RFDPA191300SBLB811
RFDPA191300SBLB811
    INPAQ(台湾佳邦)
    2.4~2.5/5.15~5.9/6.0~6.9/7.0~.12
RFDPA191300SBLB811 数据手册
2.4~2.5/5.15~5.9/6.0~6.9/7.0~7.125 GHz Working Frequency Halogens Free Product RFDPA191300SBLB811 Specification Product Name Series/PN INPAQ RF Dipole Antenna RFDPA191300SBLB811 ELECTRICAL CHARACTERISTICS Item Specification 2.4~2.5/5.15~5.9/ Working Frequency Range 6.0~6.9/7.0~7.125 GHz (Note-1) 1.91 dBi@2400~2500 MHz Gain 4.5 dBi@5150~6000 MHz 3.37 dBi @6100~7200 MHz Return Loss -10 dB(Max) VSWR 2 max. Polarization Linear Radiation Pattern Omni-directional Impedance -20℃ ~ +65℃ Operation Temperature *Note 1. Central Frequency should be defined after customers’ application approval. MATERIAL TABLE Items Description Cable RG178 Cable(Brown) Connector Reverse SMA Plug(Black) Antenna Cover TPEE(Black) Antenna Down Base PC/PBT(Black) Antenna Up Base PC(Black) Rivet POM(Black) UP Brass Tube Brass Drown Brass Tube Brass Sponge EVA Color Ring PP(Process Blue C) Heat Shrink Tube CB-HFT (Black) ORDERING RULE RFDPA191300SBLB811 Engineer Specification Version: V01 Page 1 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com RF Type Code DPA Product Code 1913 00 S Cable Dimension Connector Length (unit: (Unit: mm) Brand cm) B L Type of Application Connector B 8 11 Project status Wire Diameter Project 0: 0GHz 3: 3GHz 5: 5 GHz A: N 6: 6GHz C:MCX Per 2 digits of D:IPEX III length, width E: IPEX IV 2 digits for cable length Walsin RF e.g.: 1913 H: Hirose Length Antenna ISM band 191.9mm, Width Male dual band U:MURATA N: None T:During Test G: GPS band X: Pile Run M: Male L: 2.4/5.2/5.8 S: SMA T: TNC 4:∅1.13 Low B: MP F: Female N: None ψ13mm B: GSM 900/1800 M: MMCX None Cable 3:∅1.13 Female I: IPEX e.g.:00 1:∅0.81 A: Reverse F: IPEX A13 B: Reverse Dipole Device 0:None A: 2.4GHz GHz tri-band Loss 01~99 series 6:RG316 number 7:∅1.37 8:RG178 9:∅1.37 Low Loss N: NFC T:LTE band W: WCDMA band RFDPA191300SBLB811 Engineer Specification Version: V01 Page 2 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com DIMENSIONS RFDPA191300SBLB811 Engineer Specification Version: V01 Page 3 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com Test Report ■ELECTRICAL CHARACTERISTICS RFDPA191300SBLB811 Engineer Specification Version: V01 Page 4 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com ■ELECTRICAL CHARACTERISTICS Return Loss RFDPA191300SBLB811 Engineer Specification Version: V01 Page 5 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com ■Antenna Efficiency & Peak Gain 2400~2500 MHz RFDPA191300SBLB811 Engineer Specification Version: V01 Page 6 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com 5150~6000 MHz RFDPA191300SBLB811 Engineer Specification Version: V01 Page 7 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com 6100~7200 MHz RFDPA191300SBLB811 Engineer Specification Version: V01 Page 8 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com ■RADIATION PATTERN 2400~2500 MHz X-Z Plane Phi=0.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 9 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com Y-Z Plane Phi=90.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 10 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com X-Y Plane Theta=90.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 11 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com 5150~6000 MHz X-Z Plane Phi=0.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 12 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com Y-Z Plane Phi=90.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 13 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com X-Y Plane Theta=90.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 14 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com 6100~7200 MHz X-Z Plane Phi=0.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 15 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com Y-Z Plane Phi=90.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 16 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com X-Y Plane Theta=90.00deg Gain . dB RFDPA191300SBLB811 Engineer Specification Version: V01 Page 17 of 17  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com
RFDPA191300SBLB811 价格&库存
很抱歉,暂时无法提供与“RFDPA191300SBLB811”相匹配的价格&库存,您可以联系我们找货
