AFCT-57F5TMZ
AFCT-57F5TMZ
    FIT(鸿腾精密)
    MODULE TXRX OPT SFP 8G/4G/2G
AFCT-57F5TMZ 数据手册
AFCT-57F5TMZ Digital Diagnostic SFP+, 1310 nm, 16 GFC [14.025/8.5/4.25 GBd] Fibre Channel Optical Transceiver Temperature Range 0 to 70 °C Tcase Data Sheet Description Features Avago Technologies’ AFCT-57F5TMZ optical transceiver supports high speed serial links over single mode optical fiber at signalling rates up to 14.025 Gb/s (the serial line rate of 16 GFC). The product is compliant with Small Form Pluggable industry agreements SFP and SFP+ for mechanical and low speed electrical specifications. High speed electrical and optical specifications are compliant with ANSI Fibre Channel FC-PI-5. • • • • Digital diagnostic monitoring information (DMI) is present in the AFCT-57F5TMZ per the requirements of SFF-8472, providing real time monitoring information of transceiver laser, receiver and environment conditions over a SFF8431 2-wire serial interface. Compliant to RoHS directives 1310 nm Distributed Feedback Laser (DFB) Class 1 eye safe per IEC60825-1 and CDRH LC duplex connector optical interface conforming to ANSI TIA/EIA604-10 (FOCIS 10A) • Diagnostic features per SFF-8472 “Diagnostic Monitoring Interface for Optical Transceivers” • Enhanced operational features including EWRAP, OWRAP and variable electrical EQ/emphasis settings • Real time monitoring of: - Transmitter average optical power - Received average optical power - Laser bias current - Temperature - Supply Voltage • SFP+ mechanical specifications per SFF-8432 • Pull Tab delatch mechanism • SFP+ compliant low speed interface • Fibre Channel FC-PI-5 compliant high speed interface - 1600- SM-LC-L, 800- SM-LC-L, 400-SM-LC-L • Fibre Channel FC-PI-5 compliant 10km link distances Related Products Applications The AFCT-57F5TMZ is a multi-rate 1310 nm transceiver which ensures compliance with FC-PI-5 16 GFC, 8 GFC and 4 GFC specifications. Per the requirements of 16 GFC, an internal clock and data recovery circuit (CDR) is present on the electrical output of this transceiver. This CDR will lock at 14.025 Gb/s (16 GFC) but must be bypassed for operation at 8.5 Gb/s (8 GFC) and 4.25 Gb/s (4 GFC), accomplished by using Rate Select inputs to configure transmit and receive sides. Transmitter and receiver can operate at different data rates, as is often seen during Fibre Channel speed negotiation. • AFBR-57F5TPZ: 850 nm SFP for 16G/8G/4G Fibre Channel • AFBR-57D7APZ: 850 nm SFP for 8G/4G/2G Fibre Channel • AFCT-57D5ATPZ: 1310 nm SFP for 8G/4G/2G Fibre Channel • AFCT-57D5ANPZ: 1310 nm SFP for 8G/4G/2G Fibre Channel • AFBR-57R5APZ: 850 nm SFP for 4G/2G/1G Fibre Channel • AFCT-57R5APZ: 1310 nm SFP for 4G/2G/1G Fibre Channel • AFCT-57R5ATPZ: 1310 nm SFP for 4G/2G/1G Fibre Channel • AFCT-57R5ANPZ: 1310 nm SFP for 4G/2G/1G Fibre Channel • • • • • • Fibre Channel switches (director, stand alone, blade) Fibre Channel Host Bus Adapters Fibre Channel RAID controllers Fibre Channel tape drive Port side connections Inter-switch or inter-chassis aggregated links Post Amp Rx CDR Rx Vout & Emphasis ROSA µcontroller TOSA Laser Driver SFP Connector Pre Amp Tx Equalization Figure 1. Transceiver functional diagram Transmitter Section Digital Diagnostics The transmitter section includes a Transmitter Optical SubAssembly (TOSA), laser driver circuit and an electrical input stage with variable equalization controls. The TOSA contains a 1310 nm Distributed Feedback Laser (DFB) light source with integral light monitoring function and imaging optics to assure efficient optical coupling to the LC connector interface. The TOSA is driven by a laser driver IC, which uses the differential output from an integral Tx equalization stage to modulate and regulate DFB optical power. Between the SFP electrical connector and Laser Driver is a variable, I2C-bus controlled, equalization circuit to optimize SFP performance with non-ideal incoming electrical waveforms. The AFCT-57F5ATPZ is compliant to the Diagnostic Monitoring Interface (DMI) defined in document SFF-8472. These features allow the host to access, via I2C-bus, real time diagnostic monitors of transmit optical power, received optical power, temperature, supply voltage and laser operating current. Receiver Section The receiver section includes a Receiver Optical SubAssembly (ROSA), pre-amplification and post-amplification circuit, Clock and Data Recovery Circuit and an electrical output stage with variable emphasis controls. The ROSA, containing a high speed PIN detector, pre-amplifier and imaging optics efficiently couple light from the LC connector interface and perform an optical to electrical conversion. The resulting differential electrical signal passes through a post amplification circuit and into a Clock and Data Recovery circuit (CDR) for cleaning up accumulated jitter. The resulting signal is passed to a high speed output line driver stage with variable, I2C-bus controlled, emphasis settings allowing the host to optimize signal characteristics between the SFP and host ASIC. Note the Rx CDR is engaged only with Rx_RATE=high (16 GFC) and bypassed with Rx_RATE=low (8G/4G). 