157-00281
    HELLERMAN(海尔曼太通)
    标准,锁定 黑色 2.25"(57.15mm) 0.500"(12.70mm) 120 磅(54.43 kg)
157-00281 数据手册
Materials Guide for Bundling & Securing 1000 — — 540 – – – – ºF ºC 460 — – – – – 440 — – – – – 420 — – – – – 400 — – – – – 380 — – – – – 360 — – – – – 300 — – – – – 280 — – – – – 260 — – – – – 240 — ETFE  -80°C to 180°C (-112°F to 356°F)  UV and Chemical Resistance — 180 – – – – — 170 – – – – — 160 – – – – — 150 – – – – — 140 – – – – — 130 – – – – — 120 – – – – — 110 PPS  -40°C to 160°C (-40°F to 320°F)  Impact Resistance  Chemical Resistance PVDF  -80°C to 150°C (-112°F to 302°F)  UV and Chemical Resistance ECTFE  -76°C to 150°C (-104°F to 302°F)  Flame Retardant and Low Smoke PA4/6  -40°C to 135°C (-40°F to 275°F)  High Performance Nylon PA6/6 Heat Stabilized  -40°C to 125°C (-40°F to 257°F)  Heat and Chemical Resistance Polypropylene  -40°C to 115°C (-40°F to 239°F)  Chemical Resistance PA6/6 Impact, Heat and UV Resistant  -40°C to 105°C (-40°F to 221°F)  Resistance to UV and Vibration Tested to -40°C to 125°C (-40°F to 257°F) on specific products.** PA12  -40°C to 95°C (-40°F to 203°F)  UV Resistance, Low Moisture Absorption 200 — – – – – POM / Polyacetal  -40°C to 85°C (-40°F to 185°F)  UV Resistance w/additives  Hydrophobic, Chemical Resistance – – – – – – – – 220 — – – – – 180 — – – – – 160 — — 100 — 90 — 80 – – – – — 70 * Ratchet P-Clamps, Cable Ties and Fir Tree Assemblies ** Ratchet P-Clamps PA6/6 UV Resistant  -40°C to 85°C (-40°F to 185°F)  UV Resistance, Low Moisture Absorption PA6/6 Flame Retardant  -40°C to 85°C (-40°F to 185°F)  Where UL94-V0 is Required (125ºC or Less) – – – – STANDARD TEMPERATURE – – – – Tested to -55°C to 200°C (-57°F to 392°F) on specific products.* MODERATE TEMPERATURE 320 — PAEK  -55°C to 190°C (-67°F to 374°F)  High Strength and Flame Resistance HIGH TEMPERATURE – – – – PEEK  -55°C to 240°C (-67°F to 464°F)  High Strength and Flame Resistance (125ºC to 150º) 340 — – – – — 230 – – – – — 220 – – – – — 210 – – – – — 200 – – – – — 190 – – – – (150º to 175ºC) – – – – — 240 – (175ºC +) Stainless Steel  -80°C to 540°C (-112°F to 1000°F)  304 and 316 Grade  Extreme Conditions EXTREME TEMPERATURE – – – – PA6/6  -40°C to 85°C (-40°F to 185°F)  UV Resistant, Flame Retardent Grades Available Metal Content Ties  -40°C to 85°C (-40°F to 185°F)  Detectable by X-Ray Scanners © HellermannTyton 2016
157-00281 价格&库存
很抱歉,暂时无法提供与“157-00281”相匹配的价格&库存,您可以联系我们找货
