5102747
    HAPCO
    HEATER TYPE XL92, 3X230V/10.2KW
5102747 数据手册
Data sheet HERZ Air heater type XL92 to 25,0 KW Air heater with external air supply by means of fan or compressed air. CAUTION !!! Device is not pressure-resistant !!! Function: Configuration: Default: Temperature control with potentiometer (1 – 9) - alternatively with external potentiometer (cable length 5 meter) or - external control by control unit or SPS (cable length per meter) The Device is equipped with a reliable heating element protection. The integrated device protection turns off the device when tripped, the fault must be with a "reset" reset again. Features: Special designs with internal thermocouple (cable length 1 or 5 meter) - for devices with electronic equipment max. supply air temperature 50°C/122°F - the unit is available without electronics (without heating element and device protection) - for devices without electronic equipment max. supply air temperature 80°C/176°F (Special design up to max. 100°C/212°F) Power: Voltage: 5,7 KW – 25,0 KW 230 VAC (3Ph), 400-440-480 VAC Technical data: Item number/Basic versions Voltage Frequency Power Current Max. temperature Min. air volume Weight Air intake Air outlet Heater tube Dimensions Potentiometer external control without electronic VAC Hz KW A °C/°F l/min kg Ø mm Ø mm Ø mm mm (L x W x H) 5700098 5102750 5102755 5102747 5102748 5102753 5102761 5112328 5102766 5,7 14,3 10,2 25,6 5,9 - 8,5 8,5 - 10,2 550 930 560 230 (3Ph) 5102762 5102179 5102180 400 - 480 50 / 60 7,6 - 10,9 11,0 - 13,1 650/1202 680 3,3 60 84 92 / 102 335 x 123 x 124 5102760 5110521 5102768 5102765 5113726 5102770 400 on request on request 5102770 480 11,8 - 17,1 17,0 - 20,6 17,0 25,5 25,0 30,1 950 1480 Conformity mark Protection class I DB XL92 V20 R20 03_2021 GB.docx Technical changes reserved 1 Data sheet HERZ Air heater type XL92 to 25,0 KW Product description: With electronics 5 6 2 1 Connection scheme: Without electronics 7 3 8 4 1. Cable fitting mains supply 2. Cable fitting control cable for external control 3. Potentiometer 0-9 (no Potentiometer for devices without electronic and external control) 4. Mounting on bottom of housing M 8 (screw depth 16 mm) 5. Heating element pipe (type L= 62mm; type XL = 92 mm) 6. Cover 7. Data plate 8. Air intake Ø 38mm 1. L1, N or L1, L2 or L1, L2, L3 Main connection according to data plate 2. earth 3. 1 – 3 potential-free changeover contact (230VAC, 1A) - 2  1 = close - 2  3 = open 4. +/- external control signal from for example SPS or Controller (PWM 12 – 24VDC max. 1 Hz) NOTE: For devices without electronics, the terminals + / - and 1/2/3 not available! NOTE: After activation of the heating element and / or equipment protection is indicated on the devices with electronics has a relay contact this disorder. The built-in relay, will give the following model with the terminals 1-3 (3), a potential-free changeover contact. This signal can only be a "reset" back off, that is, the device must be energized. Measures in case the heating element and protection: Unit from the mains, after 3 seconds automatically reset the electronics. Check the air supply (air flow, pressure, fan