2 Low Speed Interfaces Conventional low speed interface I/Os are available as defined in documents SFF-8074 and SFF-8431 to manage coarse and fine functions of the optical transceiver. On the transmit side, a Tx_DISABLE input is provided for the host to turn on and off the outgoing optical signal. A transmitter rate select control input, Tx_RATE, is provided to configure the transmitter stages for 16 GFC, 8 GFC or 4 GFC operation (logic HIGH , reserved for 16 GFC, logic LOW , reserved for 8 GFC and 4 GFC). A transmitter fault indicator output, Tx_FAULT, is available for the SFP to signal a host of a transmitter operational problem. A receiver rate select control input, Rx_RATE, is provided to configure receiver stages for 16 GFC, 8 GFC or 4 GFC operation (logic HIGH reserved for 16 GFC, logic LOW reserved for 8 GFC and 4 GFC). A received optical power loss of signal indicator, RX_LOS, is available to advise the host of a receiver operational problem. Regulatory Compliance The AFCT-57F5TMZ complies with all applicable laws and regulations as detailed in Table 1. Certification level is dependent on the overall configuration of the host equip­ ment. The transceiver performance is offered as a figure of merit to assist the designer. Electrostatic Discharge (ESD) Electromagnetic Interference (EMI) The AFCT-57F5TMZ is compatible with ESD levels found in typical manufacturing and operating environments as described in Table 1. In the normal handling and operation of optical transceivers, ESD is of concern in two circumstances. Equipment incorporating gigabit transceivers is typically subject to regulation by the FCC in the United States, CENELEC EN55022 (CISPR 22) in Europe and VCCI in Japan. The AFCT-57F5TMZ’s compliance to these standards is detailed in Table 1. The metal housing and shielded design of the AFCT-57F5TMZ minimizes the EMI challenge facing the equipment designer. The first case is during handling of the transceiver before it is inserted into an SFP compliant cage. To protect the device, it is important to use normal ESD handling precautions. These include use of grounded wrist straps, work-benches and floor wherever a transceiver is handled. The second case to consider is static discharges to the exterior of the host equipment chassis after installation. If the optical interface is exposed to the exterior of host equipment cabinet, the transceiver may be subject to system level ESD requirements. EMI Immunity (Susceptibility) Due to its shielded design, the EMI immunity of the AFCT57F5TMZ exceeds typical industry standards. Flammability The AFCT-57F5TMZ optical transceiver is made of metal and high strength, heat resistant, chemical resistant and UL 94 flame retardant plastic. Table 1. Regulatory Compliance Feature Test Method Performance Electrostatic Discharge (ESD) JEDEC A114 to the Electrical Pins Class 1 (> 2000 V) >1000 V for high speed signal pins TD+/-, RD+/- Electrostatic Discharge (ESD) Variation of IEC 61000-4-2 to the Duplex LC Receptacle Typically, no damage occurs with 25 kV when the duplex LC connector receptacle is contacted by a Human Body Model probe. GR1089 10 contacts of 8 kV on the electrical faceplate with device inserted into a panel. Electrostatic Discharge (ESD) Variation of IEC 801-2 to the Optical Connector Air discharge of 15 kV (min.) contact to connector without damage. Electromagnetic Interference (EMI) FCC Class B CENELEC EN55022 Class B (CISPR 22A) VCCI Class 1 System margins are dependent on customer board and chassis design. Immunity Variation of IEC 61000-4-3 Typically shows no measurable effect from a 10 V/m field swept from 10 MHz to 1 GHz. Laser Eye Safety and US FDA CDRH Equipment Type Testing EN 60825-1:2007 EN 60950-1:2006+A11+A1+A12  Class 1 Laser product Component Recognition UL file 173874 Underwriters Laboratories and Canadian Standards Association Joint Component Recognition for Information Technology Equipment including Electrical Business Equipment RoHS Compliance 3 Less than 1000 ppm of cadmium, lead, mercury, hexavalent chromium, polybrominated biphenyls, and polybrominated biphenyl ethers. Special Operation Functions: Electrical and optical high speed data “wrap” functions are enabled to assist with local host or remote diagnostic and optimization sequences. Optical data wrap (OWRAP) takes a received optical signal through a CDR jitter clean-up and retransmits it optically out. Electrical data wrap (EWRAP) takes an incoming electrical signal through a CDR jitter cleanup and retransmits it electrically out. An optional pass-through function is available to transmit outbound the wrapped information, controlled through I2C-bus commands. Rx CDR ROSA µcontroller TOSA Laser Driver Pre Amp Rx Vout & Emphasis Post Amp Rx Vout & Emphasis ROSA µcontroller TOSA Laser Driver Tx Equalization Figure 2a. OWRAP Functionality (I2C-buscontrolled) Rx CDR SFP Connector Post Amp SFP Connector Pre Amp Tx Equalization Figure 2b. EWRAP Functionality (I2C-bus