Data sheet
HERZ
Air heater type XL92 to 25,0 KW
Air heater with external air supply by means of fan or compressed air.
CAUTION !!! Device is not pressure-resistant !!!
Function:
Configuration: Default: Temperature control with potentiometer (1 – 9)
- alternatively with external potentiometer (cable length 5 meter) or
- external control by control unit or SPS (cable length per meter)
The Device is equipped with a reliable heating element protection. The integrated device
protection turns off the device when tripped, the fault must be with a "reset" reset again.
Features:
Special designs with internal thermocouple (cable length 1 or 5 meter)
- for devices with electronic equipment max. supply air temperature
50°C/122°F
- the unit is available without electronics (without heating element and device
protection)
- for devices without electronic equipment max. supply air temperature
80°C/176°F (Special design up to max. 100°C/212°F)
Power:
Voltage:
5,7 KW – 25,0 KW
230 VAC (3Ph), 400-440-480 VAC
Technical data:
Item number/Basic versions
Voltage
Frequency
Power
Current
Max. temperature
Min. air volume
Weight
Air intake
Air outlet
Heater tube
Dimensions
Potentiometer
external control
without electronic
VAC
Hz
KW
A
°C/°F
l/min
kg
Ø mm
Ø mm
Ø mm
mm (L x W x H)
5700098
5102750
5102755
5102747
5102748
5102753
5102761
5112328
5102766
5,7
14,3
10,2
25,6
5,9 - 8,5
8,5 - 10,2
550
930
560
230 (3Ph)
5102762
5102179
5102180
400 - 480
50 / 60
7,6 - 10,9
11,0 - 13,1
650/1202
680
3,3
60
84
92 / 102
335 x 123 x 124
5102760
5110521
5102768
5102765
5113726
5102770
400
on request
on request
5102770
480
11,8 - 17,1
17,0 - 20,6
17,0
25,5
25,0
30,1
950
1480
Conformity mark
Protection class I
DB XL92 V20 R20 03_2021 GB.docx
Technical changes reserved
1
Data sheet
HERZ
Product description:
With electronics
5
6
2
1
Connection scheme:
Without electronics
7
3
8
4
1. Cable fitting mains supply
2. Cable fitting control cable for external control
3. Potentiometer 0-9 (no Potentiometer for devices without electronic and
external control)
4. Mounting on bottom of housing M 8 (screw depth 16 mm)
5. Heating element pipe (type L= 62mm; type XL = 92 mm)
6. Cover
7. Data plate
8. Air intake Ø 38mm
1. L1, N or L1, L2 or
L1, L2, L3 Main connection according to data plate
2.
earth
3. 1 – 3 potential-free changeover contact (230VAC, 1A)
- 2 1 = close
- 2 3 = open
4. +/- external control signal from for example SPS or Controller
(PWM 12 – 24VDC max. 1 Hz)
NOTE:
For devices without electronics, the terminals + / - and 1/2/3 not available!
NOTE:
After activation of the heating element and / or equipment protection is indicated on the devices with electronics has a relay contact this disorder. The built-in relay,
will give the following model with the terminals 1-3 (3), a potential-free changeover contact. This signal can only be a "reset" back off, that is, the device must be
energized.
Measures in case the heating element and protection:
Unit from the mains, after 3 seconds automatically reset the electronics. Check the air supply (air flow, pressure, fan filter). Restore power supply.
2
Data sheet
HERZ
Avaiable Versions:
Item no.
5700098
5102750
5102755
5102747
5102748
5102753
5102761
5112328
5102766
5102762
5102179
5102180
5102760
5110521
5102768
5102765
5113726
5102770
Description
Air heater XL92 230 VAC 3Ph 5,7 KW with potentiometer
Air heater XL92 230 VAC 3Ph 5,7 KW externally controllable (PWM 12-24 VDC, 1 Hz)
Air heater XL92 230 VAC 3Ph 5,7 KW without electronic
Air heater XL92 230 VAC 3Ph 10,2 KW with potentiometer
Air heater XL92 230 VAC 3Ph 10,2 KW externally controllable (PWM 12-24 VDC, 1 Hz)
Air heater XL92 230 VAC 3Ph 10,2 KW without electronic
Air heater XL92 400-440-480 VAC 5,9-7,1-8,5 KW with potentiometer
Air heater XL92 400-440-480 VAC 5,9-7,1-8,5 KW externally controllable (PWM 12-24 VDC, 1 Hz)
Air heater XL92 400-440-480 VAC 5,9-7,1-8,5 KW without electronic
Air heater XL92 400-440-480 VAC 7,6-9,1-10,9 KW with potentiometer
Air heater XL92 400-440-480 VAC 7,6-9,1-10,9 KW externally controllable (PWM 12-24 VDC, 1 Hz)
Air heater XL92 400-440-480 VAC 7,6-9,1-10,9 KW without electronic
Air heater XL92 400-440-480 VAC 11,8-14,3-17,1 KW with potentiometer
Air heater XL92 400-440-480 VAC 11,8-14,3-17,1 KW externally controllable (PWM 12-24 VDC, 1 Hz)
Air heater XL92 400-440-480 VAC 11,8-14,3-17,1 KW without electronic
Air heater XL92 400 VAC 17,0 KW with potentiometer
Air heater XL92 400 VAC 17,0 KW externally controllable (PWM 12-24 VDC, 1 Hz)
Air heater XL92 400 VAC 17,0 KW without electronic
3
Data sheet
HERZ
Available modifications:
Item number
Type
5005014
S02
5005021.7
5005010.7
5005017
S05
S06
S17
5005033
S20
5005036.6
S23
Modification
External potentiometer for heating including 5m control line; 3 pole;
The basic device for this modification is
Potentiometer is soldered to the end of the cable; including potentiometer knob
always standard with a potentiometer
red;
Internal PID control via internal potentiometer without digital display;
Internal thermocouple including 2m compensation cable with open ends green (+) white (-);
Device with 2m silicone connection cable. Open ended cables; the ends are marked; Inlet temperature max. 100°C/212°F;
The device has no electronics but has a built-in solid state relay;
there is a 2-pole connection terminal for connecting the control line; exclusive control cable;
Device with tube adapter without protective tube; Standard is with protective tube;
Accessories:
Item no.
