Data sheet
HERZ
High pressure blower type HD140
Type:
Side channel blower
Configuration:
In the standard version, the fan on the intake side has a stainless steel filter that
can be used after cleaning with compressed air. When using a fine filter, the
stainless steel filter be removed.
Features:
The device is suitable for operation with frequency inverters for speed control. If
desired, the device can be equipped with a thermistor (PTC), the signal can be
evaluated with an optional trip device. The tech. Data remains unchanged.
Operating temperature: The operating temperature of the radial pressure may NOT exceed 60 ° C.
Ambient temperature:
-20 ° C to +60 ° C;
Voltage:
Optional 1 x 230VAC/50Hz, Capacitor 16/450uF/V (Item-no.: 5108623)
Technical data
Type:
Item no.:
Voltage
Frequency
Motor power
Current
Volume flow
Total pressure difference
Speed
Sound pressure level
Weight
Air intake
Air outlet
Dimensions
Protection type
Conformity
VAC (Y/Δ)
Hz
KW
A (Y/Δ)
m³ / min
Pa
rpm
LpA (db)
kg
mm
mm
mm (LxWxH)
Side channel blower
5103429
on request
200 – 255 / 346 - 440
200 – 247 / 346 – 480
50
60
0,42
0,52
1,73 – 2,10 / 1,00 – 1,20
2,00 – 2,50 / 1,15 – 1,45
1,50
1,60
14‘000
2‘845
3‘435
64 – 73
69 – 76
11,3
Ø 38 (aussen)
Ø 38 (aussen)
283 x 244 x 266,5
IP 54
CE
Protection class I
DB HD140 V20 R18 07_2021 GB.docx
technical changes reserved
1
Data sheet
HERZ
Fan characteristics
(Y/Δ) 200–255/346–440VAC, 50Hz
(Y/Δ) 200–277/346–480VAC, 60Hz
Permissible vibration values according to ISO 14694
Fan application
category [ah]
BV-3
Rigidly mounted [mm/s²]
Peak
r.m.s.
3,8
2,8
Flexibly mounted [mm/s²]
Peak
r.m.s.
5,1
3,5
2
Data sheet
HERZ
Accessories
Item-No.
Description
5108623
Motor capacitor 230 V ~ with clamp and cable
5107293
Hose connection adaptor 1 x 38mm inside / 2 x 38mm outside
5207293
Hose connection adaptor 1 x 38mm / 2 x 38mm – with thread outside
5107281
Hose connection adaptor 1 x 38mm inside / 3 x 14mm outside
5107298
Hose connection adaptor 1 x 38mm inside / 2 x 19mm outside
5107286
PVC air hose – Ø 38mm inside
5107287
Hose clip for hose Ø 38mm
5107241
Closure Cap for hose connection adaptor Ø 38mm
5107350
PVC air hose aus PVC – Ø 19mm inside
5107290
Hose clip for hose Ø 19mm
5107242
Closure Cap for hose connection adaptor Ø 19mm
5107354
Stainless steel filter for HD140
3
Data sheet
HERZ
4
Data sheet
HERZ
HERZ GmbH
HERZ GmbH
Kunststoff- & Wärmetechnologie
Biberweg 1
DE – 56566 Neuwied
Tel.: +49 (0)2622-8855-0
Fax: +49 (0)2622-8855-135
Fax: +49 (0)2622-8855-136
www.herz-gmbh.com
info@herz-gmbh.com
Am Arenberg 26A
DE – 86456 Gablingen
Tel.: +49 (0)8230-85085
Fax: +49 (0)8230-85087
www.herz-gmbh.com
robert.einberger@herz-gmbh.com
HERZ Austria GmbH
HERZ Austria GmbH
Gleinser Weg 27
AT – 6141 Schönberg / Tirol
Tel.: +43 (0)5225-63113
Fax: +43 (0)5225-6311385
www.herz-austria.at
herz.schoenberg@herz-gmbh.com
Johann-Galler-Str. 20 IZ – NÖ – Nord
AT – 2120 Wolkersdorf i. Weinviertel
Tel.: +43 (0)2245-82494-0
Fax: +43 (0)2245-82494-9
www.herz-austria.at
herz.wolkersdorf@herz-gmbh.com
HERZ Hungária Kft.
HERZ Polska Sp.z o. o.
Technologie obróbki tworzyw sztucznych
Ul. Kostrzyńska 30
PL – 02-979 Warzawa
Tel.: +48 (0)22-8428583
Fax: +48 (0)22-8429700
www.herz-polska.pl
herz@herz-polska.pl
Műanyag- es hőlégtechnika
Pesti út 284
HU – 2225 Üllö
Tel.: +36 (06)29-522400
Fax: +36 (06)29-522410
www.herz-hungaria.hu
herz@herz-hungaria.hu
HERZ Bulgaria OOD
Boul. Assen Yordanov 10
BG – 1592 Sofia
Tel.: +359 (0)2-9790351
www.herz-bulgaria.com
office@herz-bulgaria.com
© by HERZ GmbH
5
很抱歉,暂时无法提供与“5103429”相匹配的价格&库存,您可以联系我们找货