controlled) The electrical SFP input stage (TD +/-) has been enhanced with features to allow host control and optimization of the transceiver’s input equalization settings. The host can then select, in situ, the most appropriate SFP setting for a given interconnect scenario. Rx CDR ROSA µcontroller TOSA Laser Driver Pre Amp Rx Vout & Emphasis Tx Equalization Figure 2c. SFP Tx Variable Input Electrical EQ (I2C-bus controlled) Post Amp Rx CDR Rx Vout & Emphasis ROSA µcontroller TOSA Laser Driver SFP Connector Post Amp SFP Connector Pre Amp Tx Equalization Figure 2d. SFP Rx Variable Output Electrical Emphasis (I2C-bus controlled) The SFP electrical output stage (RD+/-) has been enhanced with variable output emphasis features to allow host control and optimization of the receiver’s output settings. The host can then select, in situ, the most appropriate SFP setting for a given interconnect scenario. To assist with optimizing the receiver output setting, the user can have data transmitted by the SFP to a host ASIC by using EWRAP to loop back host generated traffic or can use a remotely generated optical signal as a data source for SFP and interconnect training. 4 Table 2. Rate Select Function Function State Explanation Rx Rate Select RS(0) High Receive Rate Select HIGH engages the internal Rx CDR. The CDR will look for valid 16 GFC traffic (14.025 Gb/s coded with 64b/66b) and lock within 500 µs when found. Due to differences in coding and bit rate, this CDR will not be able to lock on valid 8 GFC or 4 GFC traffic. Receive Rate Select LOW bypasses the internal Rx CDR. This is intended for use only with 8 GFC and 4 GFC traffic. When set low, the SFP behaves like a legacy SFP. Transmit Rate Select HIGH optimizes the transmitter performance for 16 GFC traffic. Transmit Rate Select LOW optmizes the transmitter performance for 4 GFC and 8 GFC traffic. Low Tx Rate Select RS(1) High Low Note: During Fibre Channel Link Speed Negotiation sequences, the host will control Tx Rate and Rx Rate inputs separately to accomplish link initialization. Once speed negotiation is complete, it is expected that both Tx Rate and Rx Rate will be placed in the same state by the host. Tx Rate Select VCC ,T RS (1) 40 kΩ 10 kΩ Tx DIS Tx_DISABLE Tx FAULT Tx_FAULT TD+ 0.1 µF 100 Ω TD0.1 µF 4.7 k to 10 kΩ 4.7 µH 0.1 µF Tx EQ LASER DRIVER Rx CDR POST AMPLIFIER VCC ,T 22 µF 0.1 µF 3.3 V SERDES IC PROTOCOL IC 4.7 µH 0.1 µF 22 µF 0.1 µF 50 Ω 4.7 k to 10 kΩ RD+ 100 Ω Rx LOS 0.1 µF 50 Ω 0.1 µF RS (0) Rx Rate Select 40 kΩ 3.3 V GND,R 4.7 k to 10 kΩ 4.7 k to 10 kΩ MOD_DEF0 4.7 k to 10 kΩ MODULE DETECT SCL SDA Figure 3. Typical application configuration 4.7 µH V CC T 0.1 µF 0.1 µF 22 µF 3.3 V 4.7 µH V CC R 0.1 µF 22 µF 0.1 µF HOST BOARD NOTE: INDUCTORS MUST HAVE LESS THAN 1Ω SERIES RESISTANCE TO LIMIT VOLTAGE DROP TO THE SFP MODULE. Figure 4. Recommended power supply filter 5 VCC ,R RD- LOSS OF SIGNAL SFP MODULE VCC ,R VCC ,R MOD_DEF1 MOD_DEF2 Table 3. Pin Description Pin Name Function/Description Notes 1 VeeT Transmitter Ground 2 TX_FAULT Transmitter Fault Indication – High indicates a fault condition Note 1 3 TX_DISABLE Transmitter Disable – Module electrical input disables on high or open Note 2 4 MOD-DEF2 Module Definition 2 – Two wire serial ID interface data line (SDA) Note 3 5 MOD-DEF1 Module Definition 1 – Two wire serial ID interface clock line (SCL) Note 3 6 MOD-DEF0 Module Definition 0 – Grounded in module (module present indicator) Note 3 7 Rx Rate Select RS(0) Receiver rate select. Logic High = 14.025 Gb/s, Logic Low = 8.5 Gb/s and 4.25 Gb/s Note 8 8 RX_LOS Loss of Signal – High indicates loss of received optical signal Note 4 9 Tx Rate Select RS(1) Transmitter rate select. Logic High = 14.025 Gb/s, Logic Low = 8.5 Gb/s and 4.25 Gb/s Note 8 10 VeeR Receiver Ground 11 VeeR Receiver Ground 12 RD- Inverse Received Data Out Note 5 13 RD+ Received Data Out Note 5 14 VeeR Receiver Ground 15 VccR Receiver Power + 3.3 V Note 6 16 VccT Transmitter Power + 3.3 V Note 6 17 VeeT Transmitter Ground 18 TD+ Transmitter Data In Note 7 19 TD- Inverse Transmitter Data In Note 7 20 VeeT Transmitter Ground Notes: 1.  TX_FAULT is an open collector/drain output, which must be pulled up with a 4.7 k – 10 kΩ resistor on the host board. When high, this output indicates a laser fault of some kind. Low indicates normal operation. In the low state, the output will be pulled to < 0.8 V. 2.  TX_DISABLE is an input that is used to shut down the transmitter optical output. It is internally pulled up (within the transceiver) with a 6.8 kΩ resistor. Low (0 – 0.8 V ): Transmitter on Between (0.8 V and 2.0 V ): Undefined High (2.0 – Vcc max) or OPEN: Transmitter Disabled 3.  The signals Mod-Def 0, 1, 2 designate the two wire serial interface pins. They must be pulled up with a 4.7 k – 10 kΩ resistor on the host board. Mod-Def 0 is grounded by the module to indicate the module is present Mod-Def 1 is serial clock line (SCL) of two wire serial interface Mod-Def 2 is serial data line (SDA) of two wire serial interface 4.  