filter). Restore power supply. DB XL92 V20 R20 03_2021 GB.docx Technical changes reserved 2 Data sheet HERZ Air heater type XL92 to 25,0 KW Avaiable Versions: Item no. 5700098 5102750 5102755 5102747 5102748 5102753 5102761 5112328 5102766 5102762 5102179 5102180 5102760 5110521 5102768 5102765 5113726 5102770 Description Air heater XL92 230 VAC 3Ph 5,7 KW with potentiometer Air heater XL92 230 VAC 3Ph 5,7 KW externally controllable (PWM 12-24 VDC, 1 Hz) Air heater XL92 230 VAC 3Ph 5,7 KW without electronic Air heater XL92 230 VAC 3Ph 10,2 KW with potentiometer Air heater XL92 230 VAC 3Ph 10,2 KW externally controllable (PWM 12-24 VDC, 1 Hz) Air heater XL92 230 VAC 3Ph 10,2 KW without electronic Air heater XL92 400-440-480 VAC 5,9-7,1-8,5 KW with potentiometer Air heater XL92 400-440-480 VAC 5,9-7,1-8,5 KW externally controllable (PWM 12-24 VDC, 1 Hz) Air heater XL92 400-440-480 VAC 5,9-7,1-8,5 KW without electronic Air heater XL92 400-440-480 VAC 7,6-9,1-10,9 KW with potentiometer Air heater XL92 400-440-480 VAC 7,6-9,1-10,9 KW externally controllable (PWM 12-24 VDC, 1 Hz) Air heater XL92 400-440-480 VAC 7,6-9,1-10,9 KW without electronic Air heater XL92 400-440-480 VAC 11,8-14,3-17,1 KW with potentiometer Air heater XL92 400-440-480 VAC 11,8-14,3-17,1 KW externally controllable (PWM 12-24 VDC, 1 Hz) Air heater XL92 400-440-480 VAC 11,8-14,3-17,1 KW without electronic Air heater XL92 400 VAC 17,0 KW with potentiometer Air heater XL92 400 VAC 17,0 KW externally controllable (PWM 12-24 VDC, 1 Hz) Air heater XL92 400 VAC 17,0 KW without electronic DB XL92 V20 R20 03_2021 GB.docx Technical changes reserved 3 Data sheet HERZ Air heater type XL92 to 25,0 KW Available modifications: Item number Type 5005014 S02 5005021.7 5005010.7 5005017 S05 S06 S17 5005033 S20 5005036.6 S23 Modification External potentiometer for heating including 5m control line; 3 pole; The basic device for this modification is Potentiometer is soldered to the end of the cable; including potentiometer knob always standard with a potentiometer red; Internal PID control via internal potentiometer without digital display; Internal thermocouple including 2m compensation cable with open ends green (+) white (-); Device with 2m silicone connection cable. Open ended cables; the ends are marked; Inlet temperature max. 100°C/212°F; The device has no electronics but has a built-in solid state relay; there is a 2-pole connection terminal for connecting the control line; exclusive control cable; Device with tube adapter without protective tube; Standard is with protective tube; Accessories: Item no. Description 5107275 Flange connector, push fit on the protective tube 5107244 Round nozzle ø 50 mm 5107269 Angled nozzle, length 175 x 175mm 5107273 Extension tube 60 x 500mm 5107274 Wide slot nozzle 130 x 17mm 5107272 Wide slot nozzle 300 x 12mm 5106018 Wide slot nozzle 400 x 10mm 5107267 Wide slot nozzle 500 x 15mm 5106023 Wide slot nozzle 600 x 4mm 5107268 Tubular nozzle 1288 x 1000 x 1,5mm (L1 x L2 x W) DB XL92 V20 R20 03_2021 GB.docx Technical changes reserved 4 Data sheet HERZ Air heater type XL92 to 25,0 KW Combination possibilities for devices WITH