Han® HP Direct M
Sizes 6 B, 10 B, 16 B, 24 B
Features
Technical characteristics
Housings systen without using a bulkheasd
mounting housing on the device side
• Hoods in size 6 B, 10 B, 16 B and 24 B
Suitable for all contact inserts Han® B
Top and side entry from M20 to M40 all sizes
Optional coding by two coding elements
• Panel cut-outs compatible with standard Han® B
panel cut-outs
• Suitable for extreme environmental conditions
Specifications
DIN EN 61 984
DIN EN 60 664-1
Hoods
Material
Colour
Surface
- top coat
aluminium die-cast
RAL 9005 (black)
powder coated
Locking element
Screw locking
Marerial
M6
stainless steel
Tightening torque
4 Nm
Housing seal FPM
Mounting Flange
Material
Colour
zinc die-cast
unpainted
Surface
electrically conductive
Coding element
Material
Color
polycarbonat
red
-40 °C ... +125 °C
ASTM B117-09 (500 h)
Limit temperature
corrosion resistance
Protection degree acc. to
DIN EN 60 529
in locked position
IP66 / IP68 / IP69K
HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp
Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495
www.HARTING.com | electric@HARTING.com
Han®
2016-08-17
Data Sheet 1161
Han® HP Direct M
Cable
Identification
Part number
entry
Drawing
Han® 6 HP Direct M
Hood
top entry
19 39 706 0445
19 39 706 0446
19 39 706 0447
19 39 706 0448
M20
M25
M32
M40
Panel cut out
Han® 6 HP Direct M
Hood
side entry
19 39 706 0545
19 39 706 0546
19 39 706 0547
19 39 706 0548
M20
M25
M32
M40
Panel cut out
Han® 10 HP Direct M
Hood
top entry
19 39 710 0445
19 39 710 0446
19 39 710 0447
19 39 710 0448
M20
M25
M32
M40
Panel cut out
Han® 10 HP Direct M
Hood
side entry
19 39 710 0545
19 39 710 0546
19 39 710 0547
19 39 710 0548
M20
M25
M32
M40
Panel cut out
Dimensions in mm
Han® HP Direct M
Cable
Identification
Part number
entry
Drawing
Han® 16 HP Direct M
Hood
top entry
19 39 716 0445
19 39 716 0446
19 39 716 0447
19 39 716 0448
M20
M25
M32
M40
Panel cut out
Han® 16 HP Direct M
Hood
side entry
19 39 716 0545
19 39 716 0546
19 39 716 0547
19 39 716 0548
M20
M25
M32
M40
Panel cut out
Han® 24 HP Direct M
Hood
top entry
19 39 724 0445
19 39 724 0446
19 39 724 0447
19 39 724 0448
M20
M25
M32
M40
Panel cut out
Han® 24 HP Direct M
Hood
side entry
19 39 724 0545
19 39 724 0546
19 39 724 0547
19 39 724 0548
M20
M25
M32
M40
Panel cut out
Dimensions in mm
Han® HP Direct M
Cable
Identification
Part number
entry
Mounting Flange
Set 2 pieces
09 39 000 9902
Coding element
Set 4 pieces
09 39 000 9903
Drawing
Dimensions in mm
很抱歉,暂时无法提供与“19397160545”相匹配的价格&库存,您可以联系我们找货
