MRF18-8R-PC
MRF18-8R-PC
    HRS(广濑)
    8 位置 插座 连接器 通孔 镀金
MRF18-8R-PC 数据手册
MKT-E-13088F MRF18 Series Vertical Mating, Non-Magnetic 8-channel Coaxial Connector  Features 1.Non-Magnetic coaxial connector 2. Small Size & Light Weight 3. Vertical mate, horizontal cable out 4. High lock strength & cable pull resistance 5. Easy cable termination with soldering both center and outer conductors 6. Flow mounting or manual soldering for PCB mounting 7. Applicable cable ranges from  1.13 to 1.8 mm 8.RoHS compliant  Small Size & Light Weight  Vertical Mate Allows Layout on PCB Center 37 6.4 in mated 4.6 grams (cable is not included) Plug: MRF18-8P-178B/U 17 .7 Receptacle: MRF18-8R-PC  Specifications Characteristic Impedance 50  Operating Temperature Range -40 C to + 125 C (includes temperature rise caused by current flow) V.S.W.R. 1.3 Max. from DC to 1 GHz 1.4 Max. from 1 to 2 GHz Contact Resistance Center: 35 m Max. Outer: 20 m Max. Insulation Resistance 500 M Min. (DC100 V)  High Frequency Characteristics Data at [Port 1] HRM-306 Test PCB MRF18-8P-178B/U ASSY L=100 mm RG-178B/U Cable V.S.W.R. Cable Outer Dia.:  1.13 to 1.8 mm Cable Pull Force: 70 N/line (Actual measured value with RG-178B/U cable ) Lock Strength: 28 N (Actual measured value when cables are pulled up) Insertion Loss (dB) [Port 1] MRF18-8R-PC HRM-200-088BPJBN 0 2 Insertion Loss -1 1.8 -2 1.6 -3 1.4 V.S.W.R. -4 1.2 Withstanding Voltage AC 300 V for 1 minute Durability 30 times -5 1 1 1.5 Frequency (GHz) Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities. © 2014 HIROSE ELECTRIC CO., LTD. All rights reserved. 0 0.5 2 Issued: Mar. 28, 2014
MRF18-8R-PC 价格&库存
很抱歉,暂时无法提供与“MRF18-8R-PC”相匹配的价格&库存,您可以联系我们找货