RX_LOS (Rx Loss of Signal) is an open collector/drain output that must be pulled up with a 4.7 k – 10 kΩ resistor on the host board. When high, this output indicates the received optical power is below the worst case receiver sensitivity (as defined by the standard in use). Low indicates normal operation. In the low state, the output will be pulled to < 0.8 V. 5.  RD-/+ designate the differential receiver outputs. They are AC coupled 100 Ω differential lines which should be terminated with 100 Ω differential at the host SERDES input. AC coupling is done inside the transceiver and is not required on the host board. The voltage swing on these lines will be between 370 and 850 mV differential (185 – 425 mV single ended) when properly terminated. 6.  VccR and VccT are the receiver and transmitter power supplies. They are defined at the SFP connector pin. The maximum supply current is 300 mA and the associated in-rush current will typically be no more than 30 mA above steady state after 2 microseconds. 7.  TD-/+ designate the differential transmitter inputs. They are AC coupled differential lines with 100 Ω differential termination inside the module. The AC coupling is done inside the module and is not required on the host board. The inputs will accept differential swings of 180 – 1200 mV (90 – 600 mV single ended) 8. Rate_Select is an input that is used to control transmit and receive high speed parametric optimizaton. It is internally pulled down (within the transceiver) with a 40kOhm resistor. Low (0 - 0.8V) or Open: Rate is set to 8.5 Gb/s and below optimization. For Rx Rate_Select, the internal CDR is bypassed. Between (0.8V and 2.0V) Undefined High (2.0 - Vcc max): Rate is set to 14.025 Gb/s optimization. For Rx Rate_Select, the internal CDR is engaged. 6 Table 4. Absolute Maximum Ratings Parameter Symbol Minimum Maximum Unit Notes Storage Temperature TS -40 85 C Note 1, 2 Case Operating Temperature TC -40 85 C Note 1, 2 Relative Humidity RH 5 95 % Note 1 Supply Voltage VccT, R -0.5 3.8 V Note 1, 2, 3 Low Speed Input Voltage VIN -0.5 Vcc+0.5 V Note 1 Notes; 1.  Absolute Maximum Ratings are those values beyond which damage to the device may occur if these limits are exceeded for other than a short period of time. See Reliability Data Sheet for specific reliability performance. 2.  Between Absolute Maximum Ratings and the Recommended Operating Conditions functional performance is not intended, device reliability is not implied, and damage to the device may occur over an extended period of time. 3.  The module supply voltages, VCCT and VCCR must not differ by more than 0.5 V or damage to the device may occur. Table 5. Recommended Operating Conditions Parameter Symbol Minimum Maximum Unit Notes Case Operating Temperature TC 0 70 °C Note s1, 2 Supply Voltage VccT, R 3.135 3.465 V Note 2 4.25 14.025 Gb/s Note 2 Data Rate Notes: 1.  The Ambient Operating Temperature limitations are based on the Case Operating Temperature limitations and are subject to the host system thermal design. 2.  Recommended Operating Conditions are those values for which functional performance and device reliability is implied. Table 6. Transceiver Electrical Characteristics (Tc = 0 °C to 70 °C, VccT, VccR = 3.3 V ± 5%) Parameter Symbol Minimum Typical Maximum PSNR 100 Unit  Notes AC Electrical Characteristics Power Supply Noise Rejection (peak-peak) mV Note 1 DC Electrical Characteristics Module Supply Current ICC 330 mA Low Speed Outputs: VOH 2.0   Transmit Fault (TX_FAULT), Loss of Signal   (RX_LOS), MOD-DEF 2 VOL 0.8 V Low Speed Inputs: VIH 2.0   Transmit Disable (TX_DIS), MOD-DEF 1,   MOD-DEF2, RS(0), RS(1) VIL 0 VccT,R+0.3 Vcc V 0.8 V Notes: 1.  Filter per SFP specification is required on host board to remove 10 Hz to 2 MHz content. 2.  Pulled up externally with a 4.7 k – 10 kΩ resistor on the host board to 3.3 V. 3.  Mod-Def1 and Mod-Def2 must be pulled up externally with a 4.7 k – 10 kΩ resistor on the host board to 3.3 V. 7 V Note 2 Note 3 Table 7. Transmitter and Receiver Electrical Characteristics (Tc = 0 °C to 70 °C, VccT, VccR = 3.3 V ± 5%) Parameter Symbol Min High Speed Data Input Transmitter Differential Input Voltage (TD+/-) VI High Speed Data Output Receiver Differential Output Voltage (RD+/-) Vo Receiver Total Jitter (14.025 Gb/s) Typ Max Unit Notes 180 1200 mV Note 1 370 850 mV Note 2 TJ 0.36 UI Note 3, Rx_Rate = high Receiver Total Jitter (8.5 Gb/s) TJ 0.71 UI Note 4, Rx_Rate = low Receiver Contributed Total Jitter (4.25 Gb/s) TJ 0.26 UI Note 4, Rx_Rate = low Receiver Deterministic Jitter (14.025 Gb/s) DJ 0.22 UI Note 3, Rx_Rate = high Receiver Deterministic Jitter (8.5 Gb/s) DJ 0.42 UI Note 4, Rx_Rate = low Receiver Contributed Deterministic Jitter (4.25 Gb/s) DJ 0.10 UI Note 4, Rx_Rate = low Receiver Data Dependent Pulse Width Shrinkage (14.025 Gb/s) DDPWS 0.14 UI Note 3, Rx_Rate = high Receiver Data Dependent Pulse Width Shrinkage (8.5 Gb/s) DDPWS 0.36 UI Note 4, Rx_Rate = low Notes: 1. Internally ac coupled and terminated (100Ω differential). 2. Internally ac coupled but requires an external load termination (100Ω differential). 