JA3D-C1001276
JA3D-C1001276
    JABIL(捷普)
    3D 打印丝 黑色 PA(聚酰胺) 0.070"(1.75mm)
JA3D-C1001276 数据手册
Jabil PA 4500 Filament Technical Data Sheet _______________________________________________________________________________ Product Description PA 4500 Filament is a low warp, neat nylon copolymer that has good lay flat/low warp properties, excellent appearance, strength in both XY and XZ directions, toughness, and can be printed at lower temps (240-260° C). Applications for this material include component production of less than 20,000 per year with complex geometries that require good wear properties and appearance are required but also strength and durability, such as slides, screen printing pallets, automation sleds, adaptors for fluid and materials handling, end of arm tooling (EOAT), masking covers, die cast models and patterns, clips, covers, housings, and gears. Advantages Along with easier printability, PA 4500 filament also delivers better appearance, over 100% elongation at break and better overall strength compared to other commercial PA’s and products like PETg and PLA. Storage and Use PA 4500 is highly hygroscopic, meaning it will quickly absorb and retain moisture from the atmosphere, affecting visual quality and mechanical properties. For best results, print and store filament in a dry environment. If necessary, dry filament in an oven at up to 75 °C (165 °F) for 6 - 12 hours. Download Jabil's optimized print profile by clicking here. Properties Mechanical Properties - Dry as Printed1 Test Condition Tensile Modulus (MPa) Tensile Elongation at Break (%) Ultimate Tensile Strength (MPa) Flexural Modulus (MPa) Flexural Strength (MPa) Flexural Strain (%) Izod Impact, notched (J/m) Izod impact, un-notched (J/m) 1. Testing conducted on bars printed are for reference only. XY coupons, Ambient XY coupons, Ambient XY coupons, Ambient XY coupons, Ambient at 260 °C and tested at Typical Method Value 1930 ASTM D638, Type I >100 56.0 1440 ASTM D790 56.9 >5 61.5 ASTM D256 830 500 Ultimate Tensile Strength (MPa) 41.6 Flexural Modulus (MPa) 497 XY coupons, Ambient ASTM D790 Flexural Strength (MPa) 20.4 Flexural Strain (%) >5 Izod Impact, notched (J/m) XY coupons, Ambient 282 ASTM D256 Izod impact, un-notched (J/m) XY coupons, Ambient 1714 1. Testing conducted on bars printed at 260 °C and conditioned for 14 days at 23 °C and 50 % RH. Typical values are for reference only. Test Condition Thermal Properties Test Condition Heat Deflection Temperature (°C) Melt Temperature, Peak (°C) 0.455 Mpa 20°C/min ramp Typical Value 62 190 Method DMA DSC Other Physical Properties Test Condition Density (g/cm3) Ambient Typical Value 1.10 Method ASTM D792 Dimensional Properties Test Condition Diameter: Mean, Indiv. Axis (mm) In-line, 100% inspection Typical Value 1.75±0.05 2.85±0.05 Method Laser Micrometer ________________________________________________________________________________________ United States: en 19-MT60-00048 Rev A Page 2 of 3 Jabil PA 4500 Filament Technical Data Sheet _______________________________________________________________________________ Disclaimer: The information in this technical data sheet, including material properties, are obtained from testing representative samples under carefully controlled conditions and are provided for reference only. Material properties may be impacted by storage, handling, processing equipment/parameters, and product design, among other factors. The information is not a substitute for user testing to determine fitness for any specific use and the user is responsible for ensuring safe and lawful use of the product. No express or implied warranties are provided and the implied warranties of merchantability or fitness for a particular purpose are expressly disclaimed. No representations are made, and no liability is assumed arising from or relating to the product. Copyright/Trademark: © 2019 Jabil Inc. All rights reserved. JABIL® and the JABIL logo are registered trademarks of Jabil Inc. ________________________________________________________________________________________ United States: en 19-MT60-00048 Rev A Page 3 of 3
JA3D-C1001276 价格&库存
很抱歉,暂时无法提供与“JA3D-C1001276”相匹配的价格&库存,您可以联系我们找货
