64501-0302
    FLIR(菲力尔)
    FLIR E60 IR CAMERA W/MSX 320 X 2
64501-0302 数据手册
FLIR E60 (incl. Wi-Fi) P/N: 64501-0302 Copyright © 2014, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: 64501-0302 Release: Commit: 15419 Language: en-US Modified: 2014-06-19 Formatted: 2014-06-22 Corporate Headquarters FLIR Systems, Inc. 27700 SW Parkway Ave. Wilsonville, OR 97070 USA Telephone: +1-503-498-3547 Website http://www.flir.com Customer support http://support.flir.com Disclaimer Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. General description The FLIR Exx-Series is a compact and rugged infrared camera that can be used in harsh environments while still providing you with the latest technology such as a modern touchscreen and wireless connectivity. The Exx-Series is the perfect choice when you are looking for a robust but feature-rich camera at an affordable price. Benefits: • • • Robust and sophisticated: The Exx-Series has a robust and light-weight design and can withstand a 2 meter drop. Big buttons combined with a modern touch screen and broad measuring capabilities, it is the right choice for demanding inspections in the field. Easy communication: The Wi-Fi connectivity of the FLIR Exx allows you to connect to smart phones and tablet PCs, for the wireless transfer of images or remote control of the camera. The Bluetooth-based MeterLink® function transfers readings from external measurement instruments to the infrared image. Best value for money: The FLIR Exx-Series combines good performance (up to 320 × 240 pixels), a user-friendly interface, and a rugged point-and-shoot design with an affordable price. Imaging and optical data 1 (10) IR resolution 320 × 240 pixels Thermal sensitivity/NETD < 0.05°C @ +30°C (+86°F) / 50 mK www.flir.com FLIR E60 (incl. Wi-Fi) P/N: 64501-0302 Imaging and optical data © 2014, FLIR Systems, Inc. Field of view (FOV) 25° × 19° Minimum focus distance 0.4 m (1.31 ft.) Focal length 18 mm (0.7 in.) Spatial resolution (IFOV) 1.36 mrad #64501-0302; r. -/15419; en-US F-number 1.3 Image frequency 60 Hz Focus Manual Digital zoom 2× and 4× Panning Panning over zoomed-in images Detector data Detector type Focal plane array (FPA), uncooled microbolometer Spectral range 7.5–13 µm Image presentation Display Touch screen, 3.5 in. LCD, 320 × 240 pixels Image adjustment Auto or manual Image presentation modes Image modes IR image, visual image, MSX, picture in picture, thumbnail gallery Picture in Picture Scalable IR area on visual image Measurement Object temperature range –20°C to +120°C (–4°F to +248°F) 0°C to +650°C (+32°F to +1202°F) Accuracy ±2°C (±3.6°F) or ±2% of reading, for ambient temperature 10°C to 35°C (+50°F to 95°F) Measurement analysis 2 (10) Spotmeter 3 Area 3 boxes with max./min./average Automatic hot/cold detection Auto hot or cold spotmeter markers within area Difference temperature Delta temperature between measurement functions or reference temperature Reference temperature Manually set or captured from any measurement function Emissivity correction Variable from 0.01 to 1.0 or selected from materials list External optics/windows correction Automatic, based on inputs of optics/window transmission and temperature Measurement corrections Reflected temperature, optics transmission and atmospheric transmission www.flir.com FLIR E60 (incl. Wi-Fi) P/N: 64501-0302 Set-up © 2014, FLIR Systems, Inc. Color palettes Arctic, Gray, Iron, Lava, Rainbow and Rainbow HC Set-up commands Local adaptation of units, language, date and time formats #64501-0302; r. -/15419; en-US Storage of images Image storage Standard JPEG, including measurement data, on memory card Image storage mode Simultaneous storage of images in IR, visual and MSX Image annotations Voice 60 seconds (via Bluetooth) Text Text from predefined list or soft keyboard on touch screen Meterlink Wireless connection (Bluetooth®) to: FLIR meters with MeterLink Report generation • FLIR Tools software specifically designed to provide an easy way to create inspection reports. It is available on the major platforms – Android, Windows, MacOS and iOS. Video recording in camera Non-radiometric IR-video recording MPEG-4 to memory card Video streaming Radiometric IR-video streaming Full dynamic to PC using USB Non-radiometric IR-video streaming Uncompressed colorized video using USB Digital camera Built-in digital camera 3.1 Mpixel (2048 × 1536 pixels), and one LED light Digital camera, focus Fixed focus Built-in digital lens data FOV 53° × 41° Digital camera, aspect ratio 4:3 Laser pointer 3 (10) Laser Activated by dedicated button Laser alignment Position is automatic displayed on the IR image Laser classification Class 2 Laser type Semiconductor AlGaInP diode laser Laser power 1 mW Laser wavelength 635 nm (red) www.flir.com FLIR E60 (incl. Wi-Fi) P/N: 64501-0302 Data communication interfaces © 2014, FLIR Systems, Inc. Wi-Fi Peer to peer (adhoc) or infrastructure (network) SD Card One card slot for removable SD memory cards Audio Microphone headset via Bluetooth for voice annotation of images #64501-0302; r. -/15419; en-US USB USB USB, standard USB, connector type • • USB-A: Connect external USB device USB Mini-B: Data transfer to and from PC / Uncompressed colorized video USB Mini-B: 2.0 • • USB-A connector USB Mini-B connector Composite video Video out Composite Video, standard CVBS (ITU-R-BT.470 PAL/SMPTE 170M NTSC) Video, connector type 4-pole 3.5 mm jack Radio Wi-Fi Standard: 802.11 b/g Frequency range: 2412–2462 MHz Max output power: 15 dBm Bluetooth Frequency range: 2402–2480 MHz Antenna Internal Power system Battery type Rechargeable Li Ion battery Battery voltage 3.7 V Battery capacity 4.4 Ah, at +20°C to +25°C (+68°F to +77°F) Battery operating time Approx. 4 hours at +25°C (+77°F) ambient temperature and typical use Charging system In camera (AC adapter or 12 V from a vehicle) or 2-bay charger Charging time 4 h to 90% capacity, charging status indicated by LED's Charging temperature 0°C to +45°C (+32°F to +113°F) Power management Automatic shutdown and sleep mode (user selectable) AC operation AC adapter, 90–260 VAC input, 12 V output to camera Start-up time from sleep mode Instant on Environmental data 4 (10) Operating temperature range –15°C to +50°C (+5°F to +122°F) Storage temperature range –40°C to +70°C (–40°F to +158°F) Humidity (operating and storage) IEC 60068-2-30/24 h 95% relative humidity +25° C to +40°C (+77°F to +104°F) / 2 cycles www.flir.com FLIR E60 (incl. Wi-Fi) P/N: 64501-0302 Environmental data © 2014, FLIR Systems, Inc. EMC #64501-0302; r. -/15419; en-US Radio spectrum • • • • • • ETSI EN 301 489-1 (radio) ETSI EN 301 489-17 EN 61000-6-2 (Immunity) EN 61000-6-3 (Emission) FCC 47 CFR Part 15 B (Emission) ICES-003 • • • ETSI EN 300 328 FCC Part 15.247 RSS-210 Magnetic fields EN 61 000-4-8, Test level 5 for continous field (Severe industrial environment) Encapsulation IP 54 (IEC 60529) Bump 25 g (IEC 60068-2-29) Vibration 2 g (IEC 60068-2-6) Safety EN/UL/CSA/PSE 60950-1 Physical data Camera weight, incl. battery 0.880 kg (1.94 lb.) Camera size (L × W × H) 246 × 97 × 184 mm (9.7 × 3.8 × 7.2 in.) Tripod mounting UNC ¼"-20 (adapter needed) Material Polycarbonate + acrylonitrile butadiene styrene (PC-ABS) Thixomold magnesium Thermoplastic elastomer (TPE) Color Graphite gray and black Shipping information • • • • • • • • • • • • Hard transport case Infrared camera with lens Battery (2 ea.) Battery charger FLIR Tools download card Handstrap Memory card Power supply, incl. multi-plugs Printed documentation USB cable User documentation CD-ROM Video cable Packaging, weight 5.0 kg (11.02 lb.) Packaging, size 500 × 350 × 190 mm (19.7 × 13.8 × 7.5 in.) EAN-13 4743254001152 UPC-12 845188005184 Supplies & accessories: • • • • • 5 (10) 1196961; IR lens, f = 30 mm, 15° incl. case 1196960; IR lens, f = 10 mm, 45° incl. case