62103-1701
    FLIR(菲力尔)
    FLIR T440BX BLDG IR CAMERA 320 X
62103-1701 数据手册
FLIR T420bx & T440bx High Performance Infrared Camera with On-board Visual Camera, Touch Screen, Wi-Fi Connectivity, & Interchangeable Lens, plus MSX® Image Enhancement & Auto Orientation Get maximum flexibility and efficiency out of 320 x 240 thermal imaging from our new T400bx line. Superior Thermal Imaging – Sharp thermal resolution at 76,800 pixels for solid accuracy from farther away. MSX® Enhancement – Multi-Spectral Dynamic Imaging adds visible spectrum definition to IR images in real time for excellent thermal detail to help you instantly recognize the problem locations. Advanced Optics – The widest array of lens options to fit the view and spot size you need for your application. Compass – Adds camera pointing direction to every image for additional location documentation. Wi-Fi Connectivity – Send images and data to smart phones and tablets (ie. iPhone®, iPad®, iPod touch®, or Android™) to share images and critical information quickly using FLIR Tools Mobile app. Accurate Temperature Measurements – Accuracy calibrated within +/– 2°C or +/– 2% of reading. Temperature Range – measuring up to 1202°F (650°C) targeting insulation, HVAC, and building applications (T440bx model). Scalable P-i-P – Overlay thermal images onto visible light photos as an alternative reference. Humidity, Dew Point, & Insulation Alarms – Alerts user when it detects moisture intrusion and insulation issues. METERLiNK® – Wirelessly transmit vital diagnostic data from clamp and moisture meters directly to the camera for annotating thermal images to further support findings. Wi-Fi Connectivity Annotation – Add voice comments via Bluetooth headset and text notes from the touchscreen keypad; New! T440bx has image sketch feature to add circles and pointers on IR/Visual stored images. Auto Orientation – Automatically orients onscreen temperature measurement data whether in portrait or landscape view. Includes – SD Memory Card, 100-260V AC adaptor/charger, two Li-Ion rechargeable batteries, 2-bay battery charger, power supply (with multi-plugs), FLIR Tools software, USB cable, video cable, sun shield, Bluetooth® headset, lens cap, neckstrap, and hard case. Built-in 3.1MP Digital Camera, LED Lamp, Laser Pointer, Fine Focus Adjust, and Auto focus & Image Capture Button. 120° Rotating Lens with 8X Continuous Zoom Wireless METERLiNK® Communication via Bluetooth ® Original IR Image on the Left and with MSX™ Enhancement on the Right image Auto Orientation Keeps On-Screen Data Upright Applications Water Damage — Water leak on ceiling, gutter, & roof top Energy Loss — Missing Insulation, Air Leaks, HVAC Issues Imaging Specifications FEATURES FLIR T420bx FLIR T440bx Temperature range -4°F to 662°F (-20°C to 350°C) -4°F to 1202°F (-20°C to 650°C) Zoom 4X Continuous 8X Continuous LCD Image Sketch — Draw on stored images right on touchscreen Multi-Spectral Dynamic Imaging (MSX) IR image with enhanced detail presentation IR image with enhanced detail presentation Measurement Presets 7 presets: center spot; hot spot (box max); cold spot (box min); 3 spots; hot spot - spot (box max + spot + delta); hot spot - temperature (box max + ref temp + delta); no measurements 6 presets: center spot; hot spot (box max); cold spot (box min); no measurements; user preset 1; user preset 2 Profile Measurement Analysis — Shows a live graph of temperatures across a line profile on the image COMMON FEATURES Frame rate 60Hz Field of view/minimum focus distance/FOV Match 25° x 19° / 1.31ft (0.4m) / Field of View Match where Digital Image FOV adapts to the IR lens Focus Manual/Automatic Thermal sensitivity (N.E.T.D)
62103-1701 价格&库存
很抱歉,暂时无法提供与“62103-1701”相匹配的价格&库存,您可以联系我们找货
