E2SB24E001801E
E2SB24E001801E
    HOSONIC
    SIP4
    24 MHz ±20ppm 晶体 12pF 4-SMD,无引线
E2SB24E001801E 数据手册
RoHS Compliant SMD CRYSTAL UNITS E2SB Series Pb Free 2.5*2.0 Seam Sealing Crystal FEATURES Very Compact and thin (2.5*2.0*0.65mm max.) Frequency range of 12M to 62.5M with Fund Excellent electrical performance, ideal for OA (office automation), AV (audiovisual), Bluetooth and Wireless LAN applications Excellent heat resistance and shock resistance Lead-free. Meets the requirements for re-flow profiling using lead -free solder Electrical Specifications Type Item Frequency Range F0 E2SB 12 to 15.999MHz Mode of Vibration 16 to 19.999MHz 20 to 25.999MHz 26 to 62.500MHz Fundamental Load Capacitance Frequency Tolerance CL 8 to 16pF △F/ F0 ±10ppm,±15ppm,±30ppm(At 25℃) 120Ω max. 100Ω max. 80Ω max. Equivalent Series Resistance ESR Temperature Stability TC ±10ppm,±15ppm,±30ppm(Refer to 25℃) Operating Temperature Range TOPR -20~+70℃,-30~+85℃ Option Storage Temperature Range TSTG Shunt Capacitance C0 3pF max. Insulator Resistance IR 500MΩ min. (At 100VDC) Drive Level DL Aging 50µW(100µW max.) ±2ppm max. (At 25℃,First year) Fa 3000pcs/reel Packing Unit **Please contact us for inquiries regarding other Specifications Mechanical Dimensions(mm) Top View 2.50±0.10 4 0.90 0.80 3 4 3 1 2 MARKING AREA 1 2 Recommended Solder Pattern 1.00 0.70 1.00 50Ω max.
E2SB24E001801E 价格&库存
很抱歉,暂时无法提供与“E2SB24E001801E”相匹配的价格&库存,您可以联系我们找货
