V23818-S5-N1
V23818-S5-N1
    II-VI
    ACCESSORY SFP/SFP+ CAGE PLUG
V23818-S5-N1 数据手册
Product Specification Fiber Optics Cage for Small Form Factor Pluggable (SFP) Transceiver V23818-S5-N1 V23818-S5-N1-BB PRODUCT FEATURES ƒ Supports MSA compliant host board layouts and transceiver designs ƒ One-piece, rigid stainless steel construction with tin-lead plating ƒ Simple and fast installation/removal ƒ Solid retention strength ƒ Easily press fit onto host board via teardrop foot design ƒ Testing of rear connector may take place before SFP Cage is installed onto host board ƒ Low emission design via fold-back spring fingers – no openings for radiation to pass through ƒ Enhanced transceiver kick-out and retention springs ƒ Heat transfer windows on all SFP Cage surfaces ƒ Cage can be press fit and/or soldered DESCRIPTION Finisar is offering its Cage for Small Form Factor Pluggable (SFP) transceivers with the most rigid mechanical design available on the market. The Cage is designed for press fit applications in order to reduce high volume manufacturing effort. Press fit pins can be also soldered if required. Externally bent bezel contact springs and one-piece construction enhance EMI performance. As part of Finisar's Total Transceiver Solution, the SFP Cage is your logical choice for next generation pluggable transceivers. Part Number Description V23818-S5-N1 For single-sided mounting V23818-S5-N1-BB For double-sided "belly to belly" mounting (see Figure3) © Finisar Corporation 2002-10-07 DSO 1 V23818-S5-N1, V23818-S5-N1-BB Product Specification – 2002-10-07 APPLICATION NOTES ƒ ƒ ƒ ƒ ƒ ƒ ƒ For single-sided mounting, optimum host board thickness is .059to.062in [1.5to1.57mm]. SFP Cage mounting holes should be plated with HASL, gold, or immersion silver finish per MSA dimensional recommendations For double-sided mounting, host board thickness is .118in [3.0mm] minimum per the MSA. For belly-to-belly applications, one of the rear mounting feet is removed to avoid interference (V23818-S5-N1-BB) Installation of the SFP Cage may be done by hand or with a solid metal block across the top surface of the Cage. Block dimensions to be controlled by customer Removal of the Cage should be done with an internal solid metal block. Due to the collapsing nature of the teardrop foot design, the Finisar SFP Cage is intended for one-time installation The Finisar SFP Cage does not cause any damage when carefully removed; the outside profile of the teardrop feet is smooth and will not destroy pre-plated host board mounting holes Trapped fluids from washing process must be dried to prevent corrosion beneath SFP Cage Cage retention depends on finished hole size and plating thickness SYSTEM CONFIGURATIONS ƒ ƒ ƒ Single-sided mounting with .640in [16.25mm] pitch Double-sided "belly to belly" mounting with .640in [16.25mm] pitch Double-sided "offset belly to belly" mounting with .975in [24.77mm] pitch © Finisar Corporation 2002-10-07 DSO 2 V23818-S5-N1, V23818-S5-N1-BB Product Specification – 2002-10-07 Figure 1 Single-sided Host Board Layout Figure 2 Single-sided Layout © Finisar Corporation 2002-10-07 DSO 3 V23818-S5-N1, V23818-S5-N1-BB Product Specification – 2002-10-07 Figure 3 © Finisar Corporation 2002-10-07 DSO 4 V23818-S5-N1, V23818-S5-N1-BB Product Specification – 2002-10-07 Single-sided Application Figure 4 Figure 5 © Finisar Corporation 2002-10-07 DSO 5 V23818-S5-N1, V23818-S5-N1-BB Product Specification – 2002-10-07 Belly to Belly Application Figure 6 Figure 7 © Finisar Corporation 2002-10-07 DSO 6 V23818-S5-N1, V23818-S5-N1-BB Product Specification – 2002-10-07 Package Outlines Figure 8 © Finisar Corporation 2002-10-07 DSO 7 V23818-S5-N1, V23818-S5-N1-BB Product Specification – 2002-10-07 Revision History: 2002-10-07 DSO Previous Version: Page Subjects (major changes since last revision) Company’s name has been changed Document’s layout has been changed 2002-10-07 For More Information Finisar Corporation 1389 Moffett Park Drive Sunnyvale, CA 94089-1133 Tel. 1-408-548-1000 Fax 1-408-541-6138 sales@finisar.com www.finisar.com © Finisar Corporation 2002-10-07 DSO 8
V23818-S5-N1 价格&库存
很抱歉,暂时无法提供与“V23818-S5-N1”相匹配的价格&库存,您可以联系我们找货
