T4203GRB-12C-61013TU1930 数据手册
Side View PLCC IC+RGB LED
Harvatek Surface Mount PLCC IC+RGB LEDs Data Sheet
T4203GRB-12C61013TU1930
(Preliminary)
Feature Description:
Top SMD integrates high-quality external control single-wire serial cascade
constant current IC.
The control circuit and chip are integrated in the SMD 4020 components,
forming a
complete external control pixel, with uniform color temperature
effect and high consistency.
Built-in data shaping circuit, any pixel receives the signal after waveform
shaping
and then outputs it to ensure that the line waveform distortion will
not accumulate.
Built-in power-on reset and power-off reset circuit, no light when power on.
Grayscale adjustment circuit (256-level grayscale adjustable).
Special treatment for red light drive, more balanced color matching,
Single-line data transmission, infinite cascade.
Shaping forwarding enhancement technology, the transmission distance
between two points exceeds 10M.
The data transmission frequency can reach 800Kbps, when the refresh rate is
30 frames/second, the number of cascades is not less than 1024 points.
Applications
LED full-color light-emitting character string, LED full-color module,
LED magic soft and hard light strip, LED guardrail tube, LED
appearance/scenario lighting.
LED point light source, LED pixel screen, LED special-shaped screen,
various electronic products, electrical equipment marquee.
7
Official Product
HT Part No. T4203GRB-12C-61013TU1930
Tentative Product
Specifications are subject to changes for improvement without advance
notice. Proprietary data, drawings, company confidential all rights reserved.
03/29/2023
Preliminary
Page 1/17
DISCLAIMER ......................................................................................................................................... 3
LIFE SUPPORT POLICY ............................................................................................................. 3
PRODUCT SPECIFICATIONS............................................................................................................. 4
ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ............................................... 4
LABEL SPECIFICATIONS ................................................................................................................... 5
ABSOLUTE MAXIMUM RATING ................................................................................................... 7
ELECTRO-OPTICAL CHARACTERISTICS ...................................................................................... 7
ELECTRICAL CHARACTERISTICS ................................................................................................ 7
DYNAMIC CHARACTERISTICS ..................................................................................................... 8
APPLICATION CIRCUIT .............................................................................................................. 8
CASCADING DATA STRUCTURE .................................................................................................. 9
LED APPLICATION CIRCUIT .................................................................................................... 11
PRECAUTION FOR USE .................................................................................................................... 12
PACKAGING ........................................................................................................................................ 13
TAPE DIMENSION ................................................................................................................... 13
REEL DIMENSION ................................................................................................................... 13
PACKING ............................................................................................................................... 14
DRY PACK ............................................................................................................................ 15
BAKING................................................................................................................................. 15
PRECAUTIONS ....................................................................................................................... 15
REFLOW SOLDERING ...................................................................................................................... 16
REWORKING .......................................................................................................................... 16
CLEANING ............................................................................................................................. 16
CAUTIONS OF PICK AND PLACE .............................................................................................. 17
REVISE HISTORY ................................................................................................................... 17
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 2/17
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of
the application or use of any product or circuit described herein; neither does it convey any
license under its patent rights, nor the rights of others.
Life Support Policy
HARVATEK’s products are not authorized for use as critical components in life support devices
or systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when
properly used in accordance with instructions for use provided in the labeling, can be
reasonably expected to result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to
perform can be reasonably expected to cause the failure of the life support device or system, or
to affect its safety or effectiveness.
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 3/17
Product Specifications
Item
Specification
Luminous
Red : 300~500 mcd
Intensity(Iv)
Green : 700~1500 mcd
Material
Quantity
Blue : 200~3000 mcd
IC@5V, R/G/B@12mA
O
Ts= 25 C; Tolerance ±10%
Red : 620.0~630.0 nm
Wavelength
Green : 515.0~530.0 nm
Blue : 460.0~475.0 nm
IC@5V, R/G/B@12mA
O
Applied voltage
5V_DC
View angle
120o
Resin
Clear
Epoxy
Carrier tape
EIA 481-1A specs
Conductive black tape
Reel
EIA 481-1A specs
Conductive black
Label
HT standard
Paper
Packing bag
250x230mm
Aluminum laminated bag/ no-zipper
One reel per bag
Carton
HT standard
Paper
Non-specified
3000 ea/reel
Others:
Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin
combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label
as well.
Note :This is shipped test conditions
※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product,
such operation can cause migration resulting in LED damage.
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based
chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts
built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must
be taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 4/17
Label Specifications
Harvatek P/N:
T
420
3
GRB-
12C
Product
Package
Dice Q’ty
Color
Current
3:Tri
GRB (Full Color)
12mA
61
01
3T
System
Series Number
Taping
00~ZZ
X001~XZZZ
4.0(L)x2.0(W)x1.6(H)
L/F
1.Taping style
mm
2. Q’ty
Lot No.
