GS1011MIP-EVK2-S2W-WEB
    TELITWIRELESSSOLUTIONS(泰利特)
    EVAL BOARD 802.11
GS1011MIP-EVK2-S2W-WEB 数据手册
T BRIEF PR O D UCT B RI E F GainSpan GS1011M EVK Mrk II Evaluation Kit PRODUCT OVERVIEW The GS1011M EVK Mrk II Evaluation Kit provides GainSpan customers the means to evaluate capabilities of the GS1011 ultra-low power wireless system-on-a-chip and the Serial-to-WiFi embedded software for Wi-Fi networks. The Serial-to-WiFi embedded software allows devices and appliances manufacturers to easily add Wi-Fi capabilities to their products with minimal impact on host microcontroller firmware. The GS1011M EVK Mrk II Evaluation Kit provides all the hardware and software necessary to quickly set up a serial (UART or SPI) based link to a PC or external microcontroller. In order to evaluate the ease of adding secure Wi-Fi communications to a product using the GainSpan AT command set, the kit includes all the software tools necessary for configuration of Serial-to-Wi-Fi and GS1011M modules, data transfer using “AT” command-set and protocol analyzer for validation of packet & frame fields. For additional details on the module features, please refer to the GS1011M module product briefs. Host Microcontroller Embedded Application Serial-to-WiFi “Driver” GS1011M SPI or UART Serial-to-WiFi Power Management SSL HTTP Server TCP/IP Device Drivers RTOS WPA/2 WPS 802.11 MAC BENEFITS: • GS1011M highly integrated ultra- low power 802.11b Wi-Fi radio Family of modules • Easy integration of Wi-Fi and web connectivity to devices with existing microcontroller and UART or SPI interface • Easy device provisioning through LimitedAP (embedded web pages) or Wi-Fi Protected Set-up (WPS) • Serial to Wi-Fi firmware allows easy addition of Wi-Fi capabilities to embedded system • Offloads Wi-Fi and TCP/ IP networking from smaller host microcontrollers • Simple AT commands for configuration and data communication • Support for over the air firmware updates using external flash FEATURES: • • The GS1011M EVK Mrk II Evaluation Kit enables GainSpan customers to develop software on their existing microcontrollers to support the “AT” command set, and connect it to either the UART or SPI interface on the evaluation kit reference board. • Push button for Alarms and Firmware Restore from External Flash • Full Wi-Fi and networking stack services including TCP/UDP/IP, DNS, DHCP, HTTP and SSL • Wi-Fi Security • . Supports Infrastructure, Limited AP and Adhoc networking Two UART and SPI ports. Clock Data rates are o UART: up to 921 Kbps o SPI: up to 3 Mbps o WEP, WPA/WPA2 Personal o WPA/WAP2 Enterprise o Wi-Fi Protected Setup (WPS 2.0) Power Save Modes – PS-Poll, Sleep, Deep Sleep, Standby PR O D UCT B RI E F AT COMMAND SET The ‘AT’ command set supports the full range of capabilities provided by the underlying GainSpan network services software that abstract the complexity of IP networking and Wi-Fi communication from the embedded application, allowing complete control. Types Commands Serial Interface Configuration Set Serial Parameters (baud rate, flow control) Profile Management Load/Save/Restore profiles Wi-Fi Interface Scan/associate/disassociate Security Enable/set security Network Management Static or DHCP client/server, DNS client/server Connection management UDP/TCP/HTTP client/server Power management Enable/disable PS-Poll, deep sleep and standby Services Upgrade firmware EVALUATION BOARD SPECIFICATIONS Feature Description Radio Protocol IEEE 802.11b (IEEE 802.11 b/g/n Compatible) RF Module GS1011M Ultra-Low Power Module Family (GS1011MIP, GS1011MIE, GS1011MEP, GS1011MEE) RF Output Power (Typical) 8 dBm (GS1011MIx), 18 dBm (GS1011MEx) Radio Frequency 2.412 – 2.484 GHz Antenna Type PCB Trace (GS1011MxP) or u.FL connector for external antenna (GS1011MxE) I/O Port 6-pin serial UART interface, 15540 compatible; DB9 RS232 Connector; SPI Power Source 1.5 V Lithium Batteries (2x) or External Power Adapter GS1011M Firmware Serial to Wi-Fi (default); Temperature and light sensor (TLS) Application Dimensions 3.5 in X 3.0 in (includes module and RS232 connector) EVALUATION KIT CONTENTS ITEM Description GS1011M Evaluation Board Evaluation board based on low power GS1011M module USB Memory Stick Installation software for firmware, Documentation, Tools and Utilities Batteries Two 1.5V Lithium AA Batteries Wi-Fi Access Point Off the Shelf Wi-Fi Access Point for out of box functionality Cable 6-pin serial UART to USB cable to connect to host PC Software Tools TeraTerm --- Open Source Serial Terminal Emulator Wireshark --- Open Source, Network Protocol Analyzer GSDemo – GainSpan tool to demonstrate TLS application GS Flash Program --- GainSpan tool for Firmware Upgrade Documentation Quick Start Guide, Programmers Guide, Schematics EVALUATION KIT ORDERING INFORMATION ITEM PART NUMBER GS1011M EVK Mrk II Evaluation Kit GS1011MIP-EVK2-S2W-WEB GS1011MEP-EVK2-S2W-WEB GS1011MIE-EVK2-S2W-WEB GS1011MEE-EVK2-S2W-WEB © 2011. GainSpan Corporation; http://www.gainspan.com• info@gainspan.com GS1011M EVK PB 2.0 Description Serial to Wi-Fi Evaluation kit based on the ultra-low power GS1011M module base board. The Serial to Wi-Fi firmware supports embedded webserver for provisioning @GainSpan
GS1011MIP-EVK2-S2W-WEB 价格&库存
很抱歉,暂时无法提供与“GS1011MIP-EVK2-S2W-WEB”相匹配的价格&库存,您可以联系我们找货
