FTLX1370W4BTL
FTLX1370W4BTL
    II-VI
    收发器模块 以太网,光纤通道 10Gbps 1310nm 3.3V LC 双工 可插入式,SFP+
FTLX1370W4BTL 数据手册
Preliminary Product Specification 9.8304 Gigabit RoHS Compliant Long-Wavelength SFP+ Transceiver FTLX1370W4BTL PRODUCT FEATURES  Up to 9.8304 Gb/s bi-directional data links  Hot-pluggable SFP+ footprint  Built-in digital diagnostic functions  Duplex LC connector  RoHS compliant and Lead Free  Up to 1.4 km at 9.8304 Gb/s on 9/125m SMF  Metal enclosure, for lower EMI  2.457 Gb/s CPRI  Single 3.3V power supply  3.072 Gb/s CPRI/LTE  Industrial operating temperature range: -40°C to 85°C  4.915 Gb/s CPRI/LTE  6.144 Gb/s CPRI/OBSAI/LTE  9.8304 Gb/s CPRI/LTE  1 Watt Maximum Power Consumption APPLICATIONS Finisar’s FTLX1370W4BTL SFP+ transceivers are designed for use in Wireless basestation links up to 1.4 km at up to 9.8304 Gb/s data rates for CPRI, OBSAI, LTE, or other Wireless applications. They are compliant with SFF-84311, SFF-84322, SFF-8472 Rev 10.23, CPRI Rev 5.06, and OBSAI Rev V4.27. The optical transceiver is compliant per the RoHS Directive 2011/65/EU. See Finisar Application Note AN-2038 for more details. PRODUCT SELECTION FTLX1370W4BTL  Finisar Corporation - 25-Aug-2015 Rev A1 Page 1 FTLX1370W4BTL Preliminary Product Specification I. Pin Descriptions Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Symbol VEET TFAULT TDIS SDA SCL MOD_ABS RS0 RX_LOS RS1 VEER VEER RDRD+ VEER VCCR VCCT VEET TD+ TDVEET Name/Description Transmitter Ground Transmitter Fault Transmitter Disable. Laser output disabled on high or open. 2-wire Serial Interface Data Line 2-wire Serial Interface Clock Line Module Absent. Grounded within the module Rate Select 0. Not Used. Loss of Signal indication. Logic 0 indicates normal operation. Rate Select 1. Not Used. Receiver Ground Receiver Ground Receiver Inverted DATA out. AC Coupled. Receiver Non-inverted DATA out. AC Coupled. Receiver Ground Receiver Power Supply Transmitter Power Supply Transmitter Ground Transmitter Non-Inverted DATA in. AC Coupled. Transmitter Inverted DATA in. AC Coupled. Transmitter Ground Ref. 1 2 3 2 2 2 4 5 4 1 1 1 1 1 Notes: 1. Circuit ground is internally isolated from chassis ground. 2. T is an open collector/drain output, which should be pulled up with a 4.7k – 10k Ohms resistor on FAULT 3. 4. 5. the host board if intended for use. Pull up voltage should be between 2.0V to Vcc + 0.3V. A high output indicates a transmitter fault caused by either the TX bias current or the TX output power exceeding the preset alarm thresholds. A low output indicates normal operation. In the low state, the output is pulled to 2.0V or open, enabled on TDIS
FTLX1370W4BTL 价格&库存
很抱歉,暂时无法提供与“FTLX1370W4BTL”相匹配的价格&库存,您可以联系我们找货
