RTE-P2D12
RTE-P2D12
    IDEC
    可编程(多功能) 延时继电器 DPDT(2 Form C) 0.1 秒 ~ 600 小时 延时 10A @ 240VAC/30VDC 可插
RTE-P2D12 数据手册
Timers Signaling Lights Switches & Pilot Lights RTE RTE Series — Analog Timers Key features: • 20 time ranges and 10 timing functions • Time delays up to 600 hours • Space-saving package • High repeat accuracy of ± 0.2% • ON and timing OUT LED indicators • Standard 8- or 11-pin and 11-blade termination • 2 form C delayed output contacts • 10A Contact Rating Cert. No. E9950913332316 (EMC, RTE) Cert. No. BL960813332355 (LVD, RTE) UL Listed File No. E66043 Relays & Sockets General Specifications Solid state CMOS Circuit Operation Type Multi-Mode Time Range 0.1sec to 600 hours Pollution Degree 2 (IE60664-1) Over voltage category III (IE60664-1) Rated Operational Voltage Timers Voltage Tolerance Contactors Contact Ratings Operation System AF20 100-240V AC(50/60Hz) AD24 24V AC(50/60Hz)/24V DC D12 12V DC AF20 85-264V AC(50/60Hz) AD24 20.4-26.4V AC(50/60Hz)/21.6-26.4V DC D12 10.8-13.2V DC Contact Configuration 2 Form C, DPDT (Delay output) Allowable Voltage / Allowable Current 240V AC, 30V DC / 10A Maximum Permissible Operating Frequency 1800 cycles per hour Rated Load Life Input off Voltage Rated Voltage x10% minimum Ambient Operating Temperature -20 to +65ºC (without freezing) Ambient Storage and Transport Temperature -30 to +75ºC (without freezing) Relative Humidity 35 to 85%RH (without condensation) Atmospheric Pressure 80kPa to 110kPa (Operating), 70kPa to 110kPa (Transport) Reset Time 100msec maximum Repeat Error ±0.2%, ±20msec* Voltage Error ±0.2%, ±20msec* Temperature Error ±0.5%, ±20msec* Setting Error ±10% maximum Insulation Resistance 100MΩ minimum (500V DC) Resistive 10A 240V AC, 30V DC Inductive 7A 240V AC, 30V DC Horse Power Rating 1/6 HP 120V AC, 1/3 HP 240V AC Electrical 500,000 op. minimum (Resistive) Mechanical 50,000,000 op. minimum Between power and output terminals: 2000V AC, 1 minute Dielectric Strength Between contacts of different poles: 2000V AC, 1 minute Between contacts of the same pole:1000V AC, 1 minute Terminal Blocks Vibration Resistance Operating extremes: 98m/sec2 (10G) Shock Resistance Damage limits: 490m/sec2 (50G) 3 times in each of 3 axes Degree of Protection IP40 (enclosure) (IEC60529) TYPE Power Consumption (Approx.) Circuit Breakers 10 to 55Hz amplitude 0.5mm2 hours in each of 3 axes RTE-P1, -B1 RTE-P2, -B2 120V AC/60Hz 6.5VA 6.6VA 240V AC/60Hz 11.6VA 11.6VA 24V AC 60Hz/DC 3.4VA/1.7W 3.5VA/1.7W D12 1.6W 1.6W AF20 Mounting Position Dimensions Weight (Approx.) 944 Free RTE-P1, P2 40Hx 36W x 77.9D mm RTE-B1, B2 40Hx 36W x 74.9D mm RTE-P1 RTE-P2 RTE-B1, -B2 87g 89g 85g www.IDEC.com *For the value of the error against a preset time, whichever the largest, applies. 