T910814; Power supply, incl. multi plugs T911230ACC; Memory card SDHC 4 GB 1910423; USB cable Std A Mini-B www.flir.com FLIR E60 (incl. Wi-Fi) P/N: 64501-0302 © 2014, FLIR Systems, Inc. #64501-0302; r. -/15419; en-US 6 (10) • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • T198509; Cigarette lighter adapter kit, 12 VDC, 1.2 m/3.9 ft. 1910582ACC; Video cable T197771ACC; Bluetooth Headset T910972; EX845: Clamp meter + IR therm TRMS 1000A AC/DC T910973; MO297: Moisture meter, pinless with memory T911093; Tool belt T198125; Battery charger, incl. power supply with multi plugs Exx T198113; IR lens, 76 mm (6°) with case and mounting support for Exx T198487; Li-Ion Battery pack 3.7V 17Wh T198484; Pouch for FLIR Exx series T198486; Tripod Adapter T198485; Sun shield T198341ACC; Transport case Exx T198586; FLIR Reporter Professional (license only) T198584; FLIR Tools T198583; FLIR Tools+ (license only) DSW-10000; FLIR IR Camera Player APP-10002; FLIR Tools Mobile (Android Application) APP-10004; FLIR Tools (MacOS Application) T127597L5; FLIR ResearchIR 3 (license only), 5 user licenses T127597L10; FLIR ResearchIR 3 (license only), 10 user licenses T127598L5; FLIR ResearchIR 3 Max (license only), 5 user licenses T127598L10; FLIR ResearchIR 3 Max (license only), 10 user licenses T198696; FLIR ResearchIR Max 4 T198697; FLIR ResearchIR Max + HSDR 4 T198579; FLIR ResearchIR 3 (CD) T198578; FLIR ResearchIR 3 (license only) T198575; FLIR ResearchIR 3 Max (CD) T198574; FLIR ResearchIR 3 Max (license only) T198292; Upgrade previous version to FLIR ResearchIR 3 T198291; Upgrade previous version to FLIR ResearchIR 3 Max T198290; Upgrade FLIR ResearchIR 3 to FLIR ResearchIR 3 Max www.flir.com © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 2 1,53in 38,9mm 2 3 3 4 Optical axis 4 7,27in 184,7mm 1 Camera with built-in IR lens f=18 mm (25°) 1,5in 38,1mm ,7in 10 8mm 1, 27 2,41in 61,1mm 2,62in 66,5mm UNC 1/4"-20 0,15in 3,9mm Tripod Spacer Optional 2,03in 51,6mm 5 9in 4,5 5mm 6, 11 5 1,93in 49mm 1,53in 38,8mm 0,55in 14mm 0,68in 17,2mm 6 7,09in 180,2mm 6 7in 2,1 mm 55 7 7 9,68in 245,9mm 8 2,03in 51,6mm 1,59in 40,5mm Check CAHA 0,79in 20mm 0,79in 20mm R&D Thermography Drawn by 3,79in 96,2mm 1,46in 37,2mm Optical axis 9 Basic dimensions Flir Exx series 2013-04-18 Denomination Modified - 1,5in 38,1mm 2,66in 67,5mm 1:2 T127869 Drawing No. A3 Size Scale 10 A 1(4) Size Sheet G F E D C B A © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. G G H F F E D C B A 1 1 Camera with Lens IR f=10 mm (45°) 1,51in 38,4mm 2 2 1,85in 47mm Optical axis 3 1,02in 25,9mm 9in 5,1 9mm , 1 13 3 ,7in 10 8mm 1, 7 2 1,93in 49mm 0,55in 14mm 4 4 5 5 6 6 CAHA Check 8 10 T127869 Drawing No. 1:2 A3 Size Scale A E D C B A 2(4) Size Sheet For additional dimensions see page 1 R&D Thermography Drawn by 9 Basic dimensions Flir Exx series 2013-04-18 Denomination Modified - Optical axis 7 © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. G G H F F E D C B A 1 1 Camera with Lens IR f=30 mm (15°) 0,95in 24,3mm 2 2 2,28in 57,9mm Optical axis 0,46in 11,7mm 3 0,55in 14mm 1,93in 49mm in 4,8 mm ,8 1 12 3 ,7in 10 8mm 1, 7 2 4 4 5 5 6 6 Optical axis 7 CAHA Check T127869 Drawing No. 1:2 A3 Size Scale 10 A E D C B A 3(4) Size Sheet For additional dimensions see page 1 R&D Thermography Drawn by 9 Basic dimensions Flir Exx series Denomination 2013-04-18 Modified 8 © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 4,17in 105,8mm 2 2 3 3 4 Optical axis 4 4in 7,9 7mm , 1 20 Camera with Lens IR f=76 mm (6°) incl support 1 3,78in 96mm 3,48in 88,5mm in ,42 12 ,5mm 5 31 5 5,05in 128,3mm 5 Lens support Optional 6 6 7 CAHA Check T127869 Drawing No. 1:2 A3 Size Scale 10 A G F E D C B A 4(4) Size Sheet For additional dimensions see page 1 R&D Thermography Drawn by 4,27in 108,5mm 4,02in 102mm Optical axis 9 Basic dimensions Flir Exx series 2013-04-18 Denomination Modified 8
64501-0302 价格&库存
很抱歉,暂时无法提供与“64501-0302”相匹配的价格&库存,您可以联系我们找货
