PIR FRESNEL LENS_FIR05-01-WHITE 数据手册
.Inc
Tel: +82-70-7605-0693, Email: ashton@Fresnel Factory.com,
www.FresnelFactory.com
504, Sungsin Techno Park, , Yeongtong-ro 323beon-gil 38,
Yeongtong-gu, Suwon-si, Gyeonggi-do, Republic of Korea
FIR05-04
Product Specification
1. Dimensions
Unit : mm
General tolerance : ±0.2 mm
FresnelFactory.Inc
2. Field of view
10°
10°
30°
10°
1
TOP VIEW
SIDE VIEW
www.Fresnel Factory.com
504, Sungshin Techno Park, Yeongtong323beongil, Yeongtong-gu,
Suwon-si, Gyeonggi-do, South Korea
3. Material for PIR/FIR(8~13um) wavelength
The thermopile and passive infrared sensor that is using for motion sensor detects
the wavelength of 8~13um.
Without Fresnel lens, the sensor only can detect less than 1m distance and narrower
space with lens. To work with Pyroelectronic detector and thermopile, Fresnel lens
that collects infrared rays as a sensor is required. Fresnel Factory manufactures Fresnel
lenses for passive infrared and absolute temperature sensors.
3-1) Poly FIR 25
(Graph3 – Transmittance of PIR, FIR(Far infrared) material)
Material is important to have a wide FOV and excellent Far Infrared transmittance. Therefore, Fresnel
Factory is using Poly FIR200 and Poly FIR25, which have a wide FOV and excellent FIR transmittance
Transmittance (%)
Material name
8~13um
Poly FIR25
19.24% at 0.50T
The FIR (Far-Infrared) sensor detects temperature by measuring infrared emitted from an
object and is used in thermal imaging cameras. The transmittance of Poly FIR25 in the
8~13um wavelength is 19.24% on average, which is lower than that of Poly FIR200.
However, Poly FIR25 has better Hardness and high resistance of temperature.
Properties
Max tensile
*Impact
strength
strength
26Mpa
70J/m
*Hardness
*HDT(0.45Map)
Meltflow Rate
Rockwell M scale 70
130℃
2.5g/min
Poly FIR25 has higher tensile strength, impact strength, and HDT than Poly FIR200. Due to
the above properties, Poly FIR25 is used for temperature sensing sensors exposed to high
temperatures despite low transmittance.
Reference
*HDT(Heat Deflection Temperature) : It exhibits heat resistance at a specific temperature when the sample has
displacement of 2.5mm under a specific load.
*Hardness : Abrasion resistance
*Izod Impact strength : Impact resistance
PIR FRESNEL LENS_FIR05-01-WHITE 价格&库存
很抱歉,暂时无法提供与“PIR FRESNEL LENS_FIR05-01-WHITE”相匹配的价格&库存,您可以联系我们找货