1705151136 Timers RTE Switches & Pilot Lights Part Numbering Guide RTE series part numbers are composed of 4 part number codes. When ordering a RTE series part, select one code from each category. Example: RTE-P1AF20 RTE — j Series P 1 AF20 k Terminal Style l Function Group m Input Voltage Signaling Lights Part Numbers: RTE Series Description Part Number Code RTE series j Series k Terminal Style m Input Voltage For internal circuits, see next page. Pin P Blade B ON-delay, interval, cycle OFF, cycle ON 1 Each function group has different timing functions. ON-delay, cycle OFF, cycle ON, signal ON/ OFF delay, OFF-delay, one-shot 2 See page 940. Select one only. 100 to 240V AC(50/60Hz) AF20 24V AC(50/60Hz)/24V DC AD24 12V DC D12 Relays & Sockets l Function Group Remarks RTE Part Numbers Voltage Power Triggered Start Input Triggered Blade 11-Pin Blade RTE-P1D12 RTE-B1D12 RTE-P2D12 RTE-B2D12 24V AC/DC RTE-P1AD24 RTE-B1AD24 RTE-P2AD24 RTE-B2AD24 100-240V AC RTE-P1AF20 RTE-B1AF20 RTE-P2AF20 RTE-B2AF20 Timers 8-Pin 12V DC Time Range Determined by Time Range Selector and Dial Selector Range Dial 0-3 0 - 10 0 - 30 0 - 60 0.1 sec - 1 sec 0.1 sec - 3 sec 0.2 sec - 10 sec 0.6 sec - 30 sec 1.2 sec - 60 sec Minute 1.2 sec - 1 min 3.6 sec - 3 min 12 sec - 10 min 36 sec - 30 min 1.2 min - 60 min Hour 1.2 min - 1 hr 3.6 min - 3 hr 12 min - 10 hr 36 min - 30 hr 1.2 hr - 60 hr 10 Hours 12 min - 10 hr 36 min - 30 hr 2 hr - 100 hr 6 hr - 300 hr 12 hr - 600 hr Contactors 0-1 Second Terminal Blocks Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 945 Timers RTE Switches & Pilot Lights Timing Diagrams RTE-P1, -B1 RTE-P1 4 6 3 2 7 2 8 Signaling Lights 5 4 66 5 (~/+) 7 external control start signal 1 2 9 8 1 4 8 7 3 1 (~/-) 11 5 46 2 10 (~/+) (~/-) (~/+) A 1 11 RTE-B1 RTE-B2 10 6 4 15 26 7 4 8 5 9 6 B A 7 8 B 9 7 B A A (~/+) (~/-) 3 (~/+) (~/-) A: ON-Delay 1 (power start) Set timer for desired delay, apply power to coil. Contacts transfer after preset time has elapsed, and remain in transferred position until timer is reset. Reset occurs with removal of power. Item Delayed Contact Terminal Number Operation (1) 1 - 3, 6 - 8 (2) 4 - 7, 6 - 9 Delayed Contact (NO) PWR Operation (1) 1 - 4, 5 - 8 (2) 1 - 7, 3 - 9 (NC) (1) 1 - 3, 6 - 8 (2) 4 - 7, 6 - 9 (NO) OUT Set Time Set Time T C: Cycle 1 (power start, OFF first) Set timer for desired delay, apply power to coil. First transfer of contacts occurs after preset delay has elapsed, after the next elapse of preset delay contacts return to original position. The timer now cycles between on and off as long as power is applied (duty ratio 1:1). Delayed Contact Terminal Number (1) 2 - 7 (2) A - B Indicator OUT Item (~/-) PWR Indicator Power 9 B B: Interval (power start) Set timer for desired delay, apply power to coil. Contacts transfer immediately, and return to original position after preset time has elapsed. Reset occurs with removal of power. Power (NC) 8 (~/+) Item (1) 2 - 7 (2) A - B (1) 1 - 4, 5 - 8 (2) 1 - 7, 3 - 9 1. external RTE-B1: Do not apply voltage to terminals #2, #5 & #8. control start 2. signal IDEC sockets are as follows: RTE-P1: SR2P-06* pin type socket, 1 3 blade type socket, (*-may be followed by suffix 2 RTE-B1: SR3B-05* letter4 A,B,C 5 or U). 