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 5/17
Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering
(Unit:mm Tolerance: +/-0.1)
Outline Dim.
Soldering Pattern
Soldering terminals may shift in the Wd direction.
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 6/17
Absolute Maximum Rating
(Max., TA=25oC, VSS=0V)
Symbol
Parameter
Range
Units
VDD
Power Supply Voltage
+3.7~+5.5
V
VIN
Logic Input Voltage
-0.5~VDD+0.5
V
Topt
Operating temperature
-40 C to +85 C
Tstg
Storage Temperature
-40 C to +85 C
VESD
ESD Voltage
o
o
o
o
o
o
2
C
C
kV
Electro-Optical Characteristics
Series
Forward
Emitting Color
Dominant Wavelength
T4203GRB
Viewing
Material
Current(mA)
IV(mcd)
Angle 2 1
2
(nm)
R
12
AlInGaP
620-630
300-500
120
G
12
InGaN
515-530
700-1500
120
B
12
InGaN
460-475
200-300
120
Electrical characteristics
(TA=-20~+70oC, VDD=4.5~5.5V, VSS=0V)
Symbol
Parameter
Min.
Typ.
Max.
Units
Note
VDD
Supply Voltage
5.2
V
VDS.MAX
R/G/B port pressure
26
V
Iout
R/G/B Driving Current
12
mA
VDS_R/G/B=1V
49
mA
-50
mA
IDOH
IDOL
DOUT Drive Capability
VIH
Input High “H” of DI
0.7*VDD
V
VlL
Input Low “L” of DI
0.3*VDD
V
VDD=5V
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 7/17
FPWM
The Frequency of PWM
IDD
Static Power Consumption
1.2
1.0
KHz
mA
VDD=4.5V, OUT R/G/B
Dynamic characteristics
(TA=25oC)
Symbol
Parameter
Condition
Min
Typ.
Max
Units
fDIN
Data Transfer Rate
Duty Ratio (67%)
800
kHZ
500
ns
500
ns
100
ns
100
ns
TPLH
DOUT Propagation Delay
DINDOUT
TPLH
Tr
IOUT Rise Rate
VDS=1.5V
Tf
IOUT12mA
Application circuit
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 8/17
No.
Symbol
Pin
Function
1
DIN
Data Input
Control Data Signal Intput
2
VDD
Power
Power
3
DOUT
Data Output
Control Data Signal Output
4
GND
Ground
Ground
Cascading data structure
(TH+TL=1.25us±600ns)
Item
Description
Min.
Typical
Max.
Allowance
TOH
0 code, high voltage time
200 ns
320 ns
400 ns
±150 ns
T1H
1 code, high voltage time
800 ns
±150 ns
TOL
0 code, low voltage time
580 ns
640 ns
1000 ns
±150 ns
T1L
1 code, low voltage time
200 ns
±150 ns
RES
reset time
>80μs
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 9/17
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 10/17
LED Application Circuit
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 11/17
Precaution for Use
1. The chips should not be used directly in any type of fluid such as water, oil, organic
solvent, etc.
2. When the LEDs are illuminating, the maximum ambient temperature should be first
considered before operation.
3. LEDs must be stored in a clean environment. A sealed container with a nitrogen
atmosphere is necessary if the storage period is over 3 months after shipping.
4. The LEDs must be used within 48 hours after unpacked. Unused products must be
5.
6.
repacked in an anti-electrostatic package, folded to close any opening and then stored in
a dry and cool space.
The appearance and specifications of the products may be modified for improvement
without further notice.
The LEDs are sensitive to the static electricity and surge. It is strongly recommended to
use a grounded wrist band and anti-electrostatic glove when handling the LEDs. If a
voltage over the absolute maximum rating is applied to LEDs, it will damage LEDs.
Damaged LEDs will show some abnormal characteristics such as remarkable increase of
leak current, lower turn-on voltage and getting unlit at low current.
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 12/17
Packaging
Tape Dimension
Dim. A
Dim. B
Dim. C
Q’ty/Reel
2.15±0.10
2.15±0.10
1.05±0.10
3K
Reel
Dimension
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 13/17
Packing
5 or 10 boxes per carton is available depending on shipment quantity.
7
Official Product
Tentative Product
03/29/2023
Preliminary
Page 14/17
Dry Pack
All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times
during transportation or storage. Every reel is packaged in a moisture protected anti-static bag.
Each bag is properly sealed prior to shipment.
A humidity indicator will be included in the moisture protected anti-static bag prior to shipment.
The packaging sequence is as follows:
Baking
Baking before soldering is recommended when the package has been unsealed for 48 hours.
The conditions are as followings:
1. 60±3℃×(12~24hrs)and
