AR1086CHTSST
AR1086CHTSST
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 灰色,透明外盖/门 铰链式门,盖 11.100" 长 x 8.980" 宽(281.94mm x 228.09mm) X 6.710"(170.43mm)
AR1086CHTSST 数据手册
AR1086CHTSST Order symbol: AR1086CHTSST Product nbr: 8561058 Description: PC Enclosure Remarks: Hinged transparent cover w/S.S. Lockable twist latch EAN: 6418074067128 El. number: • • • Finland: Denmark: Sweden: Including: Hinged cover. Base with 10-32 brass inserts, latched cover with formed in place PUR gasket, stainless hinge pin. Quick release latches. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample image Dimensions: Height Width Depth Accessories: mm: 254 203 152 ASPHK10 Swing Panel Kit w/o Panel inch: 10 8 6 ABP108 Painted Steel Back Panel Materials: (226 x 175) Material: Polycarbonate ADFP108 Dead Front Panel w/ screws (208 x 256 x 0) Base colour: RAL 7035 -light grey Cover colour: Transparent ASP108 Aluminum Swing Panel (204.5 x 255 x 0) Gasket material: Polyurethane ASPK108 Swing Panel Kit incl. Panel ALBP108 Aluminum Back Panel (226 x 175) AMFL8 8" Mounting Flange Set APBP108 PVC Back Panel (226 x 175) Temperatures: Temperature °C (short term):: -40 … 140 Temperature °C (continuous): -40 … 80 Temperature °F (short term): -40 … 250 Temperature °F (continuous): -40 … 175 Rating: Ingress protection (EN 60529): IP66; IP67; Impact Resistance (EN 62262): IK09; Electrical insulation: Not insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 508 Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class NEMA 4, 4X, 6, 6P, 12, 12K and 13 Certificates: ARCA_CertificateofCompliance © Fibox Oy, Data subject to change without notice (printed: 20.07.2022)
AR1086CHTSST 价格&库存
很抱歉,暂时无法提供与“AR1086CHTSST”相匹配的价格&库存,您可以联系我们找货
