MOT-RB30GM-20-24V
MOT-RB30GM-20-24V
    ISL
    30MM SPUR GEAR MOTOR, OFF-SET SH
MOT-RB30GM-20-24V 数据手册
ø30mm Spur Gear Motor Carbon - Brushed / Off-Set Shaft MOT-RB30GM-20-24V Our Spur Gear Motors are an inline solution providing ample torque output at various speeds. They are best for intermittent duty operation. With endless performance combinations, we have a fully tailored gear motor solution for you. Contact Us for alternative solutions! Specifications Gearhead Type: Motor Type: Rated Voltage: Rated Speed: Rated Torque: Rated Current: Spur - Offset Shaft Carbon - Brushed 24V DC 245 rpm 1.25 kg.cm 300 mA No-Load Speed: No-Load Current: Stall Torque: Max. Power: Max. Efficiency: Termination Style: 325 rpm (+/- 10%) < 150 mA 5.1 kg.cm 4.23 W 45% Terminals Dimensions units: mm Performance Curve © 2020 ISL Products International Ltd. Specifications subject to change without notice. ISL Products International Ltd. • 235 Robbins Ln.,Ste 270 • Syosset, NY 11791 • T 516-937-3475 • www.islproducts.com
MOT-RB30GM-20-24V 价格&库存
很抱歉,暂时无法提供与“MOT-RB30GM-20-24V”相匹配的价格&库存,您可以联系我们找货
