15DYS902-xyG C8 Inlet 96W Desktop Series
Universal Input 100~240VAC 50/60Hz
UL/IEC/EN 62368-1 Approved
Compliant to LVD & EMC safety standards
RoHS & CE Directive Compliant
Level VI efficiency
OVP, OCP, OTP & Short Circuit Protection
C8 Inlet
The purpose of the document is to specify a Single-phase AC input, single output switching power
supply. This specification is suitable for: 15DYS902-xyW 96W Series. This product is AC to DC switching
power supply, it can provide 9-30V 96W max DC output constant voltage source. This Specification
defines the input, output, performance characteristics, environment, noise and safety requirements.
Models
Model Number
Output Voltage
Output Current
Output Power
15DYS902-090750G
9V DC
7.5A
67.5W
15DYS902-120750G
12V DC
7.5A
90W
15DYS902-150600G
15V DC
6A
90W
15DYS902-240400G
24V DC
4A
96W
15DYS902-320300G
32V DC
3A
96W
15DYS902-480200G
48V DC
2A
96W
Input Data
Min
Input Voltage
Input Frequency
Input Current
Inrush Current
Leakage Current
Typical
90
47
Max
Units
Notes
264
63
1.5
80
0.25
V AC
Hz
A
A
mA
100-240VAC +/- 10%
50-60Hz +/- 5%
At cold start, 100 / 240V AC
Output Data
Min
Output Voltage tolerance
Ripple & Noise
Over Current Protection
Over Voltage Protection
Typical
5%
200
Max
Units
Notes
mVp-p
Over Current Point Limited >3.9A
Continuous short circuit proof. Will recover if fault condition is removed
Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple,
Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400
Environmental Data
Minimum
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Typical
10
5
Maximum
Units
Notes
+40
+80
90
95
ºC
ºC
Operating 10% to 90%
Storage 5% to 95%
Other Information
Minimum
Dielectric Strength
MTBF
Weight
Dimensions
Typical
Maximum
Units
Notes
Primary to Secondary: 4242VDC/5mAMax (3 seconds)
hrs
At 25°C, Full load and nominal
450 g -10/+10 Depending on model
Refer to mechanical drawings
50,000
EMC Emissions (2014/30/EU)
Conducted
Radiated
Standard
Test Level
Criteria
EN 55032
EN 55032
Pass
Pass
B
B
Notes
EMC Directive 2014/30/EU
EMC Immunity (2014/30/EU)
Standard
EMS
ESD
EFT
Surge
EN 55035
IEC 61000-4-2
IEC 61000-4-4
IEC 61000-4-5
Test Level
Criteria
Notes
B
A/B
A
Contact: +/- 4KV; Air: +/- 8KV
0.5/1.0KV on input AC power ports
Differential mode: +/- 2KV, Common mode: +/- 2KV
Safety Approvals
Safety Standards
RoHS/REACH
CE LVD Directive 2014/35/EU
cULus
TUV
RCM & C-Tick
RoHS Directive (EU) 2015/863 & REACH (205 SVHC)
Yes (UK/European)
Yes
Yes
Yes
Mechanical Drawing
很抱歉,暂时无法提供与“15DYS902-150600G”相匹配的价格&库存,您可以联系我们找货
