B36L3RGB-F6C0001HOU1930 数据手册
Top Mount RGB Chip LED
Features
•Package: RGB 3 in 1 package/4pin Polarity
•Anti-Reflection resin
•View angle : >=120゚ (min 50% brightness)
•Component solder able surface finish is gold
•High contrast
Main Applications
•Indoor display
•Full color display
•Fine pitch application
Official Product
HT Part No. B36L3RGB-F6C0001HOU1930
Tentative Product
Specifications are subject to changes for improvement without advance
notice. Proprietary data, drawings, company confidential all rights
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Page 1/16
www.harvatek.com
Version 1.0
DISCLAIMER ......................................................................................................................................... 3
PRODUCT SPECIFICATIONS............................................................................................................. 4
ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ................................................ 5
LABEL SPECIFICATIONS ................................................................................................................... 5
SPECIFICATIONS RANGE .................................................................................................................. 7
PRODUCT FEATURES ......................................................................................................................... 8
ELECTRO-OPTICAL CHARACTERISTICS ...................................................................................... 8
PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW
SOLDERING ............................................................................................................................. 8
ABSOLUTE MAXIMUM RATINGS ................................................................................................. 8
CHARACTERISTICS OF B36L3RGB-F6 ..................................................................................... 9
PRECAUTION FOR USE .................................................................................................................... 10
PACKAGING ........................................................................................................................................ 11
TAPE DIMENSION ................................................................................................................... 11
REEL DIMENSION ................................................................................................................... 12
PACKING ............................................................................................................................... 12
DRY PACK............................................................................................................................................. 13
BAKING ................................................................................................................................ 13
PRECAUTIONS .................................................................................................................................... 14
REFLOW SOLDERING ...................................................................................................................... 14
REWORKING .......................................................................................................................... 15
CLEANING ............................................................................................................................. 15
REVISE HISTORY.................................................................................................................... 16
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 2/16
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of
the application or use of any product or circuit described herein; neither does it convey any
license under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support devices
or systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when
properly used in accordance with instructions for use provided in the labeling, can be
reasonably expected to result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to
perform can be reasonably expected to cause the failure of the life support device or system, or
to affect its safety or effectiveness.
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 3/16
Product Specifications
Specification
Luminous
Red :
Intensity(Iv)
Green : 46 mcd typical
Blue :
Material
Quantity
32 mcd typical
8 mcd typical
R@5mA;G/B@2mA/ Ts= 25O C; Tolerance ±10%
Wavelength
Red :
621 nm typical
Green : 530 nm typical
Blue :
470 nm typical
R@5mA;G/B@2mA/ Ts= 25O C;Tolerance ± 0.5nm
Vf
Red :
2.4 V maximum
Green : 3.1 V maximum
Blue :
3.1 V maximum
R@5mA;G/B@2mA/ Ts= 25O C;Tolerance ± 0.05V
Ir
< =1 µA @ VR = 5 V
Resin
Dark
Epoxy
Carrier tape
EIA 481-1A specs
Conductive black tape
Reel
EIA 481-1A specs
Conductive black
Label
HT standard
Paper
Packing bag
250x230mm
Aluminum laminated bag/ no-zipper One reel per bag
Carton
HT standard
Paper
Official Product
Tentative Product
reserved.
24000pcs/reel
Non-specified
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 4/16
Others:
Each immediate box consists of 28 reels. The 28 reels may not necessarily have the same lot number or the same bin
combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label
as well.
Note :This is shipped test conditions
※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product, such
operation can cause migration resulting in LED damage.
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based
chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts
built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be
taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
Label Specifications
日期
客戶品號
數量
宏齊品號
批號
光強度
波長
順向電壓
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 5/16
■Harvatek P/N:
B
36L
3
Product
Dice
PCB
3:Tri
RGB-
F6C
0001
HO U1930
Current
Taping
R:5mA
1.Taping style
2. Q’ty
G/B:2mA
Package
Color
Series Number
0.65(L)x0.65(W)x0.5(H) mm
RGB(Full Color)
X001~XZZZ
Customer Code
Customer Product Code
X0001~XZZZZ
Lot No.
1
2
3
4
5
6
7
8
9
10
1
7
N
E
4
1
L
N
1
1
Code 3
Code 4
Code 5
Code 6
Code 7
Code 8
Code 9
Code 10
Code 1 2
Mfg.Year Mfg.Month Consecutive number
Internal Tracing Code
Mixing
Lot No.
