NIR FRESNEL LENS_NF26-25-BLACK 数据手册
.Inc
Tel: +82-70-7605-0693, Email: ashton@Fresnel Factory.com,
www.FresnelFactory.com
504, Sungsin Techno Park, , Yeongtong-ro 323beon-gil 38,
Yeongtong-gu, Suwon-si, Gyeonggi-do, Republic of Korea
NF26-25
Product Specification
1. Dimensions
Ø25.0
A
A
1.5
단면 A-A
Unit : mm
General tolerance : ±0.05mm
www.Fresnel Factory.com
504, Sungshin Techno Park, Yeongtong323beongil, Yeongtong-gu,
Suwon-si, Gyeonggi-do, South Korea
3. Material for NIR(Near Infrared) wavelength
100
Poly NIR212
95
90
85
80
75
Transmittance (%)
70
65
60
55
50
Poly NIR212
45
40
35
30
25
10
5
200 300 400 500 600 700 800 900 1000110012001300140015001600170018001900200021002200230024002500
Wavelength (nm)
(Graph2 – Transmittance of NIR(near infrared) material)
3-1) Poly NIR212
Transmittance
Material name
UV and Visible(280~750nm)
NIR(750~1,400nm)
Poly NIR212
6.96%
91.46%
Poly NIR212 shows very excellent transmittance in the NIR (750~1400nm) and blocks most of
the UV and visible Wavelength. It blocks 93.07% of UV and visible wavelength and shows an
average transmittance of 91.46% in the main wavelength of Near Infrared.
Poly NIR212 not only has high transmittance of NIR, but also acts as a band pass filter of
visible wavelength to prevent malfunction of the photo diode. Poly NIR212 is produced and
supplied by custom-made, and mainly produced by injection method.
Properties
Max tensile
*Impact
strength
strength
62Mpa
694J/m
*Hardness
*HDT(0.45Map)
Melt Flow rate(230/3.8kg)
Rockwell M sale 70
137℃
20g/10min
Poly NIR212 has excellent tensile strength, impact strength, hardness and HDT. Fresnel Factory
uses Poly NIR212 for NIR sensing devices exposed to high temperatures and vibrations in the
vehicle during summer.
Reference
*HDT(Heat Deflection Temperature) : It exhibits heat resistance at a specific temperature when the sample has
displacement of 2.5mm under a specific load.
*Hardness : Abrasion resistance
*Izod Impact strength : Impact resistance
NIR FRESNEL LENS_NF26-25-BLACK 价格&库存
很抱歉,暂时无法提供与“NIR FRESNEL LENS_NF26-25-BLACK”相匹配的价格&库存,您可以联系我们找货
