T910814
T910814
    FLIR(菲力尔)
    POWER SUPPLY, INCL. MULTI PLUGS
T910814 数据手册
Power supply, incl. multi plugs P/N: T910814 Copyright © 2016, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: T910814 Release: Commit: 29700 Language: en-US Modified: 2015-10-16 Formatted: 2016-05-31 Website General description http://www.flir.com FLIR P/B/SC6xx and FLIR GF3xx series: Customer support Power supply, including multiple plugs, to charge the battery when it is inside or outside of the camera. http://support.flir.com Disclaimer FLIR T6xx and FLIR Exx series: Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Power supply, including multiple plugs, to charge the battery when it is inside the camera or in the battery charger. Power system AC operation 100–240 VAC, 50/60 Hz, 12 VDC out Power 3000 mA at 12 VDC Physical data Cable length 1.98 m (6.5 ft.) Shipping information Packaging, type List of contents Cardboard box • • • • • Power supply including cable EU plug UK plug US plug AU plug Packaging, weight 0.324 kg (9.7 lb.) Packaging, size 152 × 78 × 73 mm (6.0 × 3.1 × 2.9 in.) EAN-13 7332558003794 4743254001763 (Estonia plant) UPC-12 845188002145 Country of origin Sweden Compatible with the following products • • • • • • • • • • 1 (4) 72501-0101; FLIR T1020 12° 72501-0102; FLIR T1020 28° 72501-0103; FLIR T1020 45° 72501-0104; FLIR T1020 28° and 12° 72501-0105; FLIR T1020 28° and 45° 72501-0106; FLIR T1020 28°, 12°, and 45° 72501-0201; FLIR T1030sc 12° 72501-0202; FLIR T1030sc 28° 72501-0203; FLIR T1030sc 45° 72501-0301; FLIR T1040 12° www.flir.com Power supply, incl. multi plugs P/N: T910814 © 2016, FLIR Systems, Inc. #T910814; r. /29700; en-US 2 (4) • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 72501-0302; FLIR T1040 28° 72501-0303; FLIR T1040 45° 72501-0401; FLIR T1050sc 12° 72501-0402; FLIR T1050sc 28° 72501-0403; FLIR T1050sc 45° 55903-1015; FLIR T600 15° (incl. Wi-Fi and Ext. cal.) 55903-0922; FLIR T600 15° (incl. Wi-Fi) 55903-1016; FLIR T600 25° (incl. Wi-Fi and Ext. cal.) 55903-1022; FLIR T600 25° (incl. Wi-Fi) 55903-1007; FLIR T600 25° and 15° w/case 55903-1008; FLIR T600 25° and 45° w/case 55903-1017; FLIR T600 45° (incl. Wi-Fi and Ext. cal.) 55903-1522; FLIR T600 45° (incl. Wi-Fi) 55903-2823; FLIR T600bx 25° (incl. Wi-Fi and Ext. cal.) 55903-2822; FLIR T600bx 25° (incl. Wi-Fi) 55903-2923; FLIR T600bx 45° (incl. Wi-Fi and Ext. cal.) 55903-2922; FLIR T600bx 45° (incl. Wi-Fi) 55903-8022; FLIR T610 15° (incl. Wi-Fi) 55903-3922; FLIR T610 25° (incl. Wi-Fi) 55903-4022; FLIR T610 45° (incl. Wi-Fi) 55903-5023; FLIR T620 15° (incl. Wi-Fi and Ext. cal.) 55903-5022; FLIR T620 15° (incl. Wi-Fi) 55903-5125; FLIR T620 25° (incl. Wi-Fi and Ext. cal.) 55903-5122; FLIR T620 25° (incl. Wi-Fi) 55903-5123; FLIR T620 25° and 15° (incl. Wi-Fi) 55903-5124; FLIR T620 25° and 45° (incl. Wi-Fi) 55903-5223; FLIR T620 45° (incl. Wi-Fi and Ext. cal.) 55903-5222; FLIR T620 45° (incl. Wi-Fi) 55903-5623; FLIR T620bx 15° (incl. Wi-Fi and Ext. cal.) 55903-5622; FLIR T620bx 15° (incl. Wi-Fi) 55903-5723; FLIR T620bx 25° (incl. Wi-Fi and Ext. cal.) 55903-5722; FLIR T620bx 25° (incl. Wi-Fi) 55903-5823; FLIR T620bx 45° (incl. Wi-Fi and Ext. cal.) 55903-5822; FLIR T620bx 45° (incl. Wi-Fi) 55904-6222; FLIR T630 15° (incl. Wi-Fi) 55904-6322; FLIR T630 25° (incl. Wi-Fi) 55904-6422; FLIR T630 45° (incl. Wi-Fi) 55904-8023; FLIR T630sc 15° (incl. Wi-Fi) 55904-8123; FLIR T630sc 25° (incl. Wi-Fi) 55904-8124; FLIR T630sc 25° and 45° w/case 55904-8223; FLIR T630sc 45° (incl. Wi-Fi) 55904-6823; FLIR T640 15° (incl. Wi-Fi and Ext. cal.) 55904-6822; FLIR T640 15° (incl. Wi-Fi) 55904-6925; FLIR T640 25° (incl. Wi-Fi and Ext. cal.) 55904-6922; FLIR T640 25° (incl. Wi-Fi) 55904-6923; FLIR T640 25° and 15° (incl. Wi-Fi) 55904-6924; FLIR