12V-COB-4000K-12M
12V-COB-4000K-12M
    INSPIREDLED
    LED 照明 COB、引擎、模块 板上芯片(COB) - 白色,天然 线性灯条,弹性
12V-COB-4000K-12M 数据手册
12V COB LED Tape 420 LED/m Flexible LED Strip 265216 Inspired LED’s 12 Volt COB Flexible Strip Lights are a simple, costeffective solution for various task lighting applications. The higher density LEDs are encapsulated under epoxy creating seamless light uniformity. The higher density of LED diodes emits a strong light intensity while maintaining efficiency. Available in 12 Meter reels or bulk strips, these unique strips can easily be cut and terminated with the iDea Series Screw Terminal Solderless Connector for easy DIY installation. Energy efficient, long-lasting, and dimmable with compatible systems, Inspired LED COB flex strips are the perfect option for any lighting application! Specifications: Voltage LED Density Wattage Luminosity Color Temp CRI Warm White 12VDC 126 LEDs/ft., 420 LEDs/m 2.75W/ft. 196 lm/ft. 3000K 92 Pure White 12VDC 126 LEDs/ft., 420 LEDs/m 2.75W/ft. 209 lm/ft. 4000K 93 Product Features: • • • • • • • • • Product Dimensions: Chip-on-Board (COB) LEDs 8mm flex, cut points available every 1.4” (15 LEDs) Available in bulk pre-cut lengths or full 12m reels Class 2 DC plug-in connector (3.5 x 1.3mm), iDea Series Solderless Connectors or 18AWG-22AWG direct soldered leads available 3M adhesive mounting to almost any flat surface Dimmable with compatible systems Rated to last up to 100,000 hours CSA C22.2 No. 250.0-08/ANSI/UL Standard 1598, 8750 To be installed in accordance with NEC, using Class 2 12V power supply or constant voltage transformer only! Power Requirements: Power Source 1 Amp (12 W) 20W Transformer 2 Amp (24 W) 40W Transformer 5 Amp (60 W) 60W Transformer 100W Transformer 150W Transformer *Dimensions show in inches Installation Instructions: Max Length 42” (9.75 W) 70” (15.9 W) 85” (19.5 W) 144” (33W) 210” (48W) 210” (48W) 350” (80W) 522” (120W) *70% brightness at 150”. Longer strips should be powered from the center to avoid further voltage drop. inspiredled.com 1. Clean desired mounting surface(s) and test all products prior to installation. 2. Terminate iDea Series Screw Terminal Connector or solder 18AWG-22AWG wire directly to LED strip copper pads. 3. Temporarily mount LED flex strips using scotch or painters tape. 4. If using a low-voltage in-line switch or dimmer, connect the accessory to the LED strip using a low-voltage cable. 4. Connect 12VDC Class 2 Power Supply to in-line accessory or LED strip. 5. Test lighting system. When satisfied with the placement, peel adhesive backing from components and press firmly to adhere to surface. Troubleshooting: If LEDs are flickering, double check connection to be sure flex is fully inserted and secured, if no lights turn on check polarity to be sure they are properly matched. orders@inspiredled.com (480) 941-4286
12V-COB-4000K-12M 价格&库存
很抱歉,暂时无法提供与“12V-COB-4000K-12M”相匹配的价格&库存,您可以联系我们找货
12V-COB-4000K-12M
  • 336+4.19410336+0.52028
库存:2683
12V-COB-4000K-12M
库存:2683
