USB-to-CAN V2
Active USB interface
2 x CAN (High-/Low-Speed), LIN
With up to two CAN High Speed channels, one CAN Low Speed
channel, and a LIN channel, depending on the device variant, a
wide variety of applications can be addressed by the USB-to-CAN
V2 – in both the industrial and the automotive sectors.
FEATURES AND BENEFITS
Cost-effective and extremely versatile
Common driver interface for easy exchange of the PC interface type
For industrial and automotive applications
Galvanic isolation optional
VARIANTS
The USB-to-CAN V2 is available in different variants. In the USB-to-CAN V2 compact variant, the CAN connection is implemented as a
D-SUB 9 plug or alternatively as an RJ45 connector. For devices with two CAN interfaces, these are implemented as RJ45 connectors.
Adapter cables to sub-D9 plugs are included with the devices.
The IXXAT USB-to-CAN V2 embedded is designed without a housing, with or without a slot board and adapted USB cable for
installation into a computer.
Additional options include galvanically isolated CAN interfaces, bulk variants, and support for ISO 11898-3 low-speed CAN and LIN.
Compact
Compact
D-SUB 9
RJ45
Professional
Automotive
Embedded
LIN (AUTOMOTIVE VARIANT)
LIN communications are supported in either LIN master or LIN slave mode. As LIN slave, the interface responds automatically to
master requests it receives. The response data is updated through the PC API using a buffer. In master mode, the master calls are
processed by the PC application. Incoming LIN messages are forwarded to the application with a timestamp, master request,
response, and status information.
COMPARISON OF THE DIFFERENT USB-CAN INTERFACES
HMS offers under the Ixxat brand different USB interfaces for CAN. Besides a one or two channel version and the support of CAN FD
and LIN, also an embedded variant for implementation into customer devices is offered. An overview and comparison of the available
USB interfaces can be found on the following page:
1/3
Comparison of the Ixxat USB-CAN interfaces
HIGH PERFORMANCE
By using powerful hardware and connecting over USB 2.0 Hi-Speed (480 MBit/sec), the USB-to-CAN V2 interfaces achieve very high
data throughput with minimum latency and low power consumption. This allows them to provide the reliable, loss-free transmission
and receipt of messages in CAN networks at high transmission rates and bus load. The messages are also timestamped and can be
filtered and buffered directly in the USB-to-CAN V2.
Due to its extremely interesting price and compact size, the USB-to-CAN V2 interface is ideal for use in series products and in
combination with the canAnalyser for development, service, and maintenance tasks.
Its newly developed, rugged housing permits easy customer-specific adaptation (custom design / brand labeling).
TECHNICAL SPECIFICATIONS
PC bus interface
USB 2.0, Hi-Speed
Microcontroller
32 bit
CAN controller
Internal; CAN 2.0 A/B
CAN baudrates
10 kBit/s ... 1 Mbit/s
CAN high-speed transceiver
TI SN65HVD251D
CAN low-speed transceiver
(1)
TJA1055T
LIN transceiver (1)
TJA1020
LIN protocol (1)
V1.3 and V2.0
LIN baudrate (1)
max. 20 kBaud
Galvanic isolation
1000 VDC for 1 sec
500 VAC for 1 min.
Power supply
5 V, max. 500 mA via USB port
Temperature range
-20°C ... 70°C
Fieldbus connection
according to CiA 303-1
Certification
CE, EN 55022:2010, EN61000-6-1:2007
(1) only available in USB-to-CAN V2 automotive
CONTENTS OF DELIVERY
USB-to-CAN V2 interface in the compact, embedded, professional, or automotive variant
2 x RJ45 to Sub-D9 adapter cable (only USB-to-CAN V2 professional/automotive)
Manual
CAN driver VCI for Windows XP, Windows 7, Windows 8, Windows 10
Simple "canAnalyser Mini" CAN bus monitor
Order numbers / variants
Variants /
CAN
CAN
Fieldbus
D-SUB
Features
HS
LS
LIN ports
galv.
9
ports
ports
isolated
RJ45
Order number
2/3
compact
1
X
1
X
1
embedded
(1)
professional
1
X
2
X
X
1.01.0281.12001
X
1.01.0281.12002
X
1.01.0281.11001
X
1.01.0282.12001
X
1.01.0283.22002
(incl. D-SUB 9
adapter cable)
automotive
2
(2)
1
1
(3)
X
X (incl. D-SUB 9
1.01.0283.22042
adapter cable)
(1) PC installation via slot board and internal USB cable
(2) One channel via software between ISO11898-2 and ISO11898-3 switchable
(3) LIN master / slave mode via software switchable
Copyright © 2020 HMS Industrial Networks - All rights reserved.
3/3
很抱歉,暂时无法提供与“1.01.0283.22002”相匹配的价格&库存,您可以联系我们找货
