R100-202-035
R100-202-035
    HAMMONDMANUFACTURING
    金属 - 铝 盒 灰色 分叉式双侧 11.810" 长 x 7.870" 宽(299.97mm x 199.90mm) X 4.720"(119.89mm)
R100-202-035 数据手册
7/6/2021 Type 4X Diecast Aluminum Enclosures (R100 Series) - Hammond Mfg. Quality Products. Service Excellence. Type 4X Diecast Aluminum Enclosures R100 Series aluNORM - Watertight, Thick Wall Key Features: Material - Aluminum die-cast: G AI SI 12 / DIN 1775 Shallow lid, deep body Captive stainless steel lid screws Neoprene oil and petrol resistant gasket standard. (-40ºC up to +80ºC) Degree of protection NEMA 4X, IP66, DIN 40050 Temperature Range (-40ºC up to +80ºC) Single-channel Fastening System Special developed external mounting feet made from zinc-die-cast. Can be turned through 90º. The fastening holes have engagement lugs for this purpose. (See accessories) All sizes have inner blind holes. An inner mounting panel - made of zinc-plated steel is also available (See accessories) Textured polyester powder coat, beige RAL7032 or light gray RAL7035. (can be supplied     unpainted on special order) CSA certified, UL Listed, Type 4, for use with industrial control equipment. Features 1. Lid screws and mounting holes outside of the gasket seal. https://www.hammfg.com/electronics/small-case/diecast/r100 1/4 7/6/2021 Type 4X Diecast Aluminum Enclosures (R100 Series) - Hammond Mfg. 2. Space saving single channel mounting (ie...same hole used for mounting enclosure through rear and also for the lid), provides larger interior space than dual channel enclosures. 3. Captive stainless steel lid screws. 4. Enclosure holes threaded for easy installation and repetitive assembly & disassembly. 5. Internal mounting shelves placed along both sides of enclosure include blind holes and grounding screws. Patented Single Channel System Provides larger interior space than dual channel enclosures. Uses the same enclosure hole for mounting the enclosure and fastening the lid. Accessories (see table below for compatibility) External Mounting Inner Panel Hinge Kit Feet Shallow Lid, Deep Body (R100 Series) Part No (RAL 7032 Beige) Part No (RAL 7035 Light Gray) R100-060-000 R100-060-035 65 50 40 R100-062-000 R100-062-035 65 65 40 R100-064-000 R100-064-035 65 100 40 R100-066-000 R100-066-035 65 150 40 R100-080-000 R100-080-035 80 80 60 R100-082-000 R100-082-035 80 120 60 R100-084-000 R100-084-035 80 160 60 R100-100-000 R100-100-035 100 100 80 R100-102-000 R100-102-035 100 150 80 R100-104-000 R100-104-035 100 200 80 R100-120-000 R100-120-035 120 120 100 R100-122-000 R100-122-035 120 180 100 R100-124-000 R100-124-035 120 240 100 R100-160-000 R100-160-035 160 160 100 R100-162-000 R100-162-035 160 240 100 R100-164-000 R100-164-035 160 320 100 R100-166-000 R100-166-035 160 480 100 R100-200-000 R100-200-035 200 200 120 R100-202-000 R100-202-035 200 300 120 R100-204-000 R100-204-035 200 400 120 R100-240-000 R100-240-035 240 240 120 https://www.hammfg.com/electronics/small-case/diecast/r100 Width Length Depth (Including Lid) 2/4 7/6/2021 Type 4X Diecast Aluminum Enclosures (R100 Series) - Hammond Mfg. Part No (RAL 7032 Beige) Part No (RAL 7035 Light Gray) R100-242-000 R100-242-035 Width Length 240 360 Depth (Including Lid) 120 R100-244-000 R100-244-035 240 480 120 R100-320-000 R100-320-035 320 320 120 R100-322-000 R100-322-035 320 480 120 R100-324-000 R100-324-035 320 640 120 Deep Lid, Shallow Body (R101 Series) Part