6 9 (~/-) (~/-) RTE-B2 external control start signal 1 3 2 3 2 7 5 8 8 9 7 3 (~/-) (~/+) Power Relays & Sockets 4 5 (~/+) RTE-P2 RTE-B1 external control start signal 3 1 Timers RTE-P1 RTE-P2 Terminal Number Operation (1) 2 - 7 (2) A - B (1) 1 - 4, 5 - 8 (2) 1 - 7, 3 - 9 (1) 1 - 3, 6 - 8 (2) 4 - 7, 6 - 9 D: Cycle 3 (power start, ON first) Functions in same manner as Mode C, with the exception that first transfer of contacts occurs as soon as power is applies. The ratio is 1:1. Time On = Time Off Item Power (NC) Delayed Contact (NO) T PWR Terminal Number Operation (1) 2 - 7 (2) A - B (1) 1 - 4, 5 - 8 (2) 1 - 7, 3 - 9 (NC) (1) 1 - 3, 6 - 8 (2) 4 - 7, 6 - 9 (NO) PWR Indicator Indicator OUT T T Set Time T T Circuit Breakers Terminal Blocks Contactors Set Time OUT 946 www.IDEC.com 1705151136 Timers RTE Switches & Pilot Lights Timing Diagrams con’t RTE-P2, -B2 RTE-P1 RTE-P2 RTE-P2 RTE-B1 external control start signal external control start signal 4 5 3 2 4 3 1 2 6 67 5 7 8 1 11 3 9 2 3 75 6 4 1 5 2 6 9 7 4 8 A 7 2 A 1 10 (~/+) (~/-) (~/+) 1 54 6 (~/-) (~/+) 8 8 9 7 11 10 RTE-B2 external control start signal B 1 2 5 9 6 4 5 6 8 B 9 7 8 9 A (~/+) (~/-) 3 A B (~/-) (~/+) (~/-) B (~/+) (~/-) Terminal Number 1. RTE-P2: Do not apply voltage to terminals #5, #6 & #7. 2. RTE-B2: Do not apply voltage to terminals #2, #5 & #8. 3. IDEC sockets are as follows: RTE-P2: SR3P-05* pin type socket, RTE-B2: SR3B-05* blade type socket, (*-may be followed by suffix letter A,B,C or U). (~/-) A: ON-Delay 2 (signal start) When a preset time has elapsed after the start input turned on while power is on, the NO output contact goes on. Item 3 Operation B: Cycle 2 (signal start, OFF first) When the start input turns on while power is on, the output oscillates at a preset cycle (duty ratio 1:1), starting while the NO contact off. Item Terminal Number Power (A) 2 - 10 (B) A - B Power (A) 2 - 10 (B) A - B Start (A) 5 - 6 (B) 2 - 5 Start (A) 5 - 6 (B) 2 - 5 (A) 1 - 3, 9 - 11 (B) 4 - 7, 6 - 9 (NC) Delayed Contact (NO) PWR OUT Set Time Set Time T C: Cycle 4 (signal start, ON first) When the start input turns on while power is on, the NO contact goes on. The output oscillates at a preset cycle (duty ratio 1:1). Terminal Number (A) 2 - 10 (B) A - B Start (A) 5 - 6 (B) 2 - 5 Operation (NC) (A) 1 - 3, 9 - 11 (B) 4 - 7, 6 - 9 (NO) (A) 2 - 10 (B) A - B Start (A) 5 - 6 (B) 2 - 5 Indicator OUT T T T T T Ta Operation (A) 1 - 4, 8 - 11 (B) 1 - 7, 3 - 9 (NC) (A) 1 - 3, 9 - 11 (B) 4 - 7, 6 - 9 (NO) PWR T T T T T T T T Power (A) 2 - 10 (B) A - B Start (A) 5 - 6 (B) 2 - 5 Operation Set Time (NC) (A) 1 - 3, 9 - 11 (B) 4 - 7, 6 - 9 (NO) Terminal Number Power (A) 2 - 10 (B) A - B Start (A) 5 - 6 (B) 2 - 5 Delayed Contact Ta T T Ta Indicator OUT (A) 1 - 4, 8 - 11 (B) 1 - 7, 3 - 9 (NC) (A) 1 - 3, 9 - 11 (B) 4 - 7, 6 - 9 (NO) Operation Terminal Blocks PWR T F: One-Shot (signal start) When the start input turns on while power is on, the NO output contact goes on. When a preset time has elapsed, the NO output contact goes off. Item (A) 1 - 4, 8 - 11 (B) 1 - 7, 3 - 9 T Contactors Terminal Number OUT Ta E: Signal