2010-A
2011-B
2012-C
2013-D
2014-E
1:Jan
2:Feb
A:Oct
B:Nov
C:Dec
01~ZZ
Special code
000~ZZZ
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 6/16
Specifications Range
■Luminous Intensity (Iv) Bin:
Luminous Intensity (Iv) Bin: R@5mA;G/B @2mA
B36L3RGB Series
IV
Red
Green
Blue
HF3
21.3
26.7
HG3
30
37.5
HB3
5.4
6.8
HG1
24
30
HH1
33.5
42
HC1
6
7.5
HG2
26.7
33.5
HH2
37.5
47
HC2
6.8
8.5
HG3
30
37.5
HH3
42
52.5
HC3
7.5
9.4
HH1
33.5
42
HJ1
47
60
HD1
8.5
10.7
HH2
37.5
47
HJ2
52.5
65.7
HD2
9.4
12
HH3
42
52.5
HJ3
60
75
HD3
10.7
13.4
Note: It maintains a tolerance of ±10% on Luminous Intensity
Dominant Wavelength (λD) Bin: R@5mA;G/B @2mA
B36L3RGB Series
WD
Red
Green
Blue
RH2
618
623
GH1
526
530
BH1
464
468
RH3
623
628
GH2
528
532
BH2
466
470
RH4
628
633
GH3
530
534
BH3
468
472
GH4
532
536
BH4
470
474
GH5
534
538
Note: It maintains a tolerance of ±0.5nm on Color Bin
Forward Voltage (Vf) Bin: R@5mA;G/B @2mA
B36L3RGB Series
Vf
Red
E18
1.6
Green
2.4
F2A
2.1
Blue
3.1
2.1
F2A
3.1
Note: It maintains a tolerance of ±0.05V on forward voltage measurements
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 7/16
Product Features
Electro-Optical Characteristics
o
(IF Red@5mA,Green &Blue@2mA, Ts 25 C)
Part number
Emitting
Forward
Wavelength
Color
Voltage(VF)
(nm) typ.
I V(mcd)
Viewing
Angle 2θ1/2
typ.
max.
λD
λp
Δλ
typ.
Ultra Bright Red
1.9
2.4
621
628
11
32
140
Green
2.5
3.1
530
521
28
46
140
Blue
2.5
3.1
469
465
16
8
140
Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering
Unit: mm Tolerance: +/-0.1
Outline Dim.
Soldering Pattern
Soldering terminals may shift in the x, y direction.
Absolute Maximum Ratings
o
(TS 25 C)
Series
PD (mW)
IF (mA)
IFP (mA)
VR(V)
Forward Current
Pulse Forward Current
Reverse Voltage
Power
Color
Dissipation
Red
o
TST ( C)
Operation
Storage
Temperature
Temperature
-30~+80
-40~+85
5
24.4
Blue/Green
o
TOP ( C)
2
** Condition for IFP is pulse of 1/10 duty and 0.1msec width
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 8/16
Characteristics of B36L3RGB-F6
Relative Intensity vs. Forward Current
Forward Current vs. Ambient Temperature
Official Product
Tentative Product
reserved.
Forward Voltage vs. Forward Current
Wavelength vs. Forward Current
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 9/16
Precaution for Use
1. The chips should not be used directly in any type of fluid such as water, oil, organic
solvent, etc.
2. When the LEDs are illuminating, the maximum ambient temperature should be first
considered before operation.
3. LEDs must be stored in a clean environment. A sealed container with a nitrogen
4.
5.
6.
atmosphere is necessary if the storage period is over 3 months after shipping.
The LEDs must be used within seven days after unpacked. Unused products must be
repacked in an anti-electrostatic package, folded to close any opening and then stored in
a dry and cool space.
The appearance and specifications of the products may be modified for improvement
without further notice.
The LEDs are sensitive to the static electricity and surge. It is strongly recommended to
use a grounded wrist band and anti-electrostatic glove when handling the LEDs.If a
voltage over the absolute maximum rating is applied to LEDs, it will damage
LEDs.Damaged LEDs will show some abnormal characteristics such as remarkable
increase of leak current, lower turn-on voltage and getting unlit at low current.
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 10/16
Packaging
Tape Dimension
Dim. A
Dim. B
Dim. C
Q’ty/Reel
0.72±0.03
0.72±0.03
0.56±0.03
24K
nit: mm
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 11/16
Reel Dimension
Packing
28
28 boxes per carton is available depending on shipment quantity.
Official Product
Tentative Product
reserved.
Customer Part No.
Data Sheet No.
01/09/2020
Version 1.0
Page 12/16
Dry Pack
All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times
during transportation or storage. Every reel is packaged in a moisture protected anti-static bag.
Each bag is properly sealed prior to shipment.
Upon request, a humidity indicator will be included in the moisture protected anti-static bag
prior to shipment.
The packaging sequence is as follows:
Baking
Baking before soldering is recommended when the package has been unsealed for 4weeks.
The conditions are as followings:
1. MBB open≤672hrs, 50±3℃×(3hrs)
2. MBB open>672hrs, 60±3℃×(8~12hrs)and
