E3SB25E001803E
E3SB25E001803E
    HOSONIC
    SIP4
    25 MHz ±20ppm 晶体 12pF 4-SMD,无引线
E3SB25E001803E 数据手册
E3SB Series 3.2*2.5 Seam Sealing Crystal Excellent electrical performance, ideal for OA (office automation), AV (audiovisual), Bluetooth and Wireless LAN applications Lead-free. Meets the requirements for re-flow profiling using lead -free solder Item Frequency Range Type F0 E3SB 10 to 11.999MHz 12 to 19.999MHz Mode of Vibration Load Capacitance Frequency Tolerance 20 to 23.999MHz 24 to 62.500MHz 3RD Fundamental CL 6 to 20pF △F/ F0 ±10ppm,±15ppm,±30ppm(At 25℃) 150Ω max. 100Ω max. 70Ω max. 50Ω max. Equivalent Series Resistance ESR Temperature Stability TC ±10ppm,±15ppm,±30ppm(Refer to 25℃) Operating Temperature Range TOPR -20~+70℃,-30~+85℃ Option Storage Temperature Range TSTG Shunt Capacitance C0 3pF max. Insulator Resistance IR 500MΩ min. (At 100VDC) Drive Level DL Aging 60 to 114.285MHz Fa Packing Unit **Please contact us for inquiries regarding other Specifications 100µW(200µW max.) ±2ppm max. (At 25℃,First year) 3000pcs/reel 100Ω max.
E3SB25E001803E 价格&库存
很抱歉,暂时无法提供与“E3SB25E001803E”相匹配的价格&库存,您可以联系我们找货