electronic *: Measuring point: Hose length: Air supply: Air flow: 3.0 mm after the air outlet pipe adapter – without nozzle, measured at the hottest point 1,0 mr Blower 400 Volt, 50 Hz (HD = High pressure blower, MD = Medium pressure blower) Nl / min = standard liters per minute according to DIN 1343 CAUTION: Air flow and temperature are indicative which can change due to external influences and changes air hose diameter and length! Blower type HD140 MD10 MD14 HD140 HD240 MD10 MD14 HD140 HD240 MD10 MD14 HD240 MD10 MD14 Quantity, air heater type; voltage; power 2 x XL92; 400VAC; 5,9KW 2 x XL92; 400VAC; 5,9KW 4 x XL92; 400VAC; 5,9KW 2 x XL92; 400VAC; 5,9KW 4 x XL92; 400VAC; 5,9KW 2 x XL92; 400VAC; 7,6KW 4 x XL92; 400VAC; 7,6KW 2 x XL92; 400VAC; 7,6KW 4 x XL92; 400VAC; 7,6KW 4 x XL92; 400VAC; 7,6KW 1 x XL92; 400VAC; 11,8KW 4 x XL92; 400VAC; 11,8KW 1 x XL92; 400VAC; 11,8KW 2 x XL92; 400VAC; 11,8KW 4 x XL92; 400VAC; 11,8KW 1 x XL92; 400VAC; 11,8KW 2 x XL92; 400VAC; 11,8KW 4 x XL92; 400VAC; 11,8KW 2 x XL92; 400VAC; 17,0KW 1 x XL92; 400VAC; 17,0KW 1 x XL92; 400VAC; 17,0KW 2 x XL92; 400VAC; 17,0KW Air flow at 50 Hz with heating [Nl / min.] 2 x 780 2 x 1740 4 x 1160 2 x 2130 4 x 1910 2 x 770 4 x 1070 2 x 770 4 x 1110 4 x 1790 1470 4 x 1070 1770 2 x 1460 4 x 1070 2090 2 x 1880 4 x 1720 2 x 2040 970 1850 2 x 1800 Maximum temperature at 50 Hz [°C/°F] 480/896 250/482 360/680 210/410 230/446 580/1076 510/950 320/608 440/824 310/590 460/860 590/1094 400/752 460/860 570/1058 380/716 400/752 430/806 490/914 550/1022 530/986 540/1004 *Data without guarantee DB XL92 V20 R20 03_2021 GB.docx Technical changes reserved 5 Data sheet HERZ Air heater type XL92 to 25,0 KW DB XL92 V20 R20 03_2021 GB.docx Technical changes reserved 6 Data sheet HERZ Air heater type XL92 to 25,0 KW HERZ GmbH HERZ GmbH Kunststoff- & Wärmetechnologie Biberweg 1 DE – 56566 Neuwied Tel.: +49 (0)2622-8855-0 Fax: +49 (0)2622-8855-135 Fax: +49 (0)2622-8855-136 www.herz-gmbh.com info@herz-gmbh.com Kunststoff- & Wärmetechnologie Am Arenberg 26A DE – 86456 Gablingen Tel.: +49 (0)8230-85085 Fax: +49 (0)8230-85087 www.herz-gmbh.com robert.einberger@herz-gmbh.com HERZ Austria GmbH HERZ Austria GmbH Kunststoff- & Wärmetechnologie Gleinser Weg 27 AT – 6141 Schönberg / Tirol Tel.: +43 (0)5225-63113 Fax: +43 (0)5225-6311385 www.herz-austria.at herz.schoenberg@herz-gmbh.com Kunststoff- & Wärmetechnologie Johann-Galler-Str. 20 IZ – NÖ – Nord AT – 2120 Wolkersdorf i. Weinviertel Tel.: +43 (0)2245-82494-0 Fax: +43 (0)2245-82494-9 www.herz-austria.at herz.wolkersdorf@herz-gmbh.com HERZ Hungária Kft. HERZ Polska Sp.z o. o. Technologie obróbki tworzyw sztucznych Ul. Kostrzyńska 30 PL – 02-979 Warzawa Tel.: +48 (0)22-8428583 Fax: +48 (0)22-8429700 www.herz-polska.pl herz@herz-polska.pl Műanyag- es hőlégtechnika Pesti út 284 HU – 2225 Üllö Tel.: +36 (06)29-522400 Fax: +36 (06)29-522410 www.herz-hungaria.hu herz@herz-hungaria.hu HERZ Bulgaria OOD Boul. Assen Yordanov 10 BG – 1592 Sofia Tel.: +359 (0)2-9790351 www.herz-bulgaria.com office@herz-bulgaria.com © by HERZ GmbH DB XL92 V20 R20 03_2021 GB.docx Technical changes reserved 7
5102747 价格&库存
很抱歉,暂时无法提供与“5102747”相匹配的价格&库存,您可以联系我们找货
