PRODUCT BRIEF
Pluggable XFP-RF Transmitter
Key Features
for Hybrid Fiber Coaxial (HFC) Applications
DOCSIS 3.1 compatible: AllDigital QAM loading from
50 MHz to 1.2 GHz
Wavelength can be tuned across
the entire C-band at 100GHz ITU
DWDM spacings
Packaged in standard XFP
pluggable optical module
Built-in digital diagnostic
functions
Link distance up to 60
Wavelength tunable, 1.2 GHz pluggable
optical transmitter module
Overview
Finisar’s XFP-RF transmitter is a small form factor hot-pluggable optical module
that is compliant with interface specifications developed by the Society of Cable
Telecommunications Engineers (SCTE). It can be fully loaded with digital QAM channels
from 50 MHz to 1218 MHz to enable cable operators to more effectively segment their
serving groups and offer more services to their subscribers. The small XFP module
kilometers without any
significantly reduces power consumption and increases density for downstream
dispersion compensation
transmitters. These modules can be integrated into today’s Hybrid-Fiber Coaxial (HFC)
LC Angled-Physical Contact
optical broadband platforms and tomorrow’s converged access platforms (CCAP).
(APC) optical connection for
The transmitter wavelength can be tuned up to any of the 43 different Dense Wavelength
low reflection
Division Multiplexing (DWDM) wavelengths across the entire C-band in 500 ms. This
Low power consumption
increases operational efficiencies in deploying DWDM networks and reduces inventory of
Compliant with SCTE 195 2013:
transmitters at different fixed wavelengths. Wavelength tunability also opens the possibility
Interface Specifications for an
of novel HFC architectures that can dynamically route services and increase bandwidth
RF-Modulated Small Form Factor
capacity in the cable operator’s access network.
Pluggable Optical Module
Mechanical dimensions
Key Advantages
compliant with 10 Gigabit Small
2x to 4x density improvement over current transmitter solutions
Form Factor Pluggable Module
At least 50% less power consumption per transmitter
(XFP) Multi-Source Agreement
Enables future HFC architectures to route services dynamically by changing the
(INF-8077i, Rev. 4.5)
Applications
1550nm Broadcast with DWDM
Narrowcast Overlay architectures
All-Digital QAM networks
RF-over-Glass (RFoG)
wavelength of the transmitter
Enables pluggable optics to be utilized directly in next-generation Cable Modem
Termination Systems and QAM modulators
Pluggable XFP-RF HFC Transmitter
Specifications
Parameter
Value
Optical Output Power
+5 dBm or +6 dBm minimum (see product selection table below)
Optical Wavelengths
ITU DWDM Channels 18 to 60 (1528.77 nm to 1529.55 nm)
Center Wavelength Spacing
100 GHz
Wavelength Tuning Time
0.5 seconds typical
Optical Connection
LC/APC receptacle (angled physical contact)
Optical Fiber Distance
0 km to 60 km
Fiber Dispersion Compensation, Internal
or External
Not applicable
SBS Suppression
+13 dBm typical (higher SBS suppression available)
41 dB, Minimum (64 channels of 256 QAM, link distance of 50km)
Modulation Error Ratio (MER)
37 dB, Minimum (154 channels of 256 QAM, link distance of 50km)
RF Bandwidth
50 MHz to 1218 MHz
RF Input Level
Dependent on host module (+3 dBm composite typical into XFP-RF)
RF Impedance
Dependent on host module (100 Ω differential into XFP-RF)
1.0 dB max, peak to peak, 50 MHz to 1003 MHz
RF Flatness
1.5 dB max, peak to peak, 50 MHz to 1218 MHz
16 dB min, 52 MHz to 1218 MHz
RF Input Return Loss
78 mm (L ) X 18.35 mm (W) X 8.5 mm (H)
Dimensions
3.0 in (L) X 0.7 in (W) X 0.3 in (H)
Mounting
XFP cage assembly on host module
Operating Temperature Range
0˚C to 70˚C
Storage Temperature Range
-40˚C to 85˚C
Power Consumption
3 Watts typical
Data/Control
Digital diagnostic functions via two-wire serial interface
Product Selection
Part Number
Output Power
Wavelength Control
Wavelength Range
XT05AAQTENJD1860
+ 5 dBm
Wavelength-Tunable
43 channels from ITU 18 to 60
XT05AAQ5ENJDxxx
+ 5 dBm
Fixed Wavelength
Single-channel between ITU 18 to 60
XT06AAQTENJD2035
+ 6 dBm
Wavelength-Tunable
16 channels from ITU 20 to 35
XT06AAQ5ENJDxxx
+ 6 dBm
Fixed Wavelength
Single-channel between ITU 20 to 35
xxx – fixed wavelength designated with ITU DWDM channel number (e.g. "210" for ITU channel 21)
1389 Moffett Park Drive
Sunnyvale, CA 94089-1133
www.finisar.com
Phone: +1-408-548-1000
Sales: +1-408-541-5690
Email: sales@finisar.com
© 2015 Finisar Corporation. All rights reserved. Finisar is a registered trademark of Finisar Corporation. Features and specifications are subject to change without notice. 09/15
Visit Our Website
很抱歉,暂时无法提供与“XT06AAQ5ENJD220”相匹配的价格&库存,您可以联系我们找货
