FTLF1428P3BNV
FTLF1428P3BNV
    II-VI
    收发器模块 光纤通道链路 8.5Gbps 1310nm 3.3V LC 双工 可插入式,SFP+
FTLF1428P3BNV 数据手册
Product Specification 8 Gigabit RoHS Compliant Long-Wavelength SFP+ Transceiver FTLF1428P3BNV PRODUCT FEATURES • Up to 8.5 Gb/s bi-directional data links • Hot-pluggable SFP+ footprint • Built-in digital diagnostic functions • 1310nm DFB laser transmitter • Duplex LC connector • RoHS compliant and Lead Free • Up to 10 km on 9/125µm SMF • Metal enclosure, for lower EMI • Single 3.3V power supply • Extended operating temperature range: -5°C to 85°C APPLICATIONS • Tri Rate 2.125 / 4.25 / 8.5 Gb/s Fibre Channel through Rate Select Finisar’s FTLF1428P3BNV SFP+ transceivers are designed for use in Fibre Channel links up to 8.5 Gb/s data rate and up to 10 km link length. They are compliant with FCPI-4 Rev. 8.001 and SFF-8472 Rev 10.33, and compatible with SFF-84322 and applicable portions of SFF-8431 Rev. 3.04. The optical transceiver is compliant per the RoHS Directive 2011/65/EU5. See Finisar Application Note AN-2038 for more details6. PRODUCT SELECTION FTLF1428P3BNV  Finisar Corporation August 2015 Rev. B1 Page 1 FTLF1428P3BNV Product Specification I. Pin Descriptions Pin 1 2 3 4 5 6 7 Symbol V EET T FAULT T DIS SDA SCA MOD_ABS RS0 8 9 LOS RS1 10 11 12 13 14 15 16 17 18 19 20 V EER V EER RDRD+ V EER V CCR V CCT V EET TD+ TDV EET Name/Description Transmitter Ground (Common with Receiver Ground) Transmitter Fault. Transmitter Disable. Laser output disabled on high or open. 2-wire Serial Interface Data Line (MOD-DEF2) 2-wire Serial Interface Clock (MOD-DEF1) Module Absent, connected to V EET or V EER Rx Rate Select: Open or Low = 2.125 or 4.25 Gb/s Fibre Channel (Low Bandwidth) High = 8.5 Gb/s Fibre Channel (High Bandwidth) Loss of Signal indication. Logic 0 indicates normal operation. Tx Rate Select: Open or Low = 2.125 or 4.25 Gb/s Fibre Channel (Low Bandwidth) High = 8.5 Gb/s Fibre Channel (High Bandwidth) Receiver Ground (Common with Transmitter Ground) Receiver Ground (Common with Transmitter Ground) Receiver Inverted DATA out. AC Coupled Receiver Non-inverted DATA out. AC Coupled Receiver Ground (Common with Transmitter Ground) Receiver Power Supply Transmitter Power Supply Transmitter Ground (Common with Receiver Ground) Transmitter Non-Inverted DATA in. AC Coupled. Transmitter Inverted DATA in. AC Coupled. Transmitter Ground (Common with Receiver Ground) Ref. 1 2 3 4 4 4 5 6 5 1 1 1 1 1 Notes: 1. Circuit ground is internally isolated from chassis ground. 2. T FAULT is an open collector/drain output, which should be pulled up with a 4.7k – 10k Ohms resistor on the host board if intended for use. Pull up voltage should be between 2.0V to Vcc + 0.3V. A high output indicates a transmitter fault caused by either the TX bias current or the TX output power exceeding the preset alarm thresholds. A low output indicates normal operation. In the low state, the output is pulled to 2.0V or open, enabled on T DIS
FTLF1428P3BNV 价格&库存
很抱歉,暂时无法提供与“FTLF1428P3BNV”相匹配的价格&库存,您可以联系我们找货
