Han® 22 HPR slim
Features
Compact and flat design, thereby space-saving
hood and housing
• Optimised for up to 4 x Han® HC Modular 250
contacts
• Proven characteristics of Han® HPR hood and
housing series
Variable installation possibilities due to separate
mounting panels
External PE termination on hood and surface
mounted housing
Technical characteristics
Specifications
DIN EN 61984
DIN EN 60664-1
Hoods
Material
Colour
Surface
- top coat
Locking element
- Screw locking
- Material
- Tightening torque
aluminium die-cast
RAL 9005 (black)
powder coated
M6
stainless steel
4 Nm
Hoods/housings seal NBR
Tightening torque
external PE connection
15 Nm
Frame
Material
Number of contacts
stainless steel
4 pin for Han® HC
Modular 250
Tightening torque
fixing screw
0.5 Nm
Mounting panels
Material
stainless steel
Tightening torque
fixing screw
6 Nm
Limiting temperatures
Protection degree acc.
DIN EN 60529 in locked position
Electrical data acc. to
DIN EN 61984
for Han® HC Modular 250
Rated current
Rated voltage
Rated impulse voltage
Pollution degree
-40 °C ... +125 °C
IP66 / IP68 / IP69K
250 A 2000 V 12 kV 3
250 A
2000 V
12 kV
3
HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp
Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495
www.HARTING.com | electric@HARTING.com
Han®
2017-05-03
Data Sheet 1165
Han® 22 HPR slim
Cable
Identification
Part number
entry
Han® 22 HPR slim
Hood
top entry
19 40 022 0470
4 x M20
19 40 022 0970
4 x M20
09 40 022 9901
09 40 022 9902
Han® 22 HPR slim
Surface mounted housing
top entry
Frame for male inserts
Han® HC Modular 250
4 pins
Frame for female inserts
Han® HC Modular 250
4 pins
Drawing
Dimensions in mm
Han® 22 HPR slim
Identification
Part number Drawing
Dimensions in mm
Mounting panels
Set of 2 pieces
09 40 022 9920
很抱歉,暂时无法提供与“09400229920”相匹配的价格&库存,您可以联系我们找货
