HR-4UTCEX(4B)
HR-4UTCEX(4B)
    FDK
    FUJITSU AAA SIZE MIN. 750MAH 4PC
HR-4UTCEX(4B) 数据手册
Cell Type HR-4UTC Specifications Type : Nickel-Metal Hydride Battery Size : AAA Consumer Type Typical 800mAh Minimum 750mAh Capacity 1) 10.50 mm Nominal Voltage 1.2V Charging Current x Time 44.5 mm 800mA × 1.1h Fast Charge 2) Charge Fast Charge 2) Condition 0°C - 40°C Discharge Condition 0°C - 50°C Ambient Temp. Less than Storage 90days Condition Less than 1year -20°C - 40°C -20°C - 30°C Internal Impedance 3) (after discharge to E.V.=1.0V) Approx. 40mΩ (at 1000Hz) Weight 4) Approx.13g Size 4) :(Diameter) x (Height) Dimensions (with tube) D 10.50 mm H 44.5 mm 10.5(D) x 44.5(H) mm 1)Single cell capacity under the following condition. Charge : 80mA×16h, Discharge : 160mA(E.V.=1.0V) at 25°C 2)Use recommended charging system. 3)After a few charge and discharge cycles under the above 1) condition. 4)With tube. Typical Characteristics Charge Discharge 1.6 1.8 0ºC Charge : 800 mA (-DV=10mV) Rest : 1h Discharge : 160mA,800mA,1600mA (E.V.=1.0V) 1.5 25ºC 1.6 Cell Voltage (V) Cell Voltage (V) 1.7 40ºC 1.5 1.4 1.3 1.2 Charge : 800mA (-DV=10mV) Ambient Temp. : 0ºC, 25ºC, 40ºC 1.1 10 20 30 40 50 Charge Time (min) 60 1.3 1.2 1.1 160mA 800mA 1.0 1.0 0 1.4 70 1600mA 0.9 0 200 400 600 800 1000 Discharge Capacity (mAh) 2018/1
HR-4UTCEX(4B) 价格&库存
很抱歉,暂时无法提供与“HR-4UTCEX(4B)”相匹配的价格&库存,您可以联系我们找货