3. CDR is engaged with Rx_Rate = high. Received output jitter for 14.025 Gb/s. 4. CDR is not engaged with Rx_Rate = low (ie. Bypassed). Receiver output jitter for 8.5 Gb/s and 4.25 Gb/s. Table 8. Transmitter Optical Characteristics (Tc = 0 °C to 70 °C, VccT, VccR = 3.3 V ± 5%) Parameter Symbol Min Unit Notes Modulated Optical Output Power (OMA) (Peak to Peak) 14.025 Gb/s Tx,OMA 631 uW TxRate=High Modulated Optical Output Power (OMA) (Peak to Peak) 8.5 Gb/s, 4.25 Gb/s Tx,OMA 290 uW TxRate=Low Average Optical Output Power 14.025 Gb/s Pout -5.0 dBm Note 1, TxRate=High Average Optical Output Power 8.5 Gb/s, 4.25 Gb/s Pout -8.4 dBm Note 1, TxRate=Low Center Wavelength lc 1295 -20 dB Spectral Width -20 dB Side Mode Suppression Typ Max 1325 nm 1.0 nm 30 dB RIN12 (OMA) RIN -130 dB/Hz Transmitter Distortion Penalty, 14.025 Gb/s TDP 4.4 dB TxRate=High Transmitter Distortion Penalty, 8.5 Gb/s TDP 3.2 dB TxRate=Low Tx Optical Rise/Fall Time (20% - 80%), 4.25 Gb/s Tr, Tf 90 ps TxRate=Low Transmitter Contributed Jitter, 4.25 Gb/s TJ 0.25 UI TxRate=Low Pout Tx_DISABLE Asserted Poff -35 dBm Notes: 1. Max Pout is the lesser of Class 1 safety limits (CDRH and EN 60825) or received power, max. 8 Table 9. Receiver Optical and Electrical Characteristics (Tc = 0 °C to 70 °C, VccT, VccR = 3.3 V ± 5%) Parameter Symbol Min Receiver Optical Center Wavelength lc 1260 Optical Input Power, 14.025 Gb/s Optical Input Power, 8.5 Gb/s Max Unit 1370 nm PIN +2.0 dBm,avg RxRate=High PIN +0.5 dBm,avg RxRate=Low Optical Input Power, 4.25 Gb/s PIN -1.0 dBm,avg RxRate=Low Input Optical Modulation Amplitude, 14.025 Gb/s (Peak to Peak) [Unstressed Sensitivity] OMA 63 uW,OMA Note 1 Input Optical Modulation Amplitude, 8.5 Gb/s (Peak to Peak) [Unstressed Sensitivity] OMA 42 uW,OMA Note 1 Input Optical Modulation Amplitude, 4.25 Gb/s (Peak to Peak) [Unstressed Sensitivity] OMA 29 uW,OMA Note 1 12 dB Return Loss Loss of Signal – Assert Pa Loss of Signal – De-asserted PD Loss of Signal – Hysteresis PA – PD Typ -28 dBm,OMA -16 0.5 dBm,OMA dB Notes: 1. Input Optical Modulation Amplitude (commonly known as sensitivity] requires a valid Fibre Channel encoded input. 9 Notes Table 10. Transceiver DIAGNOSTIC Timing Characteristics (Tc = 0 °C to 70 °C, VccT, VccR = 3.3 V ± 5%) Parameter Symbol Hardware TX_DISABLE Assert Time Minimum Maximum Unit Notes t_off 10 µs Note 1 Hardware TX_DISABLE Negate Time t_on 1 ms Note 2 Time to initialize, including reset of TX_FAULT t_init 300 ms Note 3 Hardware TX_FAULT Assert Time t_fault 1000 µs Note 4 Hardware TX_DISABLE to Reset t_reset µs Note 5 Hardware RX_LOS Deassert Time t_loss_on 100 µs Note 6 Hardware RX_LOS Assert Time t_loss_off 100 µs Note 7 Software TX_DISABLE Assert Time t_off_soft 100 ms Note 8 Software TX_DISABLE Negate Time t_on_soft 100 ms Note 9 Software Tx_FAULT Assert Time t_fault_soft 100 ms Note 10 Software Rx_LOS Assert Time t_loss_on_soft 100 ms Note 11 Software Rx_LOS Deassert Time t_loss_off_soft 100 ms Note 12 Analog parameter data ready t_data 1000 ms Note 13 Serial bus hardware ready t_serial 300 ms Note 14 Serial Bus Buffer Time t_buf µs Note 16 Write Cycle Time t_write 40 ms Note 15 Serial ID Clock Rate f_serial_clock 400 kHz 10 20 Notes: 1. Time from rising edge of TX_DISABLE to when the optical output falls below 10% of nominal. 2. Time from falling edge of TX_DISABLE to when the modulated optical output rises above 90% of nominal. 3. Time from power on or falling edge of Tx_Disable to when the modulated optical output rises above 90% of nominal. 4. From power on or negation of TX_FAULT using TX_DISABLE. 5. Time TX_DISABLE must be held high to reset the laser fault shutdown circuitry. 6. Time from loss of optical signal to Rx_LOS Assertion. 7. Time from valid optical signal to Rx_LOS De-Assertion. 8. Time from two-wire interface assertion of TX_DISABLE (A2h, byte 110, bit 6) to when the optical output falls below 10% of nominal. Measured from falling clock edge after stop bit of write transaction. 9. Time from two-wire interface de-assertion of TX_DISABLE (A2h, byte 110, bit 6) to when the modulated optical output rises above 90% of nominal. 10. Time from fault to two-wire interface TX_FAULT (A2h, byte 110, bit 2) asserted. 11. Time for two-wire interface assertion of Rx_LOS (A2h, byte 110, bit 1) from loss of optical signal. 12. Time for two-wire interface de-assertion of Rx_LOS (A2h, byte 110, bit 1) from presence of valid optical signal. 13. From power on to data ready bit asserted (A2h, byte 110, bit 0). Data ready indicates analog monitoring circuitry is functional. 14. Time from power on until module is ready for data transmission over the serial bus (reads or writes over A0h and A2h). 15. Time from stop bit to completion of a 1 – 4 byte write command. Write cycle time is 80 ms max. for a 5 – 8 byte write. 16. Time between STOP and START Commands. 