GN 139.1
GN 139.2
Hinges
with Safety Switch
without Safety Switch
Zinc Die-Cast
Metric
3
Type
A
B
C
Connector plug at the top
Connector plug from the bottom
Connector plug at the backside
(with 0.2 m cable)
AK Cable at the top
BK Cable from the bottom
CK Cable from the backside
Metric table
1
2
l1
l2
Hinge wing
small
Hinge wing
broad
49
1.93
79
3.11
101
3.98
Dimensions in: millimeters - inches
4
l3
30
1.18
l4
81
3.19
l5
l6
h1
Hinge wing
small
Hinge wing
broad
Cable length
in meter
15
0.59
30
1.18
2
5
h2
12
0.47
m1
22.5
0.89
71
2.80
m2
17
0.67
m3
Hinge wing
small
Hinge wing
broad
27
1.06
50
1.97
Specification
Information
• Body
Zinc die-cast
Powder coated
Silver metallic finish
GN 139.1 hinges with integrated safety switches have been designed for use on monitoring doors and
covers of machines and equipment. Opening the door activates the switch contacts. This causes an
interruption in a protective circuit via broken contact (NC) and at the same time signals the door opening
by closing a normally open contact element (NO).
• Pin
Stainless steel
European Standard No. 1.4305 (AISI 303)
The contact blocks are fitted with positive opening slow-action contacts, i.e. they will definitely be
separated when activated and have no hysteresis. The angle at which the switching points are reached
is adjustable.
• RoHS compliant
Accessory
• Cable with connector coupling
8-pole, 5 or 10 meters:
-- GN 330-M12x1-8-G-5
-- GN 330-M12x1-8-G-10
• GN 139.3 / GN 139.4 mounting plates
GN 139.2 hinges without safety switch are identical to GN 139.1 except they lack the connector plug.
The compact construction combines safety and attractive design. The hinges are tamper-proof because of the covered mounting from the back side.
see also...
• List of Hinge Types
How to order (With safety switch)
1
On request
• Hinges with operating angle > 0°
• Hinges with other contact load ratings
32
2
3
4
GN 139.1-49-101-AK-5
How to order (Without safety switch)
1
2
GN 139.2-49-101
| 3.3 Hinging, Latching, Locking of Doors and Covers
1
Width l1
2
Length l 2
3
Type
4
Cable length l 6
1
Width l1
2
Length l 2
www.jwwinco.com | phone: 1-800-877-8351
GN 139.1 / GN 139.2 Hinges continued
Mechanical features
Maximum load
Information with safety factor
Load
direction
l1 = 49
1500 N
1000 N
1000 N
l1 = 79
337.21 lbf
750 N
224.81 lbf
500 N
224.81 lbf
500 N
112.40 lbf
112.40 lbf
Contact material
Operating travel diagram
(scheme)
168.61 lbf
from the back, 7 x threads M5, 6 mm deep
5 Nm (Screws M5)
IP67 / IP69K
(Mind the cable conduit!)
Slow-action contacts
force-fitted, with positive opening
Silver alloy
The switching points are adjustable
up to 4° in direction of 0°.
Maximum operating frequency
Mechanical life span
Actuating speed
see operating instruction
600 operating cycles / hour
106 operating cycles
min. 2° / second, max. 90° / second
Examples of calculation
→ see operating instruction
Fixing
Recommended torque
Protection class
Switching principle, contact opening
acc. to EN 60529
acc. to IEC 60947-5-1, K
one operating cycle includes one opening and one
closing action
Electrical features / Safety features
Utilization category
AC 15: 24 Vac / 2A / DC 13: 24 Vdc / 2A (connector plug) acc. to EN 60947-5-1
AC 15: 250 Vac / 4A / DC 13: 250 Vdc / 0,3 A (cable)
Contacts, termination
8-pole connector M12
or cable with 2 m or 5 m length
Pin and cable assignment
Type of cable
Typ N 7x0.5 mm2, jacket PVC H05VV-F
acc. to IEC 60332-1-2 et seqq.
Short-circuit current
1000 A
Rated insulation voltage
30 V AC / 36 V DC (connector plug) / 250 Vac (cable)
Short-circuit protection
Ambient temperature
2 A, 500 V, Typ gG (connector plug) / 6 A, 500 V, Type gG (cable)
- 25 °C up to + 80 °C
Degree of pollution, external
3
Mission time (TM)
20 years
acc. to EN ISO 13849-1
Number of cycles (B10 d)
5 000 000
acc. to EN 61820-2
Approvals, Conformities, Applicability
Low-voltage switchgear and controlgear
CE declaration
IMQ: CA02.03746
UL: E 131787
Safety applications
up to SIL 3 / PL e
EN 60947-1/2007
EN 60947-1-5 : 2004 +
A1/2009
Other important details and hints are given in the operating instruction for GN 139.1 hinges which are included with every hinge and which are also available as PDF
downloads from “www.jwwinco.com“ under “Service“.
The hinges with safety switch must be mounted and commissioned by qualified technical personnel in compliance with the details given in the operating
instructions and with the national and international rules and regulations and the applicable standards. JW Winco will assume no statutory liability for missing or
incorrect information and for any consequences arising therefrom.
3.3 Hinging, Latching, Locking of Doors and Covers |
33
很抱歉,暂时无法提供与“139.1-79-101-A”相匹配的价格&库存,您可以联系我们找货
