AR884CHSST
AR884CHSST
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 浅灰色 铰链式门,盖 9.110" 长 x 8.980" 宽(231.39mm x 228.09mm) X 4.900"(124.46mm)
AR884CHSST 数据手册
AR884CHSST Order symbol: AR884CHSST Product nbr: 8561095 Description: PC Enclosure Remarks: Hinged transparent cover w/S.S. Quick release latch EAN: 6418074067340 El. number: • • • Sample image Finland: Denmark: Sweden: Including: Hinged cover. Base with 10-32 brass inserts, latched cover with formed in place PUR gasket, stainless hinge pin. Quick release latches. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. ARCA-8x8_combi Dimensions: Height Width Depth mm: 203 203 102 inch: 8 8 4 Materials: Material: Polycarbonate Base colour: RAL 7035 -light grey Cover colour: Transparent Gasket material: Polyurethane Temperatures: Accessories: ALBP88 Aluminum Back Panel (175 x 175) ABP88 Painted Steel Back Panel (175 x175) ASP88 Aluminum Swing Panel (204.4 x 204.5 x 0) ASPHK8 Swing Panel Kit w/o Panel APBP88 PVC Back Panel (175 x 175) ADFP88 Dead Front Panel w/ screws (175 x 175 x 0) ASPK88 Swing Panel Kit incl. Panel AMFL8 8" Mounting Flange Set Temperature °C (short term):: -40 … 140 Temperature °C (continuous): -40 … 80 Rating: Temperature °F (short term): -40 … 250 Ingress protection (EN 60529): IP66; IP67; Temperature °F (continuous): -40 … 175 Impact Resistance (EN 62262): IK09; Electrical insulation: Not insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 508 Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class Certificates: ARCA_CertificateofCompliance © Fibox Oy, Data subject to change without notice (printed: 20.07.2022) NEMA 4, 4X, 6, 6P, 12, 12K and 13
AR884CHSST 价格&库存
很抱歉,暂时无法提供与“AR884CHSST”相匹配的价格&库存,您可以联系我们找货
