ACD-5036-A3-CC-S
ACD-5036-A3-CC-S
    INPAQ(台湾佳邦)
    GPS, 1575MHZ, COUPLING, 5.2*3.7*
ACD-5036-A3-CC-S 数据手册
Contact: INPAQ USA -James Lee Email: jameslee@inpaqusa.com TEL: 267-265-4079 Title: Business Manager ACD-5036-A3-CC-S Specification Product Name Series/PN Size INPAQ RF Chip Antenna ACD-5036-A3-CC-S EIAJ 5036 PN:ACD-5036-A3-CC-S 1.Features and Application This product is for GPS L1 band、1575.42 MHz 2. Explanation of part number AC D (1) (2) (1) (2) (3) (4) (5) (6) (7) - 5036 - A3 - CC - S _ (3) (4) (5) (6) (7) Product Type: Chip Antenna Center Frequency / Band Code: 1575.42 MHz Size Code: 5.0*3.6 mm (Length * Width) Design Revision Code: Rev.3 Antenna type: Coupling Ceramics Special Code: RoHS Compliant Suffix For Special Requirements 3. Electrical Specification Item Specification Frequency Band 1570 ~ 1580 MHz Polarization Linear Impedance 50 ohm Typ. VSWR Less than 2.0 *Peak Gain 3.40 dBi Typ. *Peak Efficiency 83.1 % Typ. * Test condition: Test board size 80*40 mm Matching circuit: Pi matching circuit will be required ACD-5036-A3-CC-S Engineer Specification Version: A5 Page 1 of 8  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com 4. Physical Dimension Top view Bottom view L 5.20 ± 0.30 W 3.70 ± 0.30 H 0.70 ± 0.15 A 0.50 ± 0.25 B 0.50 ± 0.25 L1 1.10 ± 0.20 W1 0.55 ± 0.20 X 0.50 ± 0.10 Y 2.60 ± 0.20 Z 2.95 ± 0.30 (Unit: mm) ACD-5036-A3-CC-S Engineer Specification Version: A5 Page 2 of 8  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com 5. Recommended PCB Layout Contact: INPAQ USA -James Lee Email: jameslee@inpaqusa.com TEL: 267-265-4079 Title: Business Manager 6.Electrical Characteristics Return Loss Frequency (MHz) S11 (dB) 1575 -24.77 1518 -10.00 1623 -10.00 Radiation Pattern The Gain pattern is measured in INPAQ’s FAR-field chamber. DUT is placed on the table of rotator, a standard horn antenna and Vector Network Analyzer is used to collect data. 3D Far Field Chamber Antenna Under Test (AUT) Double Ridge Horn Antenna Rotator Controller PC Agilent 8960 Series 10 (E5515C) 3D Chamber Definition ACD-5036-A3-CC-S Engineer Specification Version: A5 Page 3 of 8  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com ◎ 3D Gain Pattern (1575.42MHz) ◎ 2D Gain Pattern (1575.42 MHz) X-Y Plane X-Z Plane ACD-5036-A3-CC-S Engineer Specification Version: A5 Page 4 of 8  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com Y-Z Plane 7. Taping Package and Label Marking (1) Quantity/Reel: 2000pcs/Reel (2) Carrier tape dimensions Symbol A0= 4.10±0.10 mm Spec. Po 4.00±0.1 P1 8.00±0.1 P2 2.00±0.05 Do 1.55±0.05 D1 1.50(MIN) E 1.75±0.1 F 5.50±0.05 10Po 40.00±0.2 W 12.00±0.1 T 0.25±0.05 B0= 5.60±0.10 mm K0= 1.02±0.10 mm (Unit: mm) ACD-5036-A3-CC-S Engineer Specification Version: A5 Page 5 of 8  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com (3) Taping reel dimensions 8. Environmental Characteristics (1) Reliability Test Item Thermal shock Humidity resistance 1. 2. 3. 4. 5. 1. 2. 3. Condition 30±3 minutes at -40°C±5°C, Convert to +105°C (5 minutes) 30±3 minutes at +105°C±5°C, Convert to -40°C (5 minutes) Total 100 continuous cycles Humidity: 85% R.H. Temperature: 85±5°C Time: 1000 hours. High temperature resistance 1. Temperature: 150°C±5°C 2. Time: 1000 hours. Low temperature resistance 1. Temperature: -40°C±5°C 2. Time: 1000 hours. Soldering heat resistance Solderability 1. 2. Solder bath temperature: 260±5°C Bathing time: 10±1 seconds Specification No apparent damage Fulfill the electrical spec. after test. No apparent damage Fulfill the electrical spec. after test. No apparent damage Fulfill the electrical spec. after test. No apparent damage Fulfill the electrical spec. after test. No apparent damage The dipped surface of the terminal shall be at least 95% covered with solder after dipped in solder No apparent damage bath of 245±5°C for 3±1 seconds. ACD-5036-A3-CC-S Engineer Specification Version: A5 Page 6 of 8  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com (2) Storage condition (a) At warehouse: The temperature should be within 0 ~ 30°C and humidity should be less than 60% RH. The product should be used within 1 year from the time of delivery. (b) On board: The temperature should be within -40 ~ 85°C and humidity should be less than 85% RH. (3) Operating temperature range Operating temperature range: -40°C to +105°C. 9. Recommended reflow soldering ACD-5036-A3-CC-S Engineer Specification Version: A5 Page 7 of 8  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com (1) Soldering gun procedure Note the follows, in case of using solder gun for replacement. (a) The tip temperature must be less than 350C for the period within 3 seconds by using soldering gun under 30 W. (b) The soldering gun tip shall not touch this product directly. (2) Soldering volume Note that excess of soldering volume will easily get crack the body of this product. ACD-5036-A3-CC-S Engineer Specification Version: A5 Page 8 of 8  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com
ACD-5036-A3-CC-S 价格&库存
很抱歉,暂时无法提供与“ACD-5036-A3-CC-S”相匹配的价格&库存,您可以联系我们找货
