RSSV013010W0101-U1930 数据手册
Infrared Sensor
Harvatek Infrared Sensor Data Sheet
2nd Generation Proximity Sensing Module
Official Product
HT Part No. RSSV013010W0101-U1930
Tentative Product
Specifications are subject to change without notice.
Data and drawings herein are copyrighted.
08/26/2022
Version 1.1
Page 1/14
Infrared Sensor
Table of Contents
Features..............................................................................................................………3
General Description ..........................................................................................………3
Applications .......................................................................................................………3
Selection Table ..................................................................................................………4
Pin Assignment..................................................................................................………4
Pin Description ..................................................................................................………4
Block Diagram ........................................................................................................…..5
Absolute Maximum Ratings ..............................................................................………5
D.C. Electrical Characteristics..........................................................................………5
A.C. Electrical Characteristics ..........................................................................………6
UART Interface ........................................................................................………6
Functional Description ......................................................................................………7
System Description .................................................................................………7
Detection Distance Learning Function..................................................………9
Application Circuits ...........................................................................................………9
Interface..............................................................................................................……..10
UART Interface ........................................................................................….….10
Dimensions ........................................................................................................….….15
Official Product
Tentative Product
08/26/2022
Version 1.1
Page 2/16
Infrared Sensor
■Features
Wide distance detection application
Operating voltage: 3.3V/5.0V
Low current consumption:
Standby current: Typ. 14μA (3.3V / default at 85cm / scanning time = 0.5s)
Wide operating range:
Distance: 1~100cm
Factory-calibrated
Detection distance learning function
Optional communication interfaces: UART Mode or I/O Mode
■General Description
This device is an infrared proximity sensing module, which is designed for object detection applications.
When an object enters the detection range, the reflected energy of the infrared will change. Proximity is
determined by detecting changes in reflection. Compared with the general infrared sensing modules on
the market, this module has a small size, supports detection of objects at a distance of up to 100cm and
has a low standby current consumption of 14μA at 3.3V, allowing the module to meet the requirements
of a large number of product applications with varying power designs.
Having a modular design ensures much reduced product development time. This proximity sensing
module is suitable used for all types of smart home electronic products, such as smart door locks, smart
makeup mirrors, smart sanitary ware and automatic dryers. The module provides two user selectable
output modes, namely I/O and UART types. When used together with a dedicated development platform,
the required module characteristics can be rapidly setup and adjusted to implement fast and convenient
product development.
■Applications
White goods
Consumer electronics
Electrical door locks
Bath equipments
Official Product
Tentative Product
08/26/2022
Version 1.1
Page 3/16
Infrared Sensor
■Selection Table
Part Number
Distance (25℃/Indoor)
Interface
Description
RSSV013010W0101
1~100cm
UART (9600bps), I/O
Miniaturized size and no
LED indicator
■Pin Assignment
+ (VDD)
NC
(GND)
NC
IR
PD
NC
D (TX/OUT)
NC
C (RX/IN)
■Pin Description
Pin Symbol
Mode
Function
Description
I/O
IN
Learning key input
UART
RX
UART (9600bps) receiving pin
I/O
OUT
Level output
UART
TX
UART (9600bps) transmitting pin
UART, I/O
GND
Connect to ground
UART, I/O
VDD
Positive power supply (VDD63, IEmission=(Dn-64)×5+5
Dn≤63, IEmission=Dn×5+5
Ext: Dn=95, IEmission=(95-64)×5+5=160
Module Response: 0x55, 0xC0, 0x0D, 0x01, Dn, CS.
Write Commands
No.
PID
CMD
An
Len
Dn
CS
Content
Proximity Sensing Trigger Threshold Value.
1
0x55
0xC0
0x08
0x01
Dn
CS
Dn: 16~180
Module Response: 0x55, Ack, CS.
IR Trigger Debounce Times (Noise Filter).
2
0x55
0xC0
0x09
0x01
Dn
CS
Dn: 0~15
Infrared Detection Reaction Speed.
Dn: Detection time
0x00: 8 ms, 0x01: 16 ms, 0x02: 32 ms,
3
0x55
0xC0
0x0A
0x01
Dn
CS
0x03: 64 ms, 0x04: 128 ms, 0x05: 256 ms,
0x06: 0.5s,
0x07: 1s,
0x08: Fast
Mode.
Delay OFF output when an object is detected.
(only valid in normal High/Low output mode)
Dn:
0: Not activate delay OFF output function
4
0x55
0xC0
0x0B
0x01
Dn
CS
(always high/low level output)
1~255: Activate delay OFF output
function,
delay=1~255s
5
0x55
0xC0
0x0C
0x01
Dn
CS
Mode Function Setup
Official Product
Tentative Product
08/26/2022
Version 1.1
Page 13/16
Infrared Sensor
Dn: Default 00000000
Bit 4~0: Reversed
Bit 5: Output mode selection
0: Normal High/Low output mode
1: Pulse/Toggle switching mode
Bit 6: Pulse/Toggle selection (only valid when
Bit 5=1)
0: Pulse (After object approaches, ON
output
for 200μs every 1s)
1: Toogle (ON output when object
approaches; OFF Output when object
leaves and approaches again)
Bit 7: Output level setup
0: Normal high, low active
1: Normal low, high active
Current value for infrared tube emission.
6
0x55
0xC0
0x0D
0x01
Dn
CS
Dn: 0~63, 5mA/step with one-level amplifier
64~127, 5mA/step with two-level amplifier
Module Responses
No.
PID
Ack
CS
Content
1
0x55
0x7F
D4
Completed
2
0x55
0x7E
D3
Failed
3
0x55
0x7D
D2
Learning success
4
0x55
0x7C
D1
Learning failed
Official Product
Tentative Product
08/26/2022
Version 1.1
Page 14/16
Infrared Sensor
■Dimensions
Unit
No.
mm
inch
Øa
1.2
0.047
A
10
0.394
B
7.5
0.295
C
4
0.157
D
2.5
0.098
E
2
0.079
F
1.3
0.051
G
12.7
0.5
H
11.6
0.457
I
10.7
0.421
J
9.9
0.39
K
7.6
0.299
L
5.6
0.22
M
2.5
0.098
Official Product
Tentative Product
08/26/2022
Version 1.1
Page 15/16
Infrared Sensor
N
1.7
0.067
O
1.1
0.043
P
5
0.197
Q
2
0.079
R
9
0.354
S
1
0.039
T
8.95
0.352
U
6.45
0.254
V
3.95
0.156
W
7.2
0.283
X
3.7
0.146
Y
2.2
0.087
Z
1
0.039
Official Product
Tentative Product
08/26/2022
Version 1.1
Page 16/16
RSSV013010W0101-U1930 价格&库存
很抱歉,暂时无法提供与“RSSV013010W0101-U1930”相匹配的价格&库存,您可以联系我们找货
