HV-32H307B/260/SUBUYMSUG-U1930 数据手册
3.0mm Round LED LAMP with Holder
Harvatek 3.0mm Round LED LAMP with Holder
Official Product
Specifications are subject to change without notice. Data
and drawings herein are copyrighted.
Customer Part No.
Data Sheet No.
Aug.17.2021 Version of 1.0
Page 1/16
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of the
application or use of any product or circuit described herein; neither does it convey any license
under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support devices or
systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to perform
can be reasonably expected to cause the failure of the life support device or system, or to affect its
safety or effectiveness.
Official Product
Customer Part No.
Data Sheet No.
Page 2/16
Compliance and Certification
ISO9002, QS9000 and ISO14001 Certified
RoHS Compliant
Orderable Information
H V - 32 H 307B / 260 / SUBUYMSUG - U1930
Series Name
HV :
HARVATEK
Color Code
Remark
32H307B:Array 2 Lamp
260:
3.0mm Round LED LAMP.
SUBUY:
InGaN 470nm Blue Chip
AlGaInP590nm Yellow Chip.
SUG :
InGaN 520nm Green Chip.
M:
White Diffused
U1930:
Customer Product
Code
Features:
Stable Color
Popular 3.0mm through hole package.
White diffused lens and Green diffused lens.
Official Product
Customer Part No.
Data Sheet No.
Page 3/16
Package Dimensions:
Notes:
1.All dimensions are millimeters.
2.Tolerance is +/-0.25mm unless otherwise noted.
3.Specifications are subject to change without notice.
Official Product
Customer Part No.
Data Sheet No.
Page 4/16
Absolute Maximum Ratings at Ta=25℃
Parameter
Symbol
Rating
Unit
Forward Current
IF
30
mA
Operating Temperature
Topr
-40to+85
Storage Temperature
Tstg
-40to+100
Soldering Temperature*1
Tsol
260±5
Power Dissipation
Pd
Reverse Voltage
VR
Peak Forward Current*2
IFP
Y
75
B/G
100
Y/B
1.1
G
5
Y
75
B/G
100
mW
V
mA
*1:Soldering time ≦ 5 seconds. *2.Pulse Width≦ 100μs and Duty≦ 1%.
Official Product
Customer Part No.
Data Sheet No.
Page 5/16
Electrical and Optical Characteristic
Parameter
Symbol
Forward Voltage
VF
Reverse Current
IR
Luminous Intensity
Viewing Angle
IV
Condition
IF=20 mA
Dominant Wavelength
Spectrum Radiation
Bandwidth
λρ
λd
Δλ
Typ.
Max.
B/G
3.0
3.6
Y
2.0
2.5
10
B
100
600
Y
40
200
G
300
500
80
B
465
Y
595
G
516
B
470
Y
590
G
520
B
25
Y
G
30
VR= 1.1V
B/Y
VR= 5 V
G
IF=20 mA
2θ1/2
Peak Wavelength
Min.
IF=20 mA
IF=20 mA
IF=20 mA
IF=20 mA
Unit
V
μA
mcd
deg
nm
nm
nm
Notes:θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline
value.
Official Product
Customer Part No.
Data Sheet No.
Page 6/16
Specifications for Bin Grading:(B)
Iv(mcd)
Grade
Min.
Max.
R
100
200
S
160
320
T
250
500
U
400
800
V
630
1250
λd(nm)
Grade
Min.
Max.
2
463.0
466.5
3
465.5
468.5
4
467.5
470.5
5
469.5
472.5
6
471.5
474.5
7
473.5
476.5
Notes:
1.Luminous intensity:+/-15%.
2.Wavelength: +/-1nm.
Official Product
Customer Part No.
Data Sheet No.
Page 7/16
Specifications for Bin Grading:(Y)
Iv(mcd)
Grade
Min.
Max.
P
40
80
Q
63
125
R
100
200
S
160
320
T
250
500
U
400
800
λd(nm)
Grade
Min.
Max.
3
585
588
4
587
590
5
589
592
6
591
594
7
593
595
Notes:
Official Product
Customer Part No.
Data Sheet No.
Page 8/16
Specifications for Bin Grading:(G)
Iv(mcd)
Grade
Min.
Max.
T
300
500
U
400
800
V
630
1250
λd(nm)
Grade
Min.
Max.