10 Table 11. Transceiver Digital Diagnostic Monitor (Real Time Sense) Characteristics (Tc = 0 °C to 70 °C, VccT, VccR = 3.3 V ± 5%) Parameter Symbol Min. Units Notes Transceiver Internal Temperature Accuracy TINT ±3.0 °C Temperature is measured internal to the transceiver. Valid from = 0 °C to 85°C case temperature. Transceiver Internal Supply Voltage Accuracy VINT ±0.1 V Supply voltage is measured internal to the transceiver and can, with less accuracy, be correlated to voltage at the SFP Vcc pin. Valid over 3.3 V ± 5%. Transmitter Laser DC Bias Current Accuracy IINT ±10 % IINT is better than ±10% of the nominal value. Transmitted Average Optical Output Power Accuracy PT ±3.0 dB Coupled into single-mode fiber. Valid from 144 µW to 1584 µW, avg. Received Average Optical Input Power Accuracy PR ±3.0 dB Coupled from single-mode fiber. Valid from 24 µW to 1584 µW, avg. V CC T,R > 2.97 V V CC T,R > 2.97 V TX_FAULT TX_FAULT TX_DISABLE TX_DISABLE TRANSMITTED SIGNAL TRANSMITTED SIGNAL t_init t_init t-init: TX DISABLE NEGATED t-init: TX DISABLE ASSERTED V CC T,R > 2.97 V TX_FAULT TX_FAULT TX_DISABLE TX_DISABLE TRANSMITTED SIGNAL TRANSMITTED SIGNAL t_off t_init t_on INSERTION t-init: TX DISABLE NEGATED, MODULE HOT PLUGGED t-off & t-on: TX DISABLE ASSERTED THEN NEGATED OCCURANCE OF FAULT OCCURANCE OF FAULT TX_FAULT TX_FAULT TX_DISABLE TX_DISABLE TRANSMITTED SIGNAL TRANSMITTED SIGNAL t_fault t_reset * SFP SHALL CLEAR TX_FAULT IN < t_init IF THE FAILURE IS TRANSIENT t-fault: TX FAULT ASSERTED, TX SIGNAL NOT RECOVERED t_init* t-reset: TX DISABLE ASSERTED THEN NEGATED, TX SIGNAL RECOVERED OCCURANCE OF FAULT TX_FAULT LOS TRANSMITTED SIGNAL * SFP SHALL CLEAR TX_FAULT IN < t_init IF THE FAILURE IS TRANSIENT t_reset t_fault t_loss_on t_init* t-fault: TX DISABLE ASSERTED THEN NEGATED, TX SIGNAL NOT RECOVERED Figure 4. Transceiver timing diagrams (module installed except where noted) 11 OCCURANCE OF LOSS OPTICAL SIGNAL TX_DISABLE t-loss-on & t-loss-off t_loss_off Table 12. EEPROM Serial ID Memory Contents – Base SFP Memory (Address A0h) Byte # Decimal Data Hex Notes Byte # Decimal Data Hex Notes 0 1 2 3 4 5 6 7 03 04 07 00 00 00 00 12 37 38 39 40 41 42 43 44 00 17 6A 41 46 43 54 2D Hex Byte of Vendor OUI [2] Hex Byte of Vendor OUI [2] Hex Byte of Vendor OUI [2] "A" - Vendor Part Number ASCII character "F" - Vendor Part Number ASCII character "C" - Vendor Part Number ASCII character "T" - Vendor Part Number ASCII character "-" - Vendor Part Number ASCII character 8 9 10 11 00 01 70 06 35 37 46 35 "5" - Vendor Part Number ASCII character "7" - Vendor Part Number ASCII character "F" - Vendor Part Number ASCII character "5" - Vendor Part Number ASCII character 12 8C 54 "T" - Vendor Part Number ASCII character 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 0A 0A 64 00 00 00 00 41 56 41 47 4F 20 20 20 20 45 Single mode optical media 46 400, 800 & 1600 MBytes/sec FC-PI-5 speed [1] 47 64b/66b for 16 GFC & 8b/10b for 8 GFC and 48 4 GFC 140 x 100 MBit/sec nominal bit rate 49 (14.025 Gbit/s) 16/8/4G Independent Tx and Rx Rate Selects 50 10km of single mode fiber 5A 10km of single mode fiber 52 53 54 55 56 "A" - Vendor Part Number ASCII character 57 "V" - Vendor Part Number ASCII character 58 "A" - Vendor Part Number ASCII character 59 "G" - Vendor Part Number ASCII character 60 "O" - Vendor Part Number ASCII character 61 “ ” - Vendor Name ASCII character 62 “ ” - Vendor Name ASCII character 63 “ ” - Vendor Name ASCII character 64 “ ” - Vendor Name ASCII character 65 4D 5A 20 20 20 20 20 20 20 20 05 1E 00 "M" - Vendor Part Number ASCII character "Z" - Vendor Part Number ASCII character “ ” - Vendor Part Number ASCII character “ ” - Vendor Part Number ASCII character “ ” - Vendor Part Number ASCII character “ ” - Vendor Part Number ASCII character “ ” - Vendor Part Number ASCII character “ ” - Vendor Part Number ASCII character “ ” - Vendor Part Number ASCII character “ ” - Vendor Part Number ASCII character Hex Byte of Laser Wavelength [3] Hex Byte of Laser Wavelength [3] 29 30 31 32 33 34 20 20 20 20 20 20 “ “ “ “ “ “ 35 36 20 00 “ ” - Vendor Name ASCII character SFP physical device SFP function defined by serial ID only LC optical connector Long distance (per FC-PI-5), Longwave Laser (LC) ” - Vendor Name ASCII character ” - Vendor Name ASCII character ” - Vendor Name ASCII character ” - Vendor Name ASCII character ” - Vendor Name ASCII character ” - Vendor Name ASCII character Checksum for Bytes 0-62 [4] 00 3A 66 67 68-83 84-91 92 93 00 00 94 95 96-255 05 68 FA Hardware SFP TX_DISABLE, TX_FAULT & RX_LOS, RATE_SELECT Vendor Serial Number ASCII characters [5] Vendor Date Code ASCII characters [6] Digital Diagnostics, Internal Cal, Rx Pwr Avg A/W, Soft SFP TX_DISABLE, TX_FAULT & RX_LOS, RATE_SELECT SFF-8472 Compliance to revision 10.5 Checksum for Bytes 64-94 [4] 00 Notes: 1. 16 GFC [1600 MByte/s] is a serial bit rate of 14.025 Gb/s with 64b/66b. 8 GFC [800 MByte/s] is 8.5 Gb/s and 4 GFC [400 MByte/s] is 4.25 Gb/s with 8b/10b. 2. The IEEE Organizationally Unique Identifier (OUI) assigned to AVAGO Technologies is 00-17-6A (3 bytes of hex). 3. Laser wavelength is represented in 16 unsigned bits. The hex representation of 1310 (nm) is 051E. 4. Addresses 63 and 95 are checksums calculated (per SFF-8472 and SFF-8074) and stored prior to product shipment. 