OFF-Delay When power is turned on while the start input is on, the NO output contact goes on. When a preset time has elapsed after the start input turned off, the NO output contact goes off. Set Time T Indicator Set Time Delayed Contact T Terminal Number Power Delayed Contact PWR T D: Signal ON/OFF-Delay When the start input turns on while power is on, the NO output contact goes on. When a preset time has elapsed while the start input remains on, the output contact goes off. When the start input turns off, the NO contact goes on again. When a preset time has elapsed after the start input turned off, the NO contact goes off. Item (A) 1 - 4, 8 - 11 (B) 1 - 7, 3 - 9 T Timers Power Item (NO) Indicator OUT Delayed Contact (NC) (A) 1 - 3, 9 - 11 (B) 4 - 7, 6 - 9 PWR Indicator Item (A) 1 - 4, 8 - 11 (B) 1 - 7, 3 - 9 Relays & Sockets Delayed Contact (A) 1 - 4, 8 - 11 (B) 1 - 7, 3 - 9 Operation Signaling Lights (~/+) 4 8 RTE-B1 RTE-B2 external control start 1 3 2 signal PWR Indicator T Ta T OUT Ta Set Time Circuit Breakers 1705151136 800-262-IDEC (4332) • USA & Canada 947 Timers RTE Switches & Pilot Lights Temperature Derating Curves Mounting B 7A Allowable Current 10A Allowable Current Mounting A Mounting A Derating Curve Signaling Lights 5A Mounting B Derating Curve 50ºC 65ºC Ambient Temperature 50ºC 65ºC Ambient Temperature Instructions Installation of Hold-Down Springs DIN Rail Mount Socket Switch Settings Insert the springs into the outer slots with the projections facing inside. Insert the springs into the slots. j Socket SR2P-06 Hold-down Spring (sold separately) SFA-202 (use two springs) Socket SR2P-05 Hold-down Spring (sold separately) SFA-203 (use two springs) l k jOperator Mode Selector kScale Selector lTime Range Selector 1. Turn the selectors securely using a flat screwdriver 4mm wide (maximum). Note that incorrect setting may cause malfunction. Do not turn the selectors beyond their limits. 2. Since changing the setting during timer operation may cause malfunction, turn power off before changing. Timers Relays & Sockets 7A Safety Precautions Contactors Special expertise is required to use Electronic Timers. • All Electronic Timers are manufactured under IDEC’s rigorous quality control system, but users must add a backup or fail safe provision to the control system when using the Electronic Timer in applications where heavy damage or personal injury may occur should the Electronic Timer fail. • Install the Electronic Timer according to instructions described in this catalog. Terminal Blocks • Make sure that the operating conditions are as described in the specifications. If you are uncertain about the specifications, contact IDEC in advance. • In these directions, safety precautions are categorized in order of importance under Warning and Caution. Warnings Warning notices are used to emphasize that improper operation may cause severe personal injury or death. • Turn power off to the Electronic timer before starting installation, removal, wiring, maintenance, and inspection on the Electronic Timer. Circuit Breakers • Failure to turn power off may cause electrical shocks or fire hazard. 