Description
5107275
Flange connector, push fit on the protective tube
5107244
Round nozzle ø 50 mm
5107269
Angled nozzle, length 175 x 175mm
5107273
Extension tube 60 x 500mm
5107274
Wide slot nozzle 130 x 17mm
5107272
Wide slot nozzle 300 x 12mm
5106018
Wide slot nozzle 400 x 10mm
5107267
Wide slot nozzle 500 x 15mm
5106023
Wide slot nozzle 600 x 4mm
5107268
Tubular nozzle 1288 x 1000 x 1,5mm (L1 x L2 x W)
4
Data sheet
HERZ
Combination possibilities for devices WITH electronic *:
Measuring point:
Hose length:
Air supply:
Air flow:
3.0 mm after the air outlet pipe adapter – without nozzle, measured at the hottest point
1,0 mr
Blower 400 Volt, 50 Hz (HD = High pressure blower, MD = Medium pressure blower)
Nl / min = standard liters per minute according to DIN 1343
CAUTION:
Air flow and temperature are indicative which can change due to external influences and changes air hose diameter and length!
Blower type
HD140
MD10
MD14
HD140
HD240
MD10
MD14
HD140
HD240
MD10
MD14
HD240
MD10
MD14
Quantity, air heater type;
voltage; power
2 x XL92; 400VAC; 5,9KW
4 x XL92; 400VAC; 5,9KW
2 x XL92; 400VAC; 7,6KW
4 x XL92; 400VAC; 7,6KW
1 x XL92; 400VAC; 11,8KW
4 x XL92; 400VAC; 11,8KW
2 x XL92; 400VAC; 11,8KW
2 x XL92; 400VAC; 17,0KW
1 x XL92; 400VAC; 17,0KW
Air flow at 50 Hz with heating [Nl / min.]
2 x 780
2 x 1740
4 x 1160
2 x 2130
4 x 1910
2 x 770
4 x 1070
2 x 770
4 x 1110
4 x 1790
1470
4 x 1070
1770
2 x 1460
4 x 1070
2090
2 x 1880
4 x 1720
2 x 2040
970
1850
2 x 1800
Maximum temperature
at 50 Hz [°C/°F]
480/896
250/482
360/680
210/410
230/446
580/1076
510/950
320/608
440/824
310/590
460/860
590/1094
400/752
460/860
570/1058
380/716
400/752
430/806
490/914
550/1022
530/986
540/1004
*Data without guarantee
5
Data sheet
HERZ
6
Data sheet
HERZ
HERZ GmbH
HERZ GmbH
Kunststoff- & Wärmetechnologie
Biberweg 1
DE – 56566 Neuwied
Tel.: +49 (0)2622-8855-0
Fax: +49 (0)2622-8855-135
Fax: +49 (0)2622-8855-136
www.herz-gmbh.com
info@herz-gmbh.com
Am Arenberg 26A
DE – 86456 Gablingen
Tel.: +49 (0)8230-85085
Fax: +49 (0)8230-85087
www.herz-gmbh.com
robert.einberger@herz-gmbh.com
HERZ Austria GmbH
HERZ Austria GmbH
Gleinser Weg 27
AT – 6141 Schönberg / Tirol
Tel.: +43 (0)5225-63113
Fax: +43 (0)5225-6311385
www.herz-austria.at
herz.schoenberg@herz-gmbh.com
Johann-Galler-Str. 20 IZ – NÖ – Nord
AT – 2120 Wolkersdorf i. Weinviertel
Tel.: +43 (0)2245-82494-0
Fax: +43 (0)2245-82494-9
www.herz-austria.at
herz.wolkersdorf@herz-gmbh.com
HERZ Hungária Kft.
HERZ Polska Sp.z o. o.
Technologie obróbki tworzyw sztucznych
Ul. Kostrzyńska 30
PL – 02-979 Warzawa
Tel.: +48 (0)22-8428583
Fax: +48 (0)22-8429700
www.herz-polska.pl
herz@herz-polska.pl
Műanyag- es hőlégtechnika
Pesti út 284
HU – 2225 Üllö
Tel.: +36 (06)29-522400
Fax: +36 (06)29-522410
www.herz-hungaria.hu
herz@herz-hungaria.hu
HERZ Bulgaria OOD
Boul. Assen Yordanov 10
BG – 1592 Sofia
Tel.: +359 (0)2-9790351
www.herz-bulgaria.com
office@herz-bulgaria.com
© by HERZ GmbH
7
