DK00610JS
DK00610JS
    JABIL(捷普)
    钻头 碳化物 0.6mm
DK00610JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.003mm; Flute diameter tolerance: +0/ -0.01mm Cutter specification • • • • • • • • P/N: DK00610JS Specification: M30 R0.3xFL0.5xL2x2T_L45 Shank diameter: 4mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.003mm Flute diameter tolerance: +0/ -0.01mm Total length: 45mm Weight: 10.5g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing N/A N/A N/A N/A Semi-fine finishing 40000 1000 mm/min 0.03 mm 0.03 mm Mold steel Fine finishing 40000 800 mm/min 0.015 mm 0.015 mm
DK00610JS 价格&库存
很抱歉,暂时无法提供与“DK00610JS”相匹配的价格&库存,您可以联系我们找货