948 • Do not use the Electronic Timer for an emergency stop circuit or interlocking circuit. If the Electronic Timer should fail, a machine malfunction, breakdown, or accident may occur. Caution Caution notices are used where inattention might cause personal injury or damage to equipment. • The Electronic Timer is designed for installation in equipment. Do not install the Electronic Timer outside equipment. • Install the Electronic Timer in environments described in the specifications. If the Electronic Timer is used in places where it will be subjected to high-temperature, high-humidity, condensation, corrosive gases, excessive vibrations, or excessive shocks, then electrical shocks, fire hazard, or malfunction could result. • Use an IEC60127-approved fuse and circuit breaker on the power and output line outside the Electronic Timer. • Do not disassemble, repair, or modify the Electronic Timer. • When disposing of the Electronic Timer, do so as industrial waste. www.IDEC.com 1705151136 Timers RTE DIN Rail Mounting Accessories DIN Rail/Surface Mount Sockets and Hold-Down Springs DIN Rail Mount Socket Style Appearance Applicable Hold-Down Springs Use with Timers 11-Pin Screw Terminal (dual tier) Part Number Appearance Part Number Switches & Pilot Lights Accessories SR3P-05 Signaling Lights RTE-P2 SFA-203 SR3P-05C 8-Pin Screw Terminal SR2P-06 Relays & Sockets 11-Pin FingerSafe Socket RTE-P1 8-Pin Fingersafe Socket SR2P-05C 11-Blade Screw Terminal SR3B-05 — BNDN1000 Timers RTE-B1 RTE-B2 SFA-202 DIN Mounting Rail Length 1000mm Panel Mounting Accessories Accessory Panel Mount Adapter Description Appearance Part No. All RTE timers RTB-G01 RTE-P1 SR6P-M08G RTE-P2 SR6P-M11G 8-pin solder terminal RTE-P1 SR6P-S08 11-pin solder terminal RTE-P2 SR6P-S11 Adaptor for flush panel mounting RTE timers 8-pin screw terminal 11-pin screw terminal Terminal Blocks Use with Contactors Flush Panel Mount Adapter and Sockets that use an Adapter (Shown: SR6P-M08G Wiring Socket Adapter) Sockets for use with Panel Mount Adapter 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1705151136 949 Timers RTE Switches & Pilot Lights Dimensions 13.0 77.9 36.0 40.0 13.7 Signaling Lights RTE-P1 (8 pin) Terminal Style Relays & Sockets RTE-P2 (11 pin)Terminal Style 7.3 RTE-B1/RTE-B2 (11 blade) Terminal Style Panel Mount Adapter RTE Timer, 8-Pin and 11-Pin with SR6P-S08 or SR6P-S11 98 maximum Timers 48 42.5 1.7 Panel Thickness 0.8 to 5mm 48 11 Back Wiring Socket 61.2 RTE Timer, 8-Pin with SR6P-M08G 8-M3.5 Terminal Screw Panel Thickness 0.8 to 5mm 44.6 4 5 6 2 1 8 7 30.4 44.6 Contactors 3.5 max. 3 5.6 min. ø3.6 min. 6.9 max. 7 9.8 x 3 80.5 RTE Timer, 11-Pin with SR6P-M11G Terminal Blocks 11-M3.5 Teminal Screws 45 16.7 45 30.5 1 11 7 6 3 8 9 10 3.5 max. 5.8 min. ø3.6 min. 6.9 max. 4 7 8.5 x 4 Circuit Breakers 92 5 34 2 950 www.IDEC.com 1705151136
RTE-P2D12 价格&库存
很抱歉,暂时无法提供与“RTE-P2D12”相匹配的价格&库存,您可以联系我们找货