1
516.5
519.5
2
518.5
521.5
3
520.5
523.5
4
522.5
525.5
5
524.5
527.5
6
526.5
529.5
Notes:
Official Product
Customer Part No.
Data Sheet No.
Page 9/16
Typical Electro-Optical Characteristics Curves(B)
Official Product
Customer Part No.
Data Sheet No.
Page 10/16
Typical Electro-Optical Characteristics Curves(Y)
Official Product
Customer Part No.
Data Sheet No.
Page 11/16
Typical Electro-Optical Characteristics Curves(G)
Official Product
Customer Part No.
Data Sheet No.
Page 12/16
Soldering condition
1.
Careful attention should be paid during soldering. When soldering, leave more then 2mm from
solder joint to Led, and soldering beyond the base of the tie bar is recommended.
2.
Avoiding applying any stress to the lead frame while the LED are at high temperature
particularly when soldering.
3.
Dip and hand soldering should not be done more than one time.
4.
After soldering the LED, the epoxy bulb should be protected from mechanical shock or vibration
until the LED return to room temperature.
5.
A rapid-rate process is not recommended for cooling the LED down from the peak temperature.
6.
Although the recommended soldering conditions are specified in the above table, dip or hand
soldering at the lowest possible temperature is desirable for the LED.
7.
Wave soldering parameter must be set and maintain according to recommended temperature
and dwell time in the solder wave.
• Recommended soldering conditions
Hand Soldering
Wave Soldering
Temp. at tip of iron
300℃ Max. (30W Max.)
Preheat temp.
160℃ Max. (120 sec Max.)
Soldering time
3 sec Max.
Bath temp. & time
260 Max., 5 sec Max
Distance
Official Product
2mm Min.(From solder joint to
Led)
Distance
2mm Min. (From solder joint
to Led)
Customer Part No.
Data Sheet No.
Page 13/16
Reliability test items and conditions:
The reliability of products shall be satisfied with items listed below.
Confidence level:97%
LTPD:3%
Item
Test Conditions
Solder Heat
TEMP:260℃±5
10 SEC
76 PCS
0/1
Temperature Cycle
H:+100℃ 15min
∫ 5min
L:-40℃ 15min
300
CYCLES
76 PCS
0/1
3
Thermal
H:+100℃ 5min
∫ 10sec
L:-10℃ 5min
300
CYCLES
76 PCS
4
High Temperature
Storage
TEMP:100℃
1000 HRS
76 PCS
5
Low Temperature
Storage
TEMP:-40℃
1000 HRS
76 PCS
0/1
6
DC Operating Life
TEMP:25℃
IF=20mA
1000 HRS
76 PCS
0/1
7
High Temperature /
High Humidity
85℃/85%RH
1000 HRS
76 PCS
0/1
No
1
2
Shock
Sample
Size
Failure
Judgment
Criteria
Test
Hours/Cycle
Iv≦Ivt*0.5
or
Vf≧U
or
Vf≦L
Ac/Er
0/1
0/1
Note:Ivt:To test Iv value of the chip before the reliability test.
Iv:The test value of the chip that has completed the reliability test
U:Upper Specification Limit
L:Lower Specification Limit
Official Product
Customer Part No.
Data Sheet No.
Page 14/16
Packing Specification:
CU
TE
TY
DA
ER
Q'
N.
OM
P/
ST
250PCS/Bag
CO
DE
PA
RT
S
/M
PC
ar
XX
Ye
NO
XX
on
th
/D
ay
1000PCS/In-Carton
CU S TO M E R
P / N .:
Q'TY:
DATE CODE:
T O TA L :
PART NO.
XXXXPCS
Year/Month/Day
XXXX PC S
10000PCS/Out-Carton
CUSTOMER
P/N.:
Q'TY:
DATE CODE:
TOTAL:
PART NO.
XXXXPCS
Year/Month/Day
XXXX PCS
Official Product
Customer Part No.
Data Sheet No.
Page 15/16
Revision History
Revision
Page
Initial Release
Official Product
Version No.
Revision Date
1.0
08-17-2021
Customer Part No.
Data Sheet No.
Page 16/16
HV-32H307B/260/SUBUYMSUG-U1930 价格&库存
很抱歉,暂时无法提供与“HV-32H307B/260/SUBUYMSUG-U1930”相匹配的价格&库存,您可以联系我们找货
