20) M4 - 0.7 Thd Typ (4) (2 Holes This Side; 2 Holes Opposite Side) 0.820 ± 0.016 (20.84 ± 0.41) 10.0 (254) Min. Length to Frame 1.46 ± 0.14 (37.0 ± 3.6) B - Black 1.024 ± 0.006 (26.00 ± 0.15) A - Red 0.662 ± 0.17 (16.82 ± 0.43) Ø0.118 ± 0.002 (3.00 ± 0.05) 2.12 ± 0.02 (53.8 ± 0.5) Terminal Connection Models 6-32 Thd Typ (4) (2 Holes This Side; 2 Holes Opposite Side) 1.214 ± 0.016 (30.84 ± 0.41) Ø0.157 (4.00) Ø0.394 ± 0.003 (10.00 ± 0.08) 0.315 ± 0.008 (8.0 ± 0.20) 0.787 ± 0.008 (20.00 ± 0.20) 0.138 ± 0.005 (3.51 ± 0.13) 0.319 ± 0.010 (8.10 ± 0.25) 0.787 ± 0.008 (20.00 ± 0.20) 0.820 ± 0.016 (20.84 ± 0.41) 0.373 (9.48) Ref. to Bobin Flange M4 - 0.7 Thd Typ (4) (2 Holes This Side; 2 Holes Opposite Side) 0.020 ± 0.003 (0.51 ± 0.08) Terminal Thickness 1.46 ± 0.14 (37.0 ± 3.6) 0.24 (6.0) Max. Engagement 0.118 ± 0.010 (3.00 ± 0.25) B A 0.55 ± 0.20 (13.9 ± 5.1) 1.024 ± 0.006 (26.00 ± 0.15) 0.662 ± 0.17 (16.82 ± 0.43) Terminal Mates with DIN 46247 Ledex® Solenoids 0.110 ± 0.005 (2.79 ± 13) Ø0.118 ± 0.002 (3.00 ± 0.05) www.ledex.com 1.937.454.2345 Fax: 1.937.898.8624
B14HD-L-258-B-4 价格&库存
很抱歉,暂时无法提供与“B14HD-L-258-B-4”相匹配的价格&库存,您可以联系我们找货