5. Addresses 68-83 specify the AFCT-57F5TMZ ASCII serial number and will vary on a per unit basis. 6. Addresses 84-91 specify the AFCT-57F5TMZ ASCII date code and will vary on a per date code basis. 12 Table 13. EEPROM Serial ID Memory Contents - Enhanced SFP Memory (Address A2h) Byte # Decimal Notes Byte # Decimal Notes Byte # Decimal Notes 0 Temp H Alarm MSB [1] 23 Tx Bias L Warning LSB [3] 99 Real Time Vcc LSB [2] 1 Temp H Alarm LSB [1] 24 Tx Power H Alarm MSB [4] 100 Real Time Tx Bias MSB [3] 2 Temp L Alarm MSB [1] 25 Tx Power H Alarm LSB [4] 101 Real Time Tx Bias LSB [3] 3 Temp L Alarm LSB [1] 26 Tx Power L Alarm MSB [4] 102 Real Time Tx Power MSB [4] 4 Temp H Warning MSB [1] 27 Tx Power L Alarm LSB [4] 103 Real Time Tx Power LSB [4] 5 Temp H Warning LSB [1] 28 Tx Power H Warning MSB [4] 104 Real Time Rx Power MSB [5] 6 Temp L Warning MSB [1] 29 Tx Power H Warning LSB [4] 105 Real Time Rx Power LSB [5] 7 Temp L Warning LSB [1] 30 Tx Power L Warning MSB [4] 106 Reserved 8 Vcc H Alarm MSB [2] 31 Tx Power L Warning LSB [4] 107 Reserved 9 Vcc H Alarm LSB [2] 32 Rx Power H Alarm MSB [5] 108 Reserved 10 Vcc L Alarm MSB [2] 33 Rx Power H Alarm LSB [5] 109 Reserved 11 Vcc L Alarm LSB [2] 34 Rx Power L Alarm MSB [5] 110 Status/Control – See Table 14 12 Vcc H Warning MSB [2] 35 Rx Power L Alarm LSB [5] 111 Status/Control – See Table 15 13 Vcc H Warning LSB [2] 36 Rx Power H Warning MSB [5] 112 Flag Bits – See Table 16 14 Vcc L Warning MSB [2] 37 Rx Power H Warning LSB [5] 113 Flag Bits – See Table 16 15 Vcc L Warning LSB [2] 38 Rx Power L Warning MSB [5] 114 Reserved 16 Tx Bias H Alarm MSB [3] 39 Rx Power L Warning LSB [5] 115 Reserved 17 Tx Bias H Alarm LSB [3] 40-55 Reserved 116 Flag Bits – See Table 16 18 Tx Bias L Alarm MSB [3] 56-94 External Calibration Constants [6] 117 Flag Bits – See Table 16 19 Tx Bias L Alarm LSB [3] 95 Checksum for Bytes 0-94 [7] 118 Status/Control – See Table 17 20 Tx Bias H Warning MSB [3] 96 Real Time Temperature MSB [1] 119-127 Reserved 21 Tx Bias H Warning LSB [3] 97 Real Time Temperature LSB [1] 128-247 Customer Writable – See Table 18 22 Tx Bias L Warning MSB [3] 98 Real Time Vcc MSB [2] 248-255 Vendor Specific Notes: 1. Temperature (Temp) is decoded as a 16 bit signed two’s complement integer in increments of 1/256 °C. 2. Supply Voltage (Vcc) is decoded as a 16 bit unsigned integer in increments of 100 V. 3. Tx bias current (Tx Bias) is decoded as a 16 bit unsigned integer in increments of 2 A. 4. Transmitted average optical power (Tx Pwr) is decoded as a 16 bit unsigned integer in increments of 0.1 W. 5. Received average optical power (Rx Pwr) is decoded as a 16 bit unsigned integer in increments of 0.1 W. 6. Bytes 56-94 are not intended for use, but have been set to default values per SFF-8472. 7. Byte 95 is a checksum calculated (per SFF-8472) and stored before product shipment. Table 14. EEPROM Serial ID Memory Contents – Soft Commands (Address A2h, Byte 110) Bit # Status/Control Name Description Notes 7 TX_DISABLE State Digital state of TX_DISABLE Input Pin (1 = TX_DISABLE asserted) Note 1 6 Soft TX_DISABLE Control Read/write bit for changing digital state of TX_DISABLE function Note 1, 2 5 RS(1) State Digital state of TX Rate_Select Input Pin RS(1) (1 = Rate High asserted) 4 RS(0) State Digital state of RX Rate_Select Input Pin RS(0) (1 = Rate High asserted) 3 Soft RS(0) Control Read/write bit for changing digital state of Rx Rate_Select RS(0) function Note 3 2 TX_FAULT State Digital state of TX_FAULT Output Pin (1 = TX_FAULT asserted) Note 1 1 RX_LOS State Digital state of SFP RX_LOS Output Pin (1 = RX_LOS asserted) Note 1 0 Data Ready (Bar) Indicates transceiver is powered and real time sense data is ready (0 = Data Ready) Notes: 1. The response time for soft commands of the AFCT-57F5TMZ is 100msec as specified by MSA SFF-8472. 2. Bit 6 is logic OR’d with the SFP TX_DISABLE input pin 3 …. either asserted will disable the SFP transmitter. 3. Bit 3 is logic OR’d with the SFP RS(0) RX Rate_Select input pin 7 …. either asserted will set receiver to Rate = High. 13 Table 15. EEPROM Serial ID Memory Contents – Soft Commands (Address A2h, Byte 111) Byte 111 (Bin) Name Description 1100 OWRAP FORWARD When enabled, OWRAP FORWARD routes incoming SFP Rx optical data to both the Tx optical output and the Rx electrical output. 0100 OWRAP When enabled, OWRAP routes incoming SFP Rx optical data to the Tx optical output. 0011 EWRAP FORWARD When enabled, EWRAP FORWARD routes incoming SFP Tx electrical data to both Rx electrical utput and Tx optical output. 0001 EWRAP When enabled, EWRAP routes incoming SFP Tx electrical data to the Rx electrical output. 