TG167-NIST
TG167-NIST
    FLIR(菲力尔)
    FLIR TG167 SPOT THERMAL CAMERA 8
TG167-NIST 数据手册
FLIR TG167 (Global) P/N: 74701-0104 Copyright © 2016, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: 74701-0104 Release: Commit: 33482 Language: Modified: 2016-02-18 Formatted: 2016-02-18 Website http://www.flir.com Customer support http://support.flir.com Disclaimer General description Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. FLIR’s new TG167 imaging infrared (IR) thermometer bridges the gap between single-spot IR thermometers and FLIR’s legendary thermal cameras. Equipped with FLIR’s exclusive Lepton micro thermal camera, the FLIR TG167 shows you where potential problems are brewing and where to aim your spot. The FLIR TG167 lets you see heat patterns, reliably measure temperature, and store images and data. Its menu uses intuitive icons, making it simple to operate. The FLIR TG167 also makes documentation easy by saving images you can download from the Micro SD card or over a USB connection and use for reports. Key features • • • • • See the heat and speed up troubleshooting. Know where to measure temperature. Grab and go simplicity—no special training required. Pocket portable to fit a crowded tool bag. Rugged and reliable. Imaging and optical data IR resolution 80 × 60 pixels Thermal sensitivity/NETD < 150 mK Field of view (FOV) 25° × 19.6° Minimum focus distance 0.1 m (4 in.) Distance to spot ratio 24:1 Image frequency 9 Hz Focus Focus free Detector data 1 (4) Detector type Focal plane array (FPA), uncooled microbolometer Spectral range 8–14 μm www.flir.com FLIR TG167 (Global) P/N: 74701-0104 Image presentation © 2016, FLIR Systems, Inc. Display #74701-0104; r. /33482; 2.0 in. TFT LCD Measurement Object temperature range –25 to +380°C (–13 to +716°F) Accuracy ±1.5% or 1.5°C (2.7°F) Minimum measurement distance 26 cm (10 in.) Measurement analysis Center spot Color palettes Yes • • • Hot Iron Rainbow Grayscale • Local adaptation of units, language, date, and time formats Deletion of images Set-up Set-up commands • Emissivity correction 4 pre-set levels with custom adjustment of 0.1– 0.99 Storage of images Memory type Micro SD card Image storage capacity 75 000 pictures with included 8 GB Micro SD card Memory expansion 32 GB SD card maximum Saved image format Bitmap (BMP) image with temperature and emissivity Laser pointers Laser Dual diverging lasers indicate the temperature measurement area, activated by pulling the trigger Power system Battery type Rechargeable Li ion battery Battery voltage 3.7 V Battery operating time >5 hours of continuous scanning with lasers Battery charge life 30 days minimum Charging system Battery is charged inside the camera Charging time 4 hours to 90%, 6 hours to 100% Power management Adjustable: off, 1 minute, 2 minutes, 5 minutes, 10 minutes Environmental data 2 (4) Operating temperature range –10 to +45°C (+14 to 113°F) Storage temperature range –30 to +55°C (–22 to 131°F) www.flir.com FLIR TG167 (Global) P/N: 74701-0104 Environmental data © 2016, FLIR Systems, Inc. Humidity (operating and storage) #74701-0104; r. /33482; EMC 0–90% relative humidity (RH) (0–37°C (32– 98.6° F)), 0–65% RH (37–45°C (98.6–113°F)), 0–45% RH (45–55°C (113–131°F )) • • • • • WEEE 2012/19/EC RoHs 2011/65/EC EN 61000-6-3 EN 61000-6-2 FCC 47 CFR Part 15 Class B Magnetic fields EN 61000-4-8 Encapsulation IP 40 (IEC 60529) Shock 25 g (IEC 60068-2-29) Vibration 2 g (IEC 60068-2-6) Drop Designed for 2 m (6.6 ft.) Safety CE, FCC, PSC, FDA Physical data Camera weight, incl. battery 0.312 kg (11 oz.) Camera size (L × W × H) 186 mm × 55 mm × 94 mm (7.3 in. × 2.2 in. × 3.7 in.) Tripod mounting 1/4 in.-20 on handle bottom Color Black, white, silver Material PC-ABS, TPU Shipping information Packaging, type List of contents 3 (4) Color box with view of product in clamshell • • • • • Imaging IR thermometer 8 GB Micro SD card Printed documentation Wrist strap lanyard Power supply with separate USB cable Packaging, weight 0.85 kg (1.8 lb.) Packaging, size 34 cm × 15 cm × 12 cm (13.5 in. × 6 in. × 4.5 in.) EAN-13 7332558010877 UPC-12 845188011628 Country of origin China www.flir.com © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 2 3 in 95 m 3, ,3m 0 10 Optical Axis Laser/ spot pyrometer IR Optical Axis 3 TG 167: Camera with built in IR lens 25° x 19,3° 1,23in 31,3mm TG 165: Camera with built in IR lens 50° x 38,6° 0,66in 16,85mm 2 10deg Optical axis g surface Vs 5,48in 139,3mm 1 Tripod mountin 4 4 3,92in 99,4mm 3,28in 83,4mm 3,03in 77mm 5 1,54in 39,2mm 5 Tripod axis 6 6 Tripod mount: UNC 1/4 - 20 7,33in m 186,1m R&D Thermography Drawn by 9 Basic Dimensions TG165 -167 ROPE Check Tripod axis 8 Laser Center Distance 2015-06-15 Denomination Modified - 2,16in 55mm 1,41in 35,9mm Optical Axis 1,26in 32mm 7 7,38in 187,4mm T128960 Drawing No. 1:2 A3 Scale Size 10 A 1(1) Size Sheet G F E D C B A
TG167-NIST 价格&库存
很抱歉,暂时无法提供与“TG167-NIST”相匹配的价格&库存,您可以联系我们找货
