FTLX1374D3BCL
FTLX1374D3BCL
    II-VI
    OPT TXRX 1310NM 10GB SFP+ LC
FTLX1374D3BCL 数据手册
Preliminary Product Specification RoHS-6 Compliant 10Gb/s 1km Single Mode Datacom SFP+ Transceiver FTLX1374D3BCL PRODUCT FEATURES • Hot-pluggable SFP+ footprint • Supports 10.3Gb/s bit rate • Power dissipation < 1W • RoHS-6 compliant (lead-free) • Data Center temperature range 15°C to 55°C • Single 3.3V power supply • Maximum link length of 1km • 4 dB link budget • Receiver limiting electrical interface • Duplex LC connector • Built-in digital diagnostic functions APPLICATIONS • Data Center 10G Ethernet Finisar’s FTLX1374D3BCL 10Gb/s Enhanced Small Form Factor Pluggable SFP+ transceivers are designed for use in 10-Gigabit Ethernet links up to 1km over Single Mode fiber. The electrical interface is SFI compliant per SFF-84311, and is compliant to SFF-84322. Digital diagnostics functions are available via a 2-wire serial interface, as specified in SFF-84723. The FTLX1374D3BCL is a “limiting module”, i.e., it employs a limiting receiver. Host board designers using an EDC PHY IC should follow the IC manufacturer’s recommended settings for interoperating the host-board EDC PHY with a limiting receiver SFP+ module. The transceiver is RoHS compliant and lead free per Directive 2011/65/EC4, and Finisar Application Note AN-20385. PRODUCT SELECTION FTLX1374D3BCL  Finisar Corporation - March 2015 Rev. B Page 1 FTLX1374D3BCL Datacom SFP+ Product Specification – March 2015 I. Pin Descriptions Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Symbol VEET TFAULT TDIS SDA SCL MOD_ABS RS0 RX_LOS RS1 VEER VEER RDRD+ VEER VCCR VCCT VEET TD+ TDVEET Name/Description Transmitter Ground Transmitter Fault Transmitter Disable. Laser output disabled on high or open. 2-wire Serial Interface Data Line 2-wire Serial Interface Clock Line Module Absent. Grounded within the module Rate Select 0. Not Used. Loss of Signal indication. Logic 0 indicates normal operation. Rate Select 1. Not Used. Receiver Ground Receiver Ground Receiver Inverted DATA out. AC Coupled. Receiver Non-inverted DATA out. AC Coupled. Receiver Ground Receiver Power Supply Transmitter Power Supply Transmitter Ground Transmitter Non-Inverted DATA in. AC Coupled. Transmitter Inverted DATA in. AC Coupled. Transmitter Ground Ref. 1 2 3 2 2 2 4 5 4 1 1 1 1 1 Notes: 1. Circuit ground is internally isolated from chassis ground. is an open collector/drain output, which should be pulled up with a 4.7k – 10k Ohms resistor on 2. T FAULT 3. 4. 5. the host board if intended for use. Pull up voltage should be between 2.0V to Vcc + 0.3V. A high output indicates a transmitter fault caused by either the TX bias current or the TX output power exceeding the preset alarm thresholds. A low output indicates normal operation. In the low state, the output is pulled to 2.0V or open, enabled on TDIS
FTLX1374D3BCL 价格&库存
很抱歉,暂时无法提供与“FTLX1374D3BCL”相匹配的价格&库存,您可以联系我们找货
