Data sheet
HERZ
Hot air blower COMPACT max. 6’100W
Function:
Configuration:
Features:
Power:
Voltage:
Hot air blowers for industrial use
small dimensions great power
Default: Temperature control with potentiometer (0 - 9)
alternatively with external potentiometer (cable length 5 meters) or
external control by controller or PLC (cable length 5 meters)
The unit is equipped with a reliable heating element, the integrated device
protection turns off the device when tripped and restore itself back after cooling. No
reset is required.
Default: Variable air volume control with potentiometer (0 - 9)
Custom design with internal thermocouple (cable length 1 or 5 meters)
For devices with electronics maximum air temperature 50°C/122°F
The unit is available without electronics
For devices without electronics maximum air temperature 80°C/176°F
Special design with internal temperature control
Evaluating the fan speed via "open collector"
2,3 KW - 6,1 KW
230 / 400VAC (2Ph)
Technical data
Item number / Basic version
Voltage
Frequency
Power
Current
Max. temperatuer
Min. air quantiry
Max. air quantity at 20°C
Max. Temperature with full air quantity
Static pressure
Sound pressure levell (LpA)
Intake opening
Air outlet
Heating element tube
Dimensions (L x W x H)
Weight incl. Cable
Conformity mark
VAC
Hz
kW
A
°C/°F
l/min
l/min
°C/°F
Pa
db
Ø mm
Ø mm
Ø mm
mm
kg
Power curve
5102586
5102602
230
2,3
10,0
650/1202
400
940
260/500
3,1
13,5
800/1472
350
800
520/968
325x136x180
2,8
5102581
50 / 60
3,7
16,0
5102605
5102599
400 (2Ph+N)
4,7
11,8
650/1202
6,1
15,3
400
550
930
960
950
440/824
480/896
630/1166
450
73 (at 1m distance)
102,5
55
62 / 74
365x136x180 325x136x180
365x136x180
3,1
2,8
3,1
Protection class II
DB Compact V20 R17 02_2021 GB.docx
technical Subject to change
1
Data sheet
HERZ
2
3
4
5
6
7
8
1. Power cable
Connection diagram for 400VAC version:
L1 = black
- L2 = brown
- N = blue
2. Heating ON- OFF (only if the fan switch (3) is ON)
3. Fan ON – OFF
4. Handle, pushed laterally (fixed with two screws)
5. Potentiometer for speed/air volume
- Cable gland for control line for external control (Option)
6. Heating control potentiometer
7. Label (rear panel)
8. Heater tube
9. Intake
10. Temperature controller (optional)
- Cable gland for signal line for pulse output (option)
11. 6 threaded inserts M5 for mounting the unit during installation
(dimensions on the device base)
1
9
10
Control cable for external temperature control
digital signal (PWM 10-24 VDC, 0.5 Hz)
Control cable for external speed control:
digital rpm = 15VDC, I/max = 10mA;
PWM/1-10KHz/50-100%
(50% = minimum amount of air)
analog 5-10 VDC
(5 VDC = minimum amount of air)
11
+ = brown
- = white
Control cable with external potentiometer for temperature- or speed control:
Red / brown
+ = green
- = white
Black / white
Blue /green
WARNING. "Must be guaranteed at analog or digital control of the speed that the minimum amount of air-flow is brought forward when the heat is on!"
Signal line for external speed display:
1 pulse per turn
Open collector output
+ = brown
- = white
Compensation line with internal thermocouple type K ':
+ = green
- = white
2
Data sheet
HERZ
Available modifications:
Item number
Type
5005006
S01
5005005.2
S02
5005005.3
S29
5005009
S04
5005021.8
5005021.9
5005010.3
5005010.8
S05
S06
5005018
S07
5005020
5005016.1
5005016.3
5700128
5000120
S08
S09
S30
S10
5005004
S11
5005022
S18
5005034
S21
5700017
S24
5700161
S32
Modification
External heating control incl. 5 meter 2-wire control cable; PWM signal (5-24VDC, maximum cycle time 1Hz);
control cable 2-wire: brown (+) white (-); cable ends are marked;
External potentiometer for heating incl. 5 meter control cable; 3-wire;
potentiometer is soldered to the end of the cable; incl. potentiometer knob red;
The basic device for this modification is always
standard with a potentiometer
External potentiometer for blower speed; incl. 5 meter control cable; 3-wire;
potentiometer is soldered to the end of the cable; incl. potentiometer knob blue;
External control for blower speed incl. 5 meter control cable;
control signal analogue: 0-10VDC; control signal digital: PWM 1-10kHz; 12-24VDC; Imax. 10mA;
control cable 3-wire; green (+) white (-) brown (not used); cable ends are marked;
Internal PID control of the temperature without visualization for basic units with potentiometer;
Internal PID control of the temperature without visualization for basic units with potentiometer; !!! For Compact L !!!
