FTLF8529P5BCV
FTLF8529P5BCV
    COHERENT
    收发器模块 光纤通道链路 14.025Gbps 850nm 3.15V ~ 3.46V LC 双工 可插入式,SFP+
FTLF8529P5BCV 数据手册
Finisar® Transceiver Product Specification 16G Fibre Channel Short Wavelength SFP+ Transceiver FTLF8529P5xyV PRODUCT FEATURES • Up to 14.025 Gb/s bi-directional data links • Hot-pluggable SFP+ footprint • Built-in digital diagnostic functions • 850nm Oxide VCSEL laser transmitter • Duplex LC connector • Bail latch or pull tab • RoHS compliant • 35m on 50/125m MMF • 100m over M5E MMF (50/125um OM3) • Metal enclosure, for lower EMI • Single 3.3V power supply • Operating temperature range: APPLICATIONS C-temp: 0°C to 70°C ▪ E-temp: 0°C to 85°C Tri-Rate 4.25/8.5/14.025 Gb/s Fibre Channel Finisar® FTLF8529P5xyV SFP+ transceivers are designed for use in Fibre Channel links up to 14.025 Gb/s data rate over multimode fiber. They are compliant with FC-PI-5 Rev. 6.00a, SFF-8472 Rev 11.0c and SFF-8081h, and compatible with SFF-8432b and applicable portions of SFF-8431 Rev. 4.1d. The transceiver is RoHS compliant as described in Application Note AN-2038. PRODUCT SELECTION FTLF8529P5xyV x=B: Bail latch x=P: Pull tab y=C: C-temp (0°C to 70°C) y=N: E-temp (0°C to 85°C) © II-VI Incorporated – December 2020 Rev A0 II-VI Confidential Page 1 Finisar® Transceiver FTLF8532P5xyV Product Specification I. Pin Descriptions Pin Symbol 1 2 3 4 5 6 7 VEET TFAULT TDIS SDA SCA MOD_ABS RS0 8 9 LOS RS1 10 11 12 13 14 15 16 17 18 19 20 VEER VEER RDRD+ VEER VCCR VCCT VEET TD+ TDVEET Name/Description Transmitter Ground (Common with Receiver Ground) Transmitter Fault. Transmitter Disable. Laser output disabled on high or open. 2-wire Serial Interface Data Line (MOD-DEF2) 2-wire Serial Interface Clock (MOD-DEF1) Module Absent, connected to VEET or VEER Rx Rate Select: Open or Low = 8.5 or 4.25 Gb/s Fibre Channel (Low Bandwidth) High = 14.025 Gb/s Fibre Channel (High Bandwidth) Loss of Signal indication. Logic 0 indicates normal operation. Tx Rate Select: Open or Low = 8.5 or 4.25 Gb/s Fibre Channel (Low Bandwidth) High = 14.025 Gb/s Fibre Channel (High Bandwidth) Receiver Ground (Common with Transmitter Ground) Receiver Ground (Common with Transmitter Ground) Receiver Inverted DATA out. AC Coupled Receiver Non-inverted DATA out. AC Coupled Receiver Ground (Common with Transmitter Ground) Receiver Power Supply Transmitter Power Supply Transmitter Ground (Common with Receiver Ground) Transmitter Non-Inverted DATA in. AC Coupled. Transmitter Inverted DATA in. AC Coupled. Transmitter Ground (Common with Receiver Ground) Re f. 1 2 3 4 4 4 5 6 5 1 1 1 1 1 Notes: 1. Circuit ground is internally isolated from chassis ground. 2. TFAULT is an open collector/drain output, which should be pulled up with a 4.7k – 10k Ohms resistor on the host board if intended for use. Pull up voltage should be between 2.0V to Vcc + 0.3V. A high output indicates a transmitter fault caused by either the TX bias current or the TX output power exceeding the preset alarm thresholds. A low output indicates normal operation. In the low state, the output is pulled to 2.0V or open, enabled on TDIS
FTLF8529P5BCV 价格&库存
很抱歉,暂时无法提供与“FTLF8529P5BCV”相匹配的价格&库存,您可以联系我们找货
