DK02006ZO
DK02006ZO
    JABIL(捷普)
    钻头 碳化物 2mm
DK02006ZO 数据手册
Data Sheet CBN cutter Long-lasting high precision CBN endmill for mold steel. Applicable for working material Mold Steel HRC 50-68 finishing machining. Radius tolerance: ±0.003mm; Flute diameter tolerance: +0/ -0.01mm Cutter specification • • • • • • • • P/N: DK02006ZO Specification: R1xL6_CBN Shank diameter: 4mm Working material: Mold steel HRC 50-68 Radius tolerance: ±0.003mm Flute diameter tolerance: +0/ -0.01mm Total length: 50mm Weight: 11.5g • • • • • • Working material: Mold steel Machining type: Fine finishing Rpm: 32000 Feed rate: 2400mm/min Cutting depth (Ap): 0.01mm Cutting width (Ae): 0.03mm Recommend cutting parameter
DK02006ZO 价格&库存
很抱歉,暂时无法提供与“DK02006ZO”相匹配的价格&库存,您可以联系我们找货
