Information Technology Solutions
SPB105-WiFi 802.11b+g SPI Evaluation kit Card
Home Automation
Lowest power consumption solution in the
The SPB105 WiFi solution and
market for embedded applications.
the AVR32 EVK1105 is a quick
start for developers that want to
High RF output TX power and RX
enter the home automation
sensitivity
market such as AMR,
surveillance, entrance control or
general home appliances.
Supports SPI serial interface.
Is delivered fully tested and calibrated
Industry Sensor Networks
WiFi in combination with AVR32
Support for both external antenna or
can easily be installed and used
internal chip antenna by the use of a
for Industry sensors or remote
control because of the pre-
switching antenna connector.
Photo: SPB105 – WiFi 802.11b+g SPI Evaluation kit Card
integration of the EVK and the
availability of WiFi infrastructure.
Media Applications
In all media applications the
problem of how to access and
change the media is easily
solved with WiFi and due to the
high speed and security
functions of 802.11, media such
as mp3, IP-radio or video are
transferred fast and secure.
H&D Wireless AB, official
Atmel Wi-Fi partner
The SPB105 is a complete WLAN card for evaluation and
development on platforms like the Atmel EVK1105 using
the AVR32 CPU. The SPB105 includes the WiFi
component HDG104 from H&D Wireless AB and enables
developers to evaluate and develop their own wireless
applications based on the 802.11bg standard compliant
HDG104 and the feature rich AVR32 platform from Atmel.
The HDG104 enables a cost efficient ultra low power,
high performance and feature rich WiFi client solution. It
provides up to 54 Mbit/s data rate when operating in the
OFDM mode and up to 11 Mbit/s data rate when
operating in the DSSS/CCK mode.
HDG104 integrates RF IC, baseband/MAC IC, EEPROM
and RF filters into a highly integrated and optimized SIP
(System In Package) solution with high quality and
reliability. This minimizes the need of external
components, simplifying assembly and test.
This highly integrated solution is optimized for customer
applications running on a host CPU. The host interface
supports SPI serial interface. Internal RAM comprises
both code and data memory eliminating the need for
external RAM, Flash or ROM memory interfaces.
Baseband
firmware, FW, is stored on the host and downloaded at
start up. MAC address, trimming values etc are stored in
the on board EEPROM.
• Data Rates: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48,
and 54Mbps
• Modulation: QPSK, 16QAM, 64QAM DBPSK,
DQPSK, CCK, OFDM with BPSK
• WEP and AES hardware encryption accelerator up
to 128 bit.
• On-chip RF filter for the ISM band 2.4GHz
• An internal 32 kHz oscillator maintains real time in
power save mode, allows the high frequency clock to
be turned off.
• Extensive DMA hardware support for data flow to
reduce CPU load.
• Low cost and low power consumption by use of Ultra
Low Power (ULP) technology
• On-board 160 kB SRAM and 1 kB EEPROM
eliminates need for external FLASH, RAM and
EEPROM for firmware
• Internal Boot-ROM. This allows firmware to be
downloaded into SRAM from the host
• Advanced power management for optimum power
consumption at varying load.
• External interfaces SPI and UART
• Supply voltage 2.75-3.6 V
• RoHS Compliant
H&D Wireless AB, Sweden 1452-ARO105
”What Do You Want To Connect?” ©
Pre-Integrated Development Kit
The SPB105 is fully tested and calibrated and is targeted for a good
TECHNICAL SUPPORT
“out-of-the-box” experience together with the AVR32 platforms such
Support for the SW drivers,
as the EVK1104.
installation and SW development
The SPB105 has full driver support integrated into the AVR32
is provided by Atmel application
Software Framework and is fully tested for 802.11bg compliance on
support at
the EVK1105 platform, see www.atmel.com/avr32.
Developers within minutes start to concentrate on the development
of their application with the rich support from the SPB105 and
EVK1105 kit for sensor control, IP-radio and other data and media
Performance of WiFi
applications. The pre-integrated solution has support for IP-stacks,
The WiFi solution provided with
web-server, ftp, sensor clients and more. The user has access to the
SPB105 and HDG104 are best in
H&D Wireless API for the WiFi control and is supplied with well
class and market leader is terms
of solution size, power
documented reference designs in source code such as web-servers.
* Photo of the SPB105 connected with of the SPI-card interface on the EVK1105. Ready-made downloadable reference designs can be started within minutes
and development can start at once.
consumption in all modes,
transmit/receive range, data
transfer speed and cost.
TURNKEY SOLUTIONS
The reference designs provided
Performance data
SERVICES AVAILABLE
Technical Support
are turnkey solutions that will
Software and Setup
work first time and can be
Hardware Support
modified and used for customers
Application Support
own products.
Customer application development
For more information on any of
our products or services please
visit us on the Web at:
www.atmel.com or
www.hd-wireless.se
H&D Wireless AB
Norgegatan 1
164 32 Kista, SWEDEN
Phone +46-8-55118460
Fax +46-8-7509977
Atmel Wi-Fi partner
很抱歉,暂时无法提供与“SPB105-AK-1”相匹配的价格&库存,您可以联系我们找货