Internal thermocouple with 2 meter compensation lin with open cable ends green (+) white (-);
Internal thermocouple with 2 meter compensation lin with open cable ends green (+) white (-);!!! For Compact L !!!
Compact 230VAC with 3-pin connection cable with open ends; black (heating), brown (blower), blue (neutral);
the double rocker switch is replaced by a double control lamp;
The fan speed is fixed and cannot be adjusted from the outside;
230 VAC version
Compact with internal thermocouple and digital controller;
400 VAC version
Compact 230 VAC with internal thermocouple, digital controller and potential-free alarm output;
Compact also has a handle on the back of the housing to hold the device with two hands;
With the Compact 400VAC, the blower is separated from the heater via a separate connection;
the double rocker switch is replaced by a double control lamp; Delivery standard is without connection cable;
Alternatively, the device is available with a 4-pin connection cable:
Terminal: N + L1 (blower 230VAC) L2 + L3 (heater 400VAC);
Cable: blue (N) black (L1) brown (L2) gray (L3);
Instead of the kink protection spiral, a normal cable gland is screwed inside the Compact;
the cable outlet is milled out in a funnel shape to avoid a cable break; the handle is omitted;
Compact with 5m control line for evaluating the fan speed; Control cable: brown (+) white (-); Signal: 1 pulse/turn;
The heating output is fixed and cannot be adjusted from the outside;
Please specify the desired heating output in% when ordering!
Klixon receives another assembly position ref. 2 ..
3
Data sheet
HERZ
Accessories
Description
Item-No.
Flange connection
Round nozzle Ø 40mm
5107246
5107245
Angled nozzle Ø 62mm; length 120 x 112mm
5107265
Extension tube Ø 40mm; length = 200mm
5107247
Tubular nozzle 700 x 550 x 1,7mm
5107253
Wide slot nozzle 85 x 15mm
5107260
Wide slot nozzle 150 x 12mm
5107259
Wide slot nozzle 200 x 9mm
Wide slot nozzle 250 x 12mm
Wide slot nozzle 300 x 4mm
Wide slot nozzle 500 x 4mm
5105977
5107263
5107262
5105991
Shrinking reflector 50 x 400mm; nozzle laterally mounted
5106177
Stainless steel filter for COMPACT suction side
5107248
4
Data sheet
HERZ
5
Data sheet
HERZ
HERZ GmbH
HERZ GmbH
Kunststoff- & Wärmetechnologie
Biberweg 1
DE – 56566 Neuwied
Tel.: +49 (0)2622-8855-0
Fax: +49 (0)2622-8855-135
Fax: +49 (0)2622-8855-136
www.herz-gmbh.com
info@herz-gmbh.com
Am Arenberg 26A
DE – 86456 Gablingen
Tel.: +49 (0)8230-85085
Fax: +49 (0)8230-85087
www.herz-gmbh.com
robert.einberger@herz-gmbh.com
HERZ Austria GmbH
HERZ Austria GmbH
Gleinser Weg 27
AT – 6141 Schönberg / Tirol
Tel.: +43 (0)5225-63113
Fax: +43 (0)5225-6311385
www.herz-austria.at
herz.schoenberg@herz-gmbh.com
Johann-Galler-Str. 20 IZ – NÖ – Nord
AT – 2120 Wolkersdorf i. Weinviertel
Tel.: +43 (0)2245-82494-0
Fax: +43 (0)2245-82494-9
www.herz-austria.at
herz.wolkersdorf@herz-gmbh.com
HERZ Hungária Kft.
HERZ Polska Sp.z o. o.
Technologie obróbki tworzyw sztucznych
Ul. Kostrzyńska 30
PL – 02-979 Warzawa
Tel.: +48 (0)22-8428583
Fax: +48 (0)22-8429700
www.herz-polska.pl
herz@herz-polska.pl
Műanyag- es hőlégtechnika
Pesti út 284
HU – 2225 Üllö
Tel.: +36 (06)29-522400
Fax: +36 (06)29-522410
www.herz-hungaria.hu
herz@herz-hungaria.hu
HERZ Bulgaria OOD
Boul. Assen Yordanov 10
BG – 1592 Sofia
Tel.: +359 (0)2-9790351
www.herz-bulgaria.com
office@herz-bulgaria.com
© by HERZ GmbH
6
很抱歉,暂时无法提供与“5102594”相匹配的价格&库存,您可以联系我们找货