T640 25° and 45° (incl. Wi-Fi) 55904-7023; FLIR T640 45° (incl. Wi-Fi and Ext. cal.) 55904-7022; FLIR T640 45° (incl. Wi-Fi) 55904-7423; FLIR T640bx 15° (incl. Wi-Fi and Ext. cal.) 55904-7422; FLIR T640bx 15° (incl. Wi-Fi) 55904-7523; FLIR T640bx 25° (incl. Wi-Fi and Ext. cal.) 55904-7522; FLIR T640bx 25° (incl. Wi-Fi) 55904-7623; FLIR T640bx 45° (incl. Wi-Fi and Ext. cal.) 55904-7622; FLIR T640bx 45° (incl. Wi-Fi) 55904-7723; FLIR T650sc 15° (incl. Wi-Fi) 55904-7823; FLIR T650sc 25° (incl. Wi-Fi) 55904-7824; FLIR T650sc 25° and 15° w/case 55904-7825; FLIR T650sc 25° and 45° w/case www.flir.com Power supply, incl. multi plugs P/N: T910814 © 2016, FLIR Systems, Inc. #T910814; r. /29700; en-US 3 (4) • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 55904-7923; FLIR T650sc 45° (incl. Wi-Fi) 55904-8423; FLIR T660 15° (incl. Wi-Fi and Ext. cal.) 55904-8422; FLIR T660 15° (incl. Wi-Fi) 55904-8523; FLIR T660 25° (incl. Wi-Fi and Ext. cal.) 55904-8522; FLIR T660 25° (incl. Wi-Fi) 55904-8524; FLIR T660 25° and 15° w/case 55904-8525; FLIR T660 25° and 45° w/case 55904-8623; FLIR T660 45° (incl. Wi-Fi and Ext. cal.) 55904-8622; FLIR T660 45° (incl. Wi-Fi) 62103-1102; FLIR T420 (incl. Wi-Fi and 15° lens) 62103-1103; FLIR T420 (incl. Wi-Fi and 45° lens) 62103-1105; FLIR T420 (incl. Wi-Fi and Ext. cal.) (60 Hz) 62103-1101; FLIR T420 (incl. Wi-Fi) 62103-1205; FLIR T420 with SC kit (incl. Wi-Fi and 45° lens) 62103-1502; FLIR T420bx (incl. Wi-Fi and Ext. cal.) (60 Hz) 62103-1501; FLIR T420bx (incl. Wi-Fi) 62103-1503; FLIR T420bx 25° and 15° w/case 62103-1504; FLIR T420bx 25° and 45° w/case 62104-2203; FLIR T430sc (incl. Wi-Fi) 62103-1304; FLIR T440 (incl. Wi-Fi and Ext. cal.) (60 Hz) 62103-1302; FLIR T440 (incl. Wi-Fi and 15° lens) 62103-1303; FLIR T440 (incl. Wi-Fi and 45° lens) 62103-1301; FLIR T440 (incl. Wi-Fi) 62103-1702; FLIR T440bx (incl. Wi-Fi and Ext. cal.) (60 Hz) 62103-1701; FLIR T440bx (incl. Wi-Fi) 62103-1703; FLIR T440bx 25° and 15° w/case 62103-1704; FLIR T440bx 25° and 45° w/case 62104-1903; FLIR T450sc (incl. Wi-Fi) 62104-1904; FLIR T450sc 25° and 45° w/case 62104-2802; FLIR T460 (incl. Wi-Fi and Ext. cal.) 62104-2801; FLIR T460 (incl. Wi-Fi) 62104-2803; FLIR T460 25° and 15° w/case 62104-2804; FLIR T460 25° and 45° w/case 44401-0201; FLIR GF300 14.5° 44402-0201; FLIR GF300 14.5° Fixed lens 44401-0202; FLIR GF300 24° 44402-0202; FLIR GF300 24° Fixed lens 59601-0101; FLIR GF304 14.5° 59602-0101; FLIR GF304 14.5° Fixed lens 59601-0102; FLIR GF304 24° 59602-0102; FLIR GF304 24° Fixed lens 44201-0101; FLIR GF306 14.5° 44202-0101; FLIR GF306 14.5° Fixed lens 44201-0102; FLIR GF306 24° 44202-0102; FLIR GF306 24° Fixed lens 44601-0101; FLIR GF309 14.5° 44602-0101; FLIR GF309 14.5° Fixed lens 44601-0102; FLIR GF309 24° 44602-0102; FLIR GF309 24° Fixed lens 44401-0101; FLIR GF320 14.5° 44402-0101; FLIR GF320 14.5° Fixed lens 44401-0102; FLIR GF320 24° 44402-0102; FLIR GF320 24° Fixed lens 57501-0102; FLIR GF335 24° 59801-0101; FLIR GF346 14.5° 59802-0101; FLIR GF346 14.5° Fixed lens 59801-0102; FLIR GF346 24° 59802-0102; FLIR GF346 24° Fixed lens 64502-0801; FLIR E33 www.flir.com Power supply, incl. multi plugs P/N: T910814 © 2016, FLIR Systems, Inc. #T910814; r. /29700; en-US 4 (4) • • • • • • • • • • • • 64502-1001; FLIR E40 64501-0101; FLIR E40 (incl. Wi-Fi) 64501-0103; FLIR E40 with SC kit (incl. Wi-Fi and 45° lens) 64501-0114; FLIR E40 with SC kit (incl. Wi-Fi) 64501-0501; FLIR E40bx (incl. Wi-Fi) 64502-1101; FLIR E50 64501-0201; FLIR E50 (incl. Wi-Fi) 64501-0601; FLIR E50bx (incl. Wi-Fi) 64502-1202; FLIR E60 64501-0302; FLIR E60 (incl. Wi-Fi) 64501-0702; FLIR E60bx (incl. Wi-Fi) 64501-0402; FLIR E63 (incl. Wi-Fi) www.flir.com
T910814 价格&库存
很抱歉,暂时无法提供与“T910814”相匹配的价格&库存,您可以联系我们找货
