Photodiodes & -Transistors for high-volume Applications
transistors
Phototransistors
VTT Series – CR Series
FOR Industrial AND
Commercial Applications
Phototransistors – VTT Series – CR Series
Applications
• Coin counters
• Position sensors
• Remote controllers
• Ambient light sensing
• Street light switching
• Oil burner flame monitoring
• Safety shields
• Margin control-printers
• Monitor paper position and stack height
Features and Benefits
• Low cost visible and near IR photo detection
• Low dark current
• Available in package with integrated
visible filtering
IR filtering
• Available in a wide range of packages
• RoHs compliant
Product Description
Phototransistors are photodiode-amplifier combinations integrated within a single silicon chip.
The phototransistor can be viewed as a photodiode whose output current is fed into the base of a
conventional transistor.
These photodiode-amplifier combinations are put together to overcome the major limitation of
photodiodes: unity gain. The typical gain of a phototransistor can range from 100 to over 1500.
Many applications demand a greater output than can be generated by a photodiode alone. Even
though the signal of a photodiode can be amplified through external circuitry (operational
amplifier for example) this is not always cost effective. In such cases, phototransistors provide a
lower cost alternative.
Figure 1
Package Drawing – VTT Series – T-1¾ Package
CR50TE
• Surface mounting device
• Solid state ceramic chip
• High thermal conductivity
• Special type (CR50TE-DLF)
with daylight filter on request
34
www.excelitas.com
Product Table
Package
Exposed
Active
Area
Dark Current
@ VCE = 10 V
min
max
min
IC
ICED
VBR(CEO)
mm2
mA
nA
V
Symbol
Unit
Collector
Breakdown @
IC = 100 µA,
0 fc
Light Current
@ 100 fc,
VCE = 5 V
Emitter
Breakdown @
IC = 100 µA,
0 fc
Saturation
Voltage @
IC = 100 µA,
100 fc
Rise/Fall Time
IC = 1.0 mA
RL = 100 Ω
Angular
Response
min
max
Typical
Typical
VBR(CEO)
VCE(SAT)
tR / tF
Θ1/2
V
µS
⁰
λRange
V
Spectral
Range
nm
VTT1222WH
T-1 ¾
0.19
1.9
10 @ VCE = 20 V
50
6.0
0.25
2.0
±40
400 -1050
VTT1223WH
T-1 ¾
0.19
1.5
10 @ VCE = 20 V
40
6.0
0.25
3.0
±40
400 -1050
VTT1225H
T-1 ¾
0.19
4.0
100
30
5.0
0.25
1.5
±5
400 -1050
VTT1226H
T-1 ¾
0.19
7.5
100
30
5.0
0.25
3.0
±5
400 -1050
VTT1227H
T-1 ¾
0.19
12.0
100
30
5.0
0.25
4.0
±5
400 -1050
VTT3122EH
Coax hermetic
0.19
1.2
100 @ VCE = 20 V
40
6.0
0.25
2.5
±8
400 -1050
VTT3123EH
Coax hermetic
0.19
4.0
100
30
4.0
0.25
4.0
±8
400 -1050
VTT3323LAH
Long T-1
0.19
2.0 @ 20 fc
100
30
5.0
0.25
3.0
±10
400 -1050
VTT3324LAH
Long T-1
0.19
4.0 @ 20 fc
100
30
5.0
0.25
4.0
±10
400 -1050
VTT3325LAH
