F2M03AC2-103
F2M03AC2-103
    FREE2MOVE
    Module
    RF TXRX MOD BLUETOOTH CHIP ANT
F2M03AC2-103 数据手册
CLASS 2 BLUETOOTH® MODULE - F2M03AC2 FEATURES • Complete Bluetooth system including antenna • Includes complete audio codec • Available with complete Bluetooth software stack • Headset functionality available • Wireless UART functionality without extra protocol • Serial interface, 8 digital and 2 analog I/O • • Analog and digital (PCM) voice interface for up to 3 simultaneous GENERAL DESCRIPTION voice channels This module is a Class 2 surface mount- Nominal 20 m range, transmit Power up to +4 dBm • Full Bluetooth data rate over UART and USB able Bluetooth system. The module includes antenna and an audio codec for conversion between analog and digital voice. It provides a fully compliant device for data and voice communications. The • 4 low power modes • Surface mountable, physical size: USB) can support full Bluetooth data 24x13 mm rate of 723.2kbps. An analog voice physical interfaces to a host (UART and • Bluetooth v1.1 compliant interface and a PCM synchronous bidirectional digital audio interface are available. There are also digital and APPLICATIONS Prototyping and volume production of: analog I/O and I2C interfaces. The module is available with a number of different firmware versions: The Wireless UART firmware implements the • Wireless headsets • Audio applications • Industrial and domestic appliances • Stand alone sensors the connected remote device. • Embedded systems Other firmware versions are: Headset, • Mobile phones Serial Port Profile (SPP) with an easy to use command interface. All information sent to the serial interface is transmitted transparently via Bluetooth to HCI, RFCOMM and the possibility to get customized standalone applications implemented on the module. BLUETOOTH is a trademark owned by Bluetooth SIG, Inc., U.S.A. and licensed to Free2move. © Free2move www.free2move.se 2003.11
F2M03AC2-103 价格&库存
很抱歉,暂时无法提供与“F2M03AC2-103”相匹配的价格&库存,您可以联系我们找货