No. Width Length Depth (Including Lid) R101-080-000¹ 80 80 60 R101-082-000¹ 80 120 60 R101-084-000¹ 80 160 60 R101-100-000¹ 100 100 80 R101-102-000¹ 100 150 80 R101-104-000¹ 100 200 80 R101-120-000¹ 120 120 100 R101-122-000¹ 120 180 100 R101-124-000¹ 120 240 100 R101-160-000¹ 160 160 100 R101-162-000¹ 160 240 100 R101-164-000¹ 160 320 100 R101-166-000¹ 160 480 100 R101-200-000¹ 200 200 120 R101-202-000¹ 200 300 120 R101-204-000¹ 200 400 120 R101-240-000¹ 240 240 120 R101-242-000¹ 240 360 120 R101-244-000¹ 240 480 120 R101-320-000¹ 320 320 120 R101-322-000¹ 320 480 120 R101-324-000¹ 320 640 120 ¹ R101 series enclosures are not stocking items. Please contact Hammond's sales team for more information. Matching Lid & Body (R102 Series) Part No. Width Length Depth (Including Lid) R102-080-000¹ 80 80 40 R102-082-000¹ 80 120 40 R102-084-000¹ 80 160 40 R102-100-000¹ 100 100 54 R102-102-000¹ 100 150 54 R102-104-000¹ 100 200 54 R102-120-000¹ 120 120 66 R102-122-000¹ 120 180 66 R102-124-000¹ 120 240 66 R102-160-000¹ 160 160 66 R102-162-000¹ 160 240 66 R102-164-000¹ 160 320 66 R102-166-000¹ 160 480 66 R102-200-000¹ 200 200 80 R102-202-000¹ 200 300 80 R102-204-000¹ 200 400 80 R102-240-000¹ 240 240 80 R102-242-000¹ 240 360 80 R102-244-000¹ 240 480 80 R102-320-000¹ 320 320 80 R102-322-000¹ 320 480 80 https://www.hammfg.com/electronics/small-case/diecast/r100 3/4 7/6/2021 Type 4X Diecast Aluminum Enclosures (R100 Series) - Hammond Mfg. Part No. R102-324-000¹ Width Length Depth (Including Lid) 320 640 80 ¹ R102 series enclosures are not stocking items. Please contact Hammond's sales team for more information. aluNORM Accessories External Feet Inner Panel 2mm, Hinge For Use With (Set of 2 or 4) Galvanized Steel (Set of 2) Enclosure Types Part No. Part No. Part No. R100, R101 & R102-060 N/A N/A N/A R100, R101 & R102-062 N/A R507-062-000 N/A R100, R101 & R102-064 N/A R507-064-000 N/A R100, R101 & R102-066 N/A R507-066-000 N/A R100, R101 & R102-080 R501-002-080 R507-080-000 N/A R100, R101 & R102-082 R501-002-080 R507-082-000 N/A R100, R101 & R102-084 R501-002-080 R507-084-000 N/A R100, R101 & R102-100 R501-002-100 R507-100-000 N/A R100, R101 & R102-102 R501-002-100 R507-102-000 R510-000-000 R100, R101 & R102-104 R501-002-100 R507-104-000 R510-000-000 R100, R101 & R102-120 R501-000-011 R507-120-000 R510-000-000 R100, R101 & R102-122 R501-000-011 R507-122-000 R510-000-000 R100, R101 & R102-124 R501-000-011 R507-124-000 R510-000-000 R100, R101 & R102-160 R501-000-012 R507-160-000 R510-000-000 R100, R101 & R102-162 R501-000-012 R507-162-000 R510-000-000 R100, R101 & R102-164 R501-000-012 R507-164-000 R510-000-000 R100, R101 & R102-166 R501-000-012 R507-166-000 R510-000-000 R100, R101 & R102-200 N/A R507-200-000 R510-000-000 R100, R101 & R102-202 N/A R507-202-000 R510-000-000 R100, R101 & R102-204 N/A R507-204-000 R510-000-000 R100, R101 & R102-240 N/A R507-240-000 R510-000-000 R100, R101 & R102-242 N/A R507-242-000 R510-000-000 R100, R101 & R102-244 N/A R507-244-000 R510-000-000 R100, R101 & R102-320 N/A R507-320-000 R510-000-000 R100, R101 & R102-322 N/A R507-322-000 R510-000-000 R100, R101 & R102-324 N/A R507-324-000 R510-000-000 Data subject to change without notice © 2021. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/small-case/diecast/r100 4/4
R100-202-035 价格&库存
很抱歉,暂时无法提供与“R100-202-035”相匹配的价格&库存,您可以联系我们找货
R100-202-035
    • 1+1234.65090
    库存:1