Long T-1
0.19
6.0 @ 20 fc
100
30
5.0
0.25
5.0
±10
400 -1050
VTT3423LAH
Long T-1
0.19
1.0 @ 20 fc
100
30
5.0
0.25
3.0
±10
700 -1050
VTT3424LAH
Long T-1
0.19
2.0 @ 20 fc
100
30
5.0
0.25
4.0
±10
700 -1050
VTT3425LAH
Long T-1
0.19
3.0 @ 20 fc
100
30
5.0
0.25
5.0
±10
700 -1050
VTT7122H
Lateral
0.19
1.0
100
30
5.0
0.25
2.0
±36
400 -1050
VTT7123H
Lateral
0.19
2.0
100
30
5.0
0.25
2.0
±36
400 -1050
VTT7125H
Lateral
0.19
4.5
100
30
5.0
0.25
2.0
±36
400 -1050
VTT7222H
Lateral
0.19
0.9
100
30
5.0
0.25
2.0
±36
700 -1050
VTT7223H
Lateral
0.19
1.8
100
30
5.0
0.25
2.0
±36
700 -1050
VTT7225H
Lateral
0.19
4.0
100
30
5.0
0.25
4.0
±36
700 -1050
VTT1212H
T-1 ¾
0.63
2.0 @ 20 fc
100
30
5.0
0.25
4.0
±10
400 -1050
VTT1214H
T-1 ¾
0.63
4.0 @ 20 fc
100
30
5.0
0.25
6.0
±10
400 -1050
VTT9002H
TO-106 flat
0.63
2.0
100
30
6.0
0.55
4.0
±50
400 -1050
VTT9003H
TO-106 flat
0.63
5.0
100
30
6.0
0.55
6.0
±50
400 -1050
VTT9102H
TO-106 lensed
0.63
6.0
100 @ VCE = 5 V
30
4.0
0.55
6.0
±42
400 -1050
VTT9103H
TO-106 lensed
0.63
13.0
100 @ VCE = 5 V
30
4.0
0.55
10.0
±42
400 -1050
VTT1015H
TO-46
0.4
25 @ VCE = 20 V
40
6.0
0.40
5.0
±35
400 -1050
VTT1016H
TO-46
1.0
25 @VCE = 20 V
30
6.0
0.40
5.0
±35
400 -1050
VTT1017H
TO-46
2.5
25
0.40
8.0
±35
400 -1050
VTT1115H
TO-46 lensed
1.0 @ 20 fc
100
30
6.0
0.40
5.0
±15
400 -1050
VTT1116H
TO-46 lensed
2.0 @ 20 fc
100
30
4.0
0.40
8.0
±15
400 -1050
VTT1117H
TO-46 lensed
4.0 @ 20 fc
100
30
4.0
0.40
8.0
±15
400 -1050
VTT9812FH
T-1 ¾ flat
0.19
0.10
100
30
5.0
0.25
1.5
±56
450 - 700
CR50TE
Ceramic
SMD (A2)
0.18
400 @ VCE = 20 V
40
0.3 @ IC= 2 mA
4.0 @ RL = 50 Ω
Wide viewing
angle
400 -1070
Figure 2
Figure 3
Package Drawing – VTT Series – T-1 Package
Package Drawing – VTT Series – TO-46 Package
www.excelitas.com
35
Graph 1
Graph 2
Rel. Spectral Response (Referred to Peak Response of Clear Case)
Relative Output vs. Illumination (Normalized at 100 fc)
Relative Output (%)
Relative Output
100
10
80
1
60
0.1
40
0.01
400
500
600
700
800
900
1000
1100
1
10
100
Wavelength (nm)
1000
Illumination, fc (2850K)
–– Clear Case –– Black Epoxy IR Transmitting Case
Graph 3
Graph 4
Angular Response Coax Packages
Angular Response Molded Epoxy Packages
Relative Output (%)
Relative Output (%)
100
100
80
80
60
60
40
40
-60
-30
60
90
-90
Angle of Optical Axis
-60
-30
60
90
–– VTT122XW, VTT712X, VTT722X –– VTT121X, VTT332XLA, VTT342XLA –– VTT122X
–– VTT312XE
Graph 5
Graph 6
Angular Response Ceramic Packages
Angular Response 10–46 Packages
Relative Output (%)
100
100
80
80
60
60
40
40
-60
-30
60
90
-90
-60
–– VTT900X –– VTT910X
36
-30
60
90
–– VTT101X –– VTT111X
www.excelitas.com
很抱歉,暂时无法提供与“VTT3323LAH”相匹配的价格&库存,您可以联系我们找货