0000 RESET Disable any EWRAP/OWRAP mode. Any settings other than Invalid those reported above Any invalid setting is ignored and leaves unchanged the previous EWRAP/OWRAP mode. Table 16. EEPROM Serial ID Memory Contents – Alarms and Warnings (Address A2h, Bytes 112, 113, 116, 117) Byte Bit Flag Bit Name Description 112 7 Temp High Alarm Set when transceiver internal temperature exceeds high alarm threshold 6 Temp Low Alarm Set when transceiver internal temperature exceeds low alarm threshold 5 Vcc High Alarm Set when transceiver internal supply voltage exceeds high alarm threshold 4 Vcc Low Alarm Set when transceiver internal supply voltage exceeds low alarm threshold 3 Tx Bias High Alarm Set when transceiver laser bias current exceeds high alarm threshold 2 Tx Bias Low Alarm Set when transceiver laser bias current exceeds low alarm threshold 1 Tx Power High Alarm Set when transmitted average optical power exceeds high alarm threshold 0 Tx Power Low Alarm Set when transmitted average optical power exceeds low alarm threshold 7 Rx Power High Alarm Set when received average optical power exceeds high alarm threshold 6 Rx Power Low Alarm Set when received average optical power exceeds low alarm threshold 0-5 Reserved 7 Temp High Warning Set when transceiver internal temperature exceeds high warning threshold 6 Temp Low Warning Set when transceiver internal temperature exceeds low warning threshold 5 Vcc High Warning Set when transceiver internal supply voltage exceeds high warning threshold 4 Vcc Low Warning Set when transceiver internal supply voltage exceeds low warning threshold 3 Tx Bias High Warning Set when transceiver laser bias current exceeds high warning threshold 2 Tx Bias Low Warning Set when transceiver laser bias current exceeds low warning threshold 1 Tx Power High Warning Set when transmitted average optical power exceeds high warning threshold 0 Tx Power Low Warning Set when transmitted average optical power exceeds low warning threshold 7 Rx Power High Warning Set when received average optical power exceeds high warning threshold 6 Rx Power Low Warning Set when received average optical power exceeds low warning threshold 0-5 Reserved 113 116 117 Table 17. EEPROM Serial ID Memory Contents – Soft Commands (Address A2h, Byte 118) Bit # Status/Control Name Description Notes 4-7 Reserved 3 Soft RS(1) Control Read/write bit for changing digital state of Tx Rate_Select RS(1) function Note 1 2 Reserved 1 Power Level State Always set to zero. Value of zero indicates Power Level 1 operation (1 W max) 0 Power Level Select Unused. This device supports power level zero (1 W max) only. Notes: 1. Bit 3 is logic OR’d with the SFP RS(1) TX Rate_Select input pin 9 …. either asserted will set transmitter to Rate = High. 14 Table. 18. Signal Integrity Feature Configuration Bytes (2-Wire Address A2h) Byte Name Description 40 Tx Input EQ Setting for RS(1) = High Defines SFP incoming electrical Tx equalization setting for Tx_Rate = High [i.e., RS(1)=High] The SFP transceiver will support 8 EQ settings in the lower 3 bits of this byte. EQ can be varied from 0 dB to 9 dB gain at 7 GHz in eight non-linear steps. The value of 0 results in 0 dB emphasis. Writing FFh to this byte and power cycling both reset the byte to factory settings, which is 02h. 41 Tx Input EQ Setting for RS(1) = Low Defines SFP incoming electrical Tx equalization setting for Tx_Rate = Low [i.e., RS(1)=Low] The SFP transceiver will support 8 EQ settings in the lower 3 bits of this byte. EQ can be varied from 0 dB to 9 dB gain at 7 GHz in eight non-linear steps. The value of 0 results in 0 dB emphasis. Writing FFh to this byte and power cycling both reset the byte to factory settings, which is 04h. 42 Rx Output Pre Emphasis Setting for RS(0) = High Defines SFP output electrical Rx pre-emphasis setting for Rx_Rate = High [i.e., RS(0)=High] The SFP transceiver will support 16 Pre Emphasis settings in the lower 4 bits of this byte. Emphasis can be varied from 0 dB to 9 dB in sixteen non-linear steps. The value of 0 results in 0 dB emphasis. Writing FFh to this byte resets to factory settings. Writing FFh to this byte and power cycling both reset the byte to factory settings, which is 04h. 43 Rx Output Pre Emphasis Setting for RS(0) = Low Defines SFP output electrical Rx pre-emphasis setting for Rx_Rate = Low [i.e., RS(0)=Low] The SFP transceiver will support 16 Pre Emphasis settings in the lower 4 bits of this byte. Emphasis can be varied from 0 dB to 9 dB in sixteen non-linear steps. The value of 0 results in 0 dB emphasis. Writing FFh to this byte resets to factory settings. Writing FFh to this byte and power cycling both reset the byte to factory settings, which is 02h. 44-55 Unallocated Contents 00h. Note: Checksum at address A2h byte 95 will be updated within 100ms of a value change in these bytes. 8.9 47.5 13.9 0.77 UNCOMPRESSED 6.25 12.95 8.55 13.65 13.46 Figure 6. Module drawing Figure 7. Product Label For product information and a complete list of distributors, please go to our website: www.avagotech.com Avago, Avago Technologies, and the A logo are trademarks of Avago Technologies in the United States and other countries. Data subject to change. Copyright © 2005-2013 Avago Technologies. All rights reserved. AV02-3785EN - July 29, 2013
AFCT-57F5TMZ 价格&库存
很抱歉,暂时无法提供与“AFCT-57F5TMZ”相匹配的价格&库存,您可